Full engine rebuild - LET Calibra 4x4
20K views 143 replies 22 participants last post by  c20letian
#1 · (Edited)
hey guys just thought id put up some pics of my car and what in doing to it...
im hoping to get the engine out soon and give it the star treatment." align="left" hspace="6" vspace="3">
See less See more
4
#120 ·
no probs. throttle body gaskets
i got this gasket paper of ebay, its .8mm thick. i used the old gaskets as a stencil then cut them out. that pipe temp gauge and 2 pence are the perfect diameter for cutting around.
#122 ·
i got another adapter in the post today and its a better colour match. both adapters are from torques and the end fittings are from demon motorsport.
these are an6 the one that is screwed into the fpr blanking plate is 1/8bsp to AN6
and the other one thats screwed into the fuel rail is M12x1.25 to AN6
#137 ·
thought id fit a pressure gauge to the fuel rail so i removed the valve, drilled it out to 8.5mm then tapped it out to 1/8bsp.
i will get a different gauge at some point but this will do to show what it will look like...
