C18XE powered tigra.
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 50
Thread: C18XE powered tigra.
    MIGClub Member Turbostevo's Avatar
    Jan 2011
    Chesterfield, derbyshire
    Saabastra/E36328/bora/147
    Seeing as my Saab tigra idea failed ive decided to use the engine out of the astra that the Saab engine ended up going in to power my tigra. The car is done and ready for the engine so I've been working on the engine getting it ready for fitting.
    Started by changing the timing belt for a new gates one including tensioner and rollers, new water pump, oil & filter and spark plugs. That's as far as I'm going to go with the engine apart from a 4 branch manifold to replace the cast manifold that comes with the engine.
    As the tigra has been converted to non-pas I've removed to pas pump from the engine. Should improve rev response a tiny bit as there's less resistance.
    I'm going to use a flat tigra flywheel and an f 13 gearbox.
    More info and specs to follow.
    Cheers
    Jan 2011
    Re: C18XE powered tigra.
    now pics of the donor car.
    Jan 2011
    quick update on this build, the car is now being sold to my mate when its finished so he has been giving me a dig out with it! (he is new on here...username name dizzy121).
    enjoy the pics and as ever if anybody wants any info please ask
    Jan 2011
    Jan 2011
    Jul 2009
    St Helens
    Opel Vectra B 2.6 v6
    Well done it's looking good
    Jan 2011
    Cheers bud
    Oct 2011
    Chesterfield
    Tigra
    cant wait for it to be done pal
    Jan 2011
    Well get a bit more done tomorrow mate.
    Oct 2011
    Chesterfield
    Tigra
    when we next getting some done pal ??
    Jan 2011
    Rate pal if it's not raining I'll pick you up tomorrow I promise! Well get the engine finished and well
    Shift all the cars about and get the Tigra up to the garage ready for dropping it all in
    Oct 2011
    Chesterfield
    Tigra
    yeh mate proper good you have made my night u leg-end hahahahaha
    Jan 2011
    Not really taken many pics recently but we've made loads of progress with the engine. I'm just drilling the flywheel then that's done. The Clutch will follow then the gearbox (f13) then it's a case of dropping it in and measuring up a mount. Only got the 1 pic to add but that shows the engine back together with new t/belt, tensioner and idlers, w/p etc and a bit of paint!
    Moderator Melv's Avatar
    Dec 2006
    KEITH, N.E. SCOTLAND
    1.8 Corsa Merit + ACT
    Is the F13 going to be strong enough to cope with the C18XE?
    Jan 2011
    I'm thinking it will be fine mate, I've heard of a few people running them on C20XE's. Only time will tell
    MIGClub Member DrewyCoupe's Avatar
    Jan 2011
    Chesterfield
    Astra Coupe Turbo
    nice work stevo
    Sep 2004
    Greece
    tigra/LET westfield
    would a z turbo manifold fit the head?
    MIG.....Made In Greece LOL
    Administrator
    Apr 2011
    Nicely done!!
    Jan 2011
    Quote Originally Posted by TigraTurbo View Post
    Not sure mate, if you send me 1 I could try it and let you know! Not sure where to get some low comp pistons but I'd definitely be interested in a turbo conversion at some point.
    Stevo
    Dec 2006
    It wouldn't be far off. The Z20LET is basically just a X20XEV + turbo in loose terms.
    Jan 2011
    Quote Originally Posted by DrewyCoupe View Post
    nice work stevo
    Quote Originally Posted by Admin_Steve View Post
    Nicely done!!
    Cheers guys. Thanks for the positive feedback, it's taken us long enough! Should be on the road Soon hopefully.
    Jan 2011
    Got a few more bits done tonight, re-drilled the flywheel to fit, bolted the clutch on and scrubbed the gearbox. Then gave it a quick coat of silver wheel paint to finish it off.
    Jan 2011
    Shame that minging manifold spoils it!
    Dec 2006
    Can you not shot blast it then paint it with high temp paint? Gotta be cheaper than a lexmaul lmao
  26. #25
    East Mids Regional Co-ordinator simonsri's Avatar
    Dec 2010
    Chesterfield
    Vectra Sri 150
    Looking good guys, will be at the meets in it in no time at all.
Tags for this Thread
