Don't post on here much really, but I do a lot of reading so thought I might as well stick a project page up. A bit of an introduction is needed I guess. Up until recently, I've been heavily involved in the classic mini scene, running a 1380 lightened and stripped out track spec mini, which I intended putting a tuned C20XE engine in and using for hillclimbs. Daily use took it toll and I needed a new car which I could put the XE engine into, so I bought myself a phase 1 GSi for the sum of £800 a few weeks back.
This is what I ended up with.
Ok so the wheels are a bit tacky, and the rear end has some rust problems, but I'm absolutely chuffed with it!. Its the 1.8 model (which I guess some of you would know just by looking), but in the grand scheme of things thats not gonna be an issue!.
It will need a pair of outer sills, inner and outer rear arches and some work on the valance. All common stuff I'm led to believe. Needs a few temp senders and bits like that, but really nothing too serious.
Since being into minis, I've done lots of fabrication, making various bits out of titanium and carbon fiber. Queue the filler cap solenoid mod/repair.
New rod was made from 5mm titanium (6AL4V). One job ticked off the list.
In an attempt to keep things interesting in here, I'll reverse back to the XE I've been building up over the last year or so (remember it was destined for a mini to start with!). Spec is roughly as follows, and I'm aiming for the roundabout figure of 260bhp with a big chunk of torque.
S80 Pro DTA ECU
Arrow/SBD steel rods
88mm Omega pistons
SBD throttle bodies
Z20LET pump
Mains girdle/strap
Lightened flywheel
Twin plate super clutch
Quaife LSD
VAG COP's
One seriously worked head
Solid tensioners/idler kit
SBD 300/295 duration cams
Probably lots more I've missed though.
Anyways thats a little bit from me, and with any luck I'll be on here fairly regularly now!
Tom.
