another mk4 astra project C20XE
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 28
Thread: another mk4 astra project C20XE
    Jan 2008
    newcastle
    mk4 astra redtop/cav
    right o heres the latest project had it about a month now not really done anything as got it with a wrecked engine
    its standard apart from rear tinted windows
    its a 2004 sxi model and usually comes with a 1.6 16v z16xep engine
    came with coupe leathers ( also got rid of the playboy seatbelt cover things lol)
    also came with a full sound system including upgraded front and back speakers
    heres the pics
    the sound system
    vibe cbrs12 twin evos
    vibe deep black box bass 5
    and full vibe black air 5 component set
    so thats what i got it with i swapped it for a tubby rep spectral blue cavy dippy
    so now just to add my little mods
    something ive done with all my cars is angel eyes its a personal touch
    i bought them off a member on AOC for £33 in need of repair
    so recivied them threw the post one of the lenses kind of melted should i say and the other unit was cracked.so ditched the lenses for the one off the astra and cut one of the units and plastic welded it back to gether and heres the finished result
    also had 2 sets of hids sitting about i got cheap
    a few pics of the lights fitted and its new home untill i get the engine sorted
    Jan 2008
    newcastle
    Re: another mk4 astra project
    with the lights fitted
    also got a badgless grill to put on still sitting in the box lol
    Jan 2008
    newcastle
    right with the engine bay empty it was time to turn to what do i put in it
    options were
    1. 1.7td isuzu engine that sitting under the blue cover in a cav £0
    2. the same engine that was in it 1.6 16v £400
    3.2.0 16v redtop complete car £300 and with the option of paying it up off a mate
    so this is the result
    so arrived at my mates on saturday morning house with the car sitting in his garden awaiting to be stripped
    before
    xe in my cav boot lol
    and thanks to my mate camy brought the engine crane over on the Sunday at 3pm thanks mate
    had the engine in by around 6pm with it all mated up to the gearbox then it was getting dark
    yesterday i went back to my mates to get a few more parts off the cav (mainly spares for ours lol )
    so got a 4-2-1 full stainless steel exhaust and fuel pump (not sure if the one in the Astra will be ok for the job )
    f16 gearbox
    accelerator cable
    plugs off the loom for the ones that plug in beside the ecu
    and a load of other parts
    today i set about the wiring just matched colour for colour on the black and green plug with loom sitting in front of the fuse box (empty bay pic ) and joined them up to there quite a few wires left
    only thing i couldn't figure out was the fuel pump wire in the car loom ( found the relay in the fuse box so pulled the fuse out and stuck the wire into the blue and red thick wire in there)
    i decided to use the Astra starter and alternator wiring loom as it was basically plug and play
    and hey presto first turn of the key and the engine started first time to my surprise with out afm connected or down-pipe or any coolant connected but was only run for a breif 2/3 seconds
    decided to put the ecu in the car over night as i dont like it sitting out in damp weather will i can seal it up and find a suitable place to put it
    also got the down pipe connected and cav rad in place and pipes joined but not tightened up yet
    here how i left it before i closed the bonnet
    Jan 2008
    newcastle
    the main part thats needed now is the engine mount not sure what folk have used but thinking a corsa redtop conversion mount would be the best thing to use
    whats everyone els used ??
    thanks for taking the time to read
    gilly-06
    Mar 2006
    Royston
    Various Vauxhall's
    Thats going to be good at the traffic lights! Bye Bye
    Feb 2002
    Fareham, Hants.
    13S C20XE X20XEV
    The Astras pump will be fine for the XE. Well done on the starting and charging loom. Many people, even long term members, don't realise the extra work they make for themselves by cutting that loom apart. As you say, it just swaps from one engine to the other. The temp gauge won't work without the 1.6's sensor and ECU to drive the clocks I think.
    There is just room to squeeze the XE ecu behind the clocks, after you've cut the hole in the bulkhead for it.
    They're there, in their room.
    Jan 2008
    newcastle
    Quote Originally Posted by badboysracing69 View Post
    im not much of a racer lol i know a decent amount about the redtops plus less hassle than the newer engines lol
    yeah i thought there might have been problems with the starter thinking it wouldnt turn over because the engine ecu wasnt inplace but it turned over ok
    and thanks for the advice about the astra pump thats another thing i dont need to worry about lol and good idea about the ecu keeps it out of the damp didnt really want to mount it outside
    Jan 2008
    newcastle
    todays progress
    got the rad all plumbed in and the astra fan connected and cable tied to the rad
    all the coolant plumbed in
    airbox all set up again
    fuel pipes joined and secured
    exhaust mated up (still blowing a little but have to add a cat so will be coming off to get the cat pipe sorted)
    accelerator cable inplace
    changed the alloys for the ones on my cdx
    and added the debaged grill from egay
    still to do
    get accelerator pedal + fit
    relocate ecu
    add battery tray
    buy /make engine mount
    do a proper job on the wiring after ive relocated the ecu as the wires will have to go to the plugs beside the ecu
    and thats about it
    heres the pics
    Jan 2006
    liverpool
    a p.c with wheels
    have you got the engine mount sorted mate? I bought an astra mk4 with a c20xe engine already converted and it looks like they have used a corsa conversion mount welded to the chassi leg. i can send you a picture if you want?
    Want good quality mirror finish smoked rear lights for you car? drop me a pm.
    Jan 2008
    newcastle
    pictures would be brilliant mate im making up a temp mount for now using a 2.0 8v engine mount and making my own rubber mount using stickaflex untill i can get some cash together to buy one
    cheers and much appreciated
    also started moving the ecu to inside the car today want it to look like its standard going round the strut mount area and thew the bulk head that way just the hole to cut to inside the car
    Sep 2010
    Bridgwater/Glastonbury
    Astra G C20XE
    i used the cam side mount from an x20xev astra, you have to drill and re-tap the 3 holes on the side of the block behind the inner cam cover, but as you now have the engine in the car allready your going to have a job with that..
    on a previous conversion i used the corsa mount setup and welded to the chasis leg but i made this myself
    have a read through my diary it may interest you
    Astra G c20xe Project (very picture heavy)
    ASTRA G C20XE,BUILT NOT BOUGHT... GD DEVELOPMENTS
    Jan 2008
    newcastle
    funny enough iwas just having a look at your thread brilliant build
    Jan 2008
    newcastle
    well thats the ecu placed in the car went the same route as the cavy went and in threw the bulkhead found all the wiring inside the car beside the fuse box only thing i had to do was find the fuel wire at the old bulk head plug and cut it and extend it to the drivers side and joined it there
    im keeping the switched live + oil level(front of sump) in the bay as they connect to a sep plug so im happy keeping it in there saves anymore hassle trying to re route them threw the bulk head
    got some interior bits done between the last few weeks
    got blue led conversion on the mfd and headlight switch and clocks
    also done the heater controls but due to them having a orange tint to the facia i had to go with that but i like it
    then i got some white festoon led bulbs for the interior lights as i dont like the blue you cant see a thing with them
    got a few other b sit sorted my sterio in and ran some more audio cable for the front and rear speaker amps
    and my external base boost usb wire and aux cable in the centre cubby hole part
    heres a pic of the centre consol
    Aug 2010
    york
    mk4 astra van
    Thumbs up Re: another mk4 astra project C20XE
    hi buddy
    how did you get your heater control so bright? what did you use to do it?
    looks good
    Nice project . bet you cant wait till your engines all complete
    Jan 2008
    newcastle
    i used 19 leds lol was prity fiddley to do but worth it its not as bright at the pic itsnot so in your face lol
    yeah everythings virtually finished
    few tings i need to do and get is
    finish the engine mount
    get an accellerator pedal
    and fit an external temp guage and
    and it should be ready for the road
    oh also still cant seem to get the power steering working for some reason
    Aug 2010
    york
    mk4 astra van
    hi buddy. have you any pics or how to,s on how you did your led conversions. its someting i want to do. but i dont know how to get the control knobs lit up.
    or if you could explain what you did please
    my email is chrisgs23@yahoo.co.uk
    would be a huge help
    chris
    Jan 2008
    newcastle
    well long and coming update sorry guys
    got married in march 26th then in may decided to move to newcastle so the project halted there
    finally about 2 months ago i got it transported up (shiply) for £120 which aint bad
    so the work commenced down here trying to get it sorted
    first thing i dont was lower it on 60mm rear and 40mm (cav fronts because of the engine thought it would be better)
    put all new brakes on and started on the exhaust
    i bought av6 vectra estate backbox off a friend (that was too big )
    so then decided to cut the rear wheel well out and do a centre exit
    because the temp guage wasnt working i decided to go the route of the digi dash then everything works basically ive wired the speedo up to the abs and it only seems to be 2mph out using them speed signs at the side of the road
    some pics
    its mot'd and tax'd now im glad i kept it
    i have a cat back turbo exhaust to put on it and im going to put the exhaust back to the left hand side not too keen on it in the middle
    Oct 2004
    Oban - West Scotland
    Astra G/Nova TB
    The wiring/ecu etc of newer cars confuses me, well done figuring it all out.
    New wheels look much better
    Jan 2008
    newcastle
    i have plenty of Patience for wiring lol.decided not to keep the astra ecu couldnt be fussed with all hassle of 2 ecu's looks much neater under the bonnet and i decided to use the cav rad and made my own wiring up for the fan
    only problem i stumbled upon was the electric steering pump trying to get it working its working just now but i have to rewire it to the blue/ white alternator wire
    MIGClub Member crombievts's Avatar
    Jun 2007
    Dingwall
    ph1 clio 172 track wep
    i wired my ps to the alt and it was perfect
    Sep 2011
    essex
    Astra sri
    read this as i really wanted too know about the engine mount as i was going to use a corsa mount but going to try drilling the holes out on the block as its already a x20xev astra! result
    INSTALLING SUMMER... ████████░░░░░░░░44% DONE. Installation failed.
    404 error: Season not found.
    Jan 2008
    newcastle
    i used the corsa mount set up didnt wanna chance going threw the block + if i need to do a head gasket change or anything its easier
    Jan 2008
    newcastle
    Quote Originally Posted by crombievts View Post
    yeah thats my plan mate but i couldnt get it to work at all then found the wire in the ecu harness
    Sep 2011
    essex
    Astra sri
    Could you get me a pic of your mount setup mate?
  26. #25
    Jan 2008
    newcastle
    just using the corsa b mount set up mate
    sorted a few annoying bits on the astra like the electric steering
    i have a zlet middle section and back box to put on as i'd rather have a more or less standard system just need the flange the otherside of the cat and weld that on to the redtop downpipe
    also thinking on fitting a f28 box aswell i know i need to use a f23 rear gearbox mount and custom front mount (was thinking of using corsa/nova mount kit )
    and i also need to use an f18 hydraulic cylinder and pipe for the clutch
    ive heard the cali/cav equal length shafts are the best to use do these fit the astra hubs ok ??
    i need to change engines anyways as some one said low oil pressure so hopefully the mrs will let me transfer the cav lump in to it and then rebuild the one out the astra
