Sorry its another corsa b 20xe but i have allways wanted to build one so here go's
First off i bought a gsi with a 20xe fitted....
Beleave it or not this car was advertised just needing a front screen which was supplied
Ill let the pics do the talking..
As you can see it needed slighty more than a front screen.
I've had it for over a year now just sat about not having time to get round to starting it. So the time has come to get started.
Next up take the engine out.
The amount of bodge jobs on this car is unbelievable. Here are just some of them.
Snapped stud in the block.
Core plug leaking.
Pipe from the air flow meter split.
And just some pics of the strip down of the engine.
Then jet washed the engine off and started painting everything.
I had all the nuts, bolts, washers, cam sprockets, and some other bits and bobs zink plated. I should of taken some pics of them before.
For some reason i cant seam to find some of the build up pics.. Not to sure whats happened.
New alt bushes.
Some new parts that came thought.
And how it is as of today..
Ill update some more as soon as i can.
Steve.
im i big fan of the zink plating such a nice touch
. i think im gonna look into getting some bits done myself now after seen this. will look forward to the next update.
