Hi all just a wee thread on my calibra LE I picked up late last year, I was hoping to have a quick turnaround from purchase to getting it on the road but have since had a couple of setbacks.
Anyhow onwards.... first up a couple of pics of the car
When I picked the car up the work it required mot wise was fuel lines replacing (I have since done with nylon tubing) and the calipers/brakes sorting.
After removing the old seized calipers it was quite obvious the brake lines would also need doing when this happened
after further investigation it looked like the steel lines corroded around clips and corners so I removed all the lines and plan to replace them with cunifer pipe, I also ordered some goodridge braided hoses to replace the worn rubber flexible s.
The car did come with a replacement set of calipers removed from a cally in the scrappy however I am tempted to just replace everything now and just get some reconditioned ones. If I had aspirations for 300bhp in the future would standard stoppers do the job or would I be better off putting the money away for an upgrade?
One of the seized calipers
the spare ones
I'm also considering replacing the bottom wishbones, track rods etc just as a matter of course as at least one ball joint is split and it all looks somewhat scabby anyhow, any advice on what I should be looking to renew?
I have missed quite alot of photo opportunity's as it was only suggested today I make this thread but I will be under the car again soon.
