4X4 MK2 Astra GTE, Was in MAXPOWER in 1996.
Page 28 of 32 FirstFirst ... 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 LastLast
Results 676 to 700 of 787
Thread: 4X4 MK2 Astra GTE, Was in MAXPOWER in 1996.
  1. #676
    Jul 2005
    Tiptree Essex
    PACE/COURTENAY 1.8 GTE
    Re: 4X4 MK2 Astra GTE, Was in MAXPOWER in 1996.
    Quote Originally Posted by IanPaskin View Post
    That's very nice work, think you've done the right thing taking the 2 inches off.
    Thanks Ian fingers crossed 2" is enough..
    Quote Originally Posted by CB GTE View Post
    Actually Benn its an 8 gallon tank. I dont go far to be fair so i'm not to bothered I'l measure it, how much for the pipe?
    Sorry just seen this, 8 gallons is about 32lts... And erm... £30? Not sure really what it's worth now..
    Performance Vauxhall Show - HERE Please click for more information.
    VBOA at Billing - HERE Please click for more information.
  4. #678
    Peterborough
    Omega
    A gallon is touch over 4.5l so the tank is just over 36l
  5. #679
    Jul 2005
    Tiptree Essex
    Over the wk end I made this, fidley and frustrating i'm glad its done
    Then after I had finished the tub I put the fixings into the frame, then marked the floor where it was going to sit and drilled the holes clamped it up and welded it in place. Still need to weld it in underneath.
    I put the tub in place
    I dropped the tank in, although it wont be this low when I finish, but it does look sweet
    Thanks for looking
    Chris
  6. #680
    Peterborough
    Omega
    Looks spot on, good work!
  7. #681
    Jul 2005
    Tiptree Essex
    Quote Originally Posted by pmc_3 View Post
    Thanks mate
  8. #682
    MIGClub Member IanPaskin's Avatar
    Jan 2012
    Shropshire
    MR2 - Astra G
    I bet your finding it much better welding the new steel together? and the spit jig must be making life loads easier?
  9. #683
    Jul 2005
    Tiptree Essex
    Fresh clean steel is much easier to get on with. And the jig well what can I say heaven sent
  10. #684
    Jul 2005
    Tiptree Essex
    Hi, i'd like some input on how to go about my next move? Here's where i'm at
    The tanks jacked up about 20mm on a couple of blocks, I dont want to rush in and make brackets / a frame and get the tank in so i'd like to have some idea's from you guys.
    I'm concidering a swirl pot on the drivers side and I want to mount a battery on the NS. I'd like to make some kind of universal battery tray. The battery in the boot is on its last legs but will give me some rough dimensions, i'd like it to be adjustable so I can fit different sized batterys.
    Eventually i'd like to cover the boot in minus the battery.
    Thanks for comments
  11. #685
    Rs1
    Rs1 is offline
    Dec 2004
    Newcastle
    Corsa C SRi
    If you have clearance underneath then i'd be tempted to sink the battery to the same level as the tank.
    I'd also run the swirl pot, pipes, pumps ect. external as its so much neater and user friendly
    "THE ROB"
  12. #686
    Jul 2005
    Tiptree Essex
    Quote Originally Posted by Rs1 View Post
    The fuel pump will be in its original position under the car on the drivers side, I'm not sure whether to use a swirl pot as yet. Anyone recommend a reasonably priced swirl pot? pipes fittings and a pump.
    Chris
  13. #687
    Aug 2004
    glasgow
    astra 4x4 C20LET TURBO, v
    I would be tempted to use a small gel race battery and sink it into the floor. Try Ebay for swirl pots. Think that's were i got mine. Ull need to decide what fitting u want on urs. Top work on the tank. Kinda miss doing that stuff to the astra.
  14. #688
    MIGClub Member mk2astraturbo's Avatar
    Jun 2005
    Boston ,Lincolnshire
    LET Astra V6 Vec mk1astra
    hi some champion work there , when do you think the project be ready for the road ? also where did you source your jig from ?
  15. #689
    Jan 2012
    Shropshire
    MR2 - Astra G
    if you are using a std battery I would probably sink a small tray into the floor even if just an inch (I guess exhaust runs under that part) this will give you a solid edge to then clamp up the battery and if it did leak it will trap it... to hold it down I would find a clamp from a car where it clamps on the chamfer on the bottom of the battery some lock in the gaps to stop sideways movement probably just need to go to a breakers yard and have a look around.
    but as Gaz says a gel battery would be better but then they're not the cheapest...
    for swirl pots have a look here demon motorsport ltd Swirl-Surge-Tanks products look good and have seen some good reviews, most likely getting my tank from them.
  16. #690
    Jan 2013
    doncaster
    1.3sr nova & corsa sport
    that looks spot on that matey! glad the tank issue is drawing to a close lol
  17. #691
    Jul 2005
    Tiptree Essex
    Quote Originally Posted by mk2astraturbo View Post
    Hi mate thanks for comments, I have no time scale, but hopefully early 2014.
    Heres a link to the jig
    ROLLOVER SPIT, JIG, Vauxhall Astra, Nova, Corsa, Viva, Cavalier, Magnum, Victor | eBay
  18. #692
    Jul 2005
    Tiptree Essex
    Quote Originally Posted by gazturbo View Post
    Hi Gaz thanks for the comments I know of a second hand swirl pot locally I may buy it. If you miss it that much it must be time for a new project,lol or come and help me with mine. We have a spare room, but you have to bring your car with you it's the law....
    Hi Ian, I want to cover the tank over so battery will be enclosed aswel giving the illusion that it's sunk in, i'l have a look at the swirl pots thanks for the link
    Chris
  19. #693
    Jul 2005
    Tiptree Essex
    Quote Originally Posted by wudgey_sr View Post
    Well the floor's done ish still allot to work out but at least I can get some paint on it and get the white GTE in for its engine re-fit
  20. #694
    Jan 2013
    doncaster
    nice matey if if there is still things to figure at least its getting there! and at least that ^^^^ stunning machine can have a heart fitted =)
  21. #695
    Nov 2009
    Taunton, Somerset
    mk3 Astra GSi ph2 4wd
    Been contemplating an alloy tank recently but need a big one otherwise ill live at Shell :lol:
    I don't have that rear subframe mount: mines been fabricated like this
  22. #696
    rc
    rc is offline
    MIGClub Member rc's Avatar
    Jan 2007
    Felixstowe, suffolk!
    359.9bhp astra
    jim is yours still rubber mounted on the front? That could cause some issues..... Standard they're rubber mounted front and rear. So yourswill be flexing up and down at the front and welded solid at the rear, could cause cracking in the weld.
  23. #697
    MIGClub Member TigraTurbo's Avatar
    Sep 2004
    Crete
    tigra/LET westfield
    White....yummy.....
    MIG.....Made In Greece LOL
  24. #698
    Jul 2005
    Tiptree Essex
    Hi here's today's effort
    Eventually after allot of thought and faffing about doing other things, like.. Bolting the tub thing in I made last wk but before I did that I put the suspension cradle thing in place just to see if all's ok.
    I'm glad to report it is
    After playing about doing that I decided to make this, I haven't decided how to mount it yet, it is very heavy duty 4/5mm steel maybe slightly ott it is 175mm wide and 278mm in length and 160mm high, the battery I have in it at present is 210mm in length so it would need packing out.
    It's still work in progress
    Thanks for looking
    Chris
  25. #699
    Jul 2005
    Tiptree Essex
    Quote Originally Posted by jimbo87 View Post
    How much room do you have? Or will you be putting it in the boot?
    I have a few shares with shell so get a juicy motor and a small tank
    Chris
  26. #700
    Jul 2005
    Tiptree Essex
    Quote Originally Posted by rc View Post
    Oh I was wondering if that would happen
