meriva c20let
Page 3 of 3 FirstFirst 1 2 3
Results 51 to 64 of 64
Thread: meriva c20let
  1. #51
    Oct 2008
    Moscow region, Russia
    meriva c20let
    Re: meriva c20let
    vx220 clocks. already connected. need advise, who done it
    had worked with clocks and other wiring all this night, so hadn't done only 2 connections.
    Oct 2008
    meriva c20let
    Re: meriva c20let
    this is seat frames, about i posted previously.
    as you can see, most holes are in same places, so it wasn't hard to remove them.
  4. #53
    Oct 2008
    meriva c20let
    Re: meriva c20let
    and some pics of my gearchange. it wasn't finished- need to weld, cut all angles and unneeded sides, and paint it. but now it's fully working and it's wonderful! really easy moving with no lufts at all. have little free move on "left-right" in gearbox, but i'll try to make this later, when will installing lsd
  5. #54
    Oct 2008
    meriva c20let
    Re: meriva c20let
    i had made a hole for engine loom and stack gauges wiring to install ecu in dry place, under the dash.
    also hade made a hole for nitrous line, to make it nice installed through all cockpit.
  6. #55
    Oct 2008
    meriva c20let
    Re: meriva c20let
    and then back to clocks wiring. same time i wired not only clocks, but also stack gauges, eps, and engine loom with meriva loom.
    body control module,which makes a lot of functions- previously on older vauxhalls this was made in separate modules, not like there, all in one.
    this is connector of it.
  7. #56
    Oct 2008
    meriva c20let
    Re: meriva c20let
    so, there is
    clocks+ gauges with illumination not so nice, like without, so
  8. #57
    Oct 2008
    meriva c20let
    Re: meriva c20let
    standart leds, which i can change easily on white color.
  9. #58
    Nov 2005
    Chester - North West
    Vectra C CDTI
    Re: meriva c20let
    ace work
  10. #59
    Oct 2008
    meriva c20let
    Re: meriva c20let
    Kev_G
    thanks!
    now waiting new leds, variable resistor for fuel gauge and multimeter, cause old one is dead.
    and some small updates
    next postage received from usa
    big one, full height of radiator.
  11. #60
    May 2001
    South Wales
    Nippy Cav Turbo
    Re: meriva c20let
    how did i miss this little cheeky warrior nice work slonik
  12. #61
    Sep 2003
    Harborne, Bham
    Astra Coupe 2.2
    Re: meriva c20let
    love this project
    what seats did you fit?
    Astra Coupe 2.2 16v
  13. #62
    Dec 2010
    Greece
    Corsa C
    Re: meriva c20let
    very good job slonik,
    i'm doing a similar conversion with X20xev engine in a Corsa C, maybe I will need some wiring help, what did you do with the stock ecu and immobilizer??
    I see you changed the clocks and I ll follow the same way. Do you have 2 ecus in the car?
    thank you, keep tuning
  14. #63
    Re: meriva c20let
    Love the gear linkage, top fab work. Love these gauges...
  15. #64
    Feb 2009
    Oban baby!
    Corsa B SRI
    Re: meriva c20let
    amazing project. First Meriva ive ever liked lol! keep up the good work.
