Looking ace![]()
Looking ace![]()
C16SE • Cruise Control • GSi Trip Computer • 4-2-1 Manifold • OEM+ Interior • Apex -40mm Suspension
bloody hell, you're as bad as Benn, 5 pics of an alternator!!![]()
log book came back from dvla today , only thing as will they send me a letter saying i owe x amount for the tax class change as its still taxed as a 1.0
carbon clad corsa gsi ,c20let big power build thread
http://www.migweb.co.uk/forums/proje...lots-pics.html
It's still classed as private light goods, don't worry, also it's not 2000cc is it?
Bloodly hell not having much luck at the minute mate! Improvements make sense tbh, i strongly recommend ditching that throttle bodie while you've got the car in bits and get a Vectra or Cav V6 one because that is causing your wheel spin, i have the same as you and all i did was wheel spin the first 1/8th of a mile due to not being able to feather the throttle, half throttle on them billet ones 90mm iirc is like full throttle on a standard tb, specky and a few others have since ditched them as well, mines going when i get back to the UK before anymore mapping is done. Also my V5 says 1998cc but tbh being 2000cc i think its' still in the same tax bracket
Cheers mate , not heard to many good story's about these throttles so I will prob end up changing it once I've done a few drag runs on it,
took gregs shell down to beardys today for some welding , while i was there i took my inlet there to have the throttle cable bracket reinforced as i dont want it bending
cheers beardy , owe you :thumbs::thumbs:
random corsa in there
, also spoke to steveboy today, head is back from neil ropers , just waiting on block cming back early next week and hopefully i can collect it the end of next week/weekend
Got your engine back yet
should be back tuesday mate
What are the big drum like things over the front inner arches?
Header or catch tank i would imagine!
fabricated water tanks
INSTALLING SUMMER... ████████░░░░░░░░44% DONE. Installation failed.
404 error: Season not found.
It's a chargecooler
Edit, I guess the other tanks are something to do with the chargecooler setup
Brian Sidebotham.
more oil
new ferodo ds2500 rear pads
ds2500 front pads, but the pin that holds the pads in dont fit in with them so need to ring them tomorow
new ones on left
had a mate make up some spacers for me 2 for the alt and one for the backing plate to the oilpump
cam cover back from the painters
hopefully getting engine back near weekend time
that will stop well with them pads all rounddid you find out why the head gasket didnt seal? mine had the same marks as yours, blown between cylinders and number 4 was blowing into end water gallery, so when you give it some it got hot and was pressuring the water system up. i think mine was down to head stud and nut kit not tightend to correct setting and head needed skimming.
no mate we think it wasent tightened up enough as i used sbd's tourque settings but apparentley its not enough, and the block needed decking
so engine back in over the weekend then lol
Yep if it all goes to plan, should be running it back in again next week
very nice project i will be keeping an eye out on this thread, keep up the good work
new mintex front pads turned up so fitted them
do you know how they compare to the ferodo pads?
any updats brig im sure im not the only one wondering whats happening hope its going well fella![]()
was ment to be collecting it tomorow but im busy then so collecting it thursday, spoke to the mapper and going to take a drive down there on sunday so he can lower the limater for me as i have a heavy right foot and dont want anything going wrong this time
