corsa booster
Page 1 of 25 1 2 3 4 5 6 7 8 9 10 11 ... LastLast
Results 1 to 25 of 621
Thread: corsa booster
    Sep 2003
    cumbria
    bmw 330d, corsa turbo
    corsa booster
    havent ever done a project thread on here before. mostly just read and not post up.
    anyway i have had this car for quite a few years now. since about 2005 it has been a c20let. i will post up sort of the last couple of years updates in one.
    used to have 200sx manifold and a cheap and cheerful ebay turbo which was alright indeed for the money. it lasted about 5-6k miles.
    randomly one day just snapped the end off the shaft while driving home from tesco's so decided it was time to change some stuff around.
    inlet to be replaced with some of these
    and a new turbo manifold from nortech.
    http://www.youtube.com/user/1muppetsport
    http://www.facebook.com/pages/1Muppetsport/125016194265586?sk=wall
    Sep 2003
    cumbria
    Re: corsa booster
    then started to collect some more parts for the job.
    due to the way the inlet was going to go had to move the header tank. decided to remove the abs set up from the car to give more room.
    whole car was re-piped without it which was a job i really enjoyed doing. then bought a turbo for it
    technically an ebay turbo as thats where it was purchased from.
    fits grand
    Sep 2003
    cumbria
    Re: corsa booster
    got a fitting kit, from ebay
    had the standard feed pipe modified to fit
    drilled take off from turbo into it as it dont have one
    got external wastegate and fake aeromotive ebay fuel pressure regulator. lovely stuff
    got a bit of powerflow from work for the booster screamer pipe. winner.
    this was the new location to have the header tank moved to
    Sep 2003
    cumbria
    Re: corsa booster
    starting to get a bit closer.
    wastegate and turbo fitted to manifold
    how the inlet pipe with dump valve was to be done
    cut and adjust the header tank
    header tank and inlet pipe welded to plenum
    vacuum take off fitted into each throttle
    screamer and downpipe sorted
    all done.
    Sep 2003
    cumbria
    Re: corsa booster
    had some problems with a pressure plate. and then some problems with a flywheel
    ring gear could move on it. nice and dangerous
    replaced it with one of them instead
    used the car to transport stuff around in as it made quite a good van
    twisted and snapped a drive shaft. was an mtec shaft.
    fitted equal length shafts. calibra shaft fitted both sides. no modifications to anything.
    got some alloy mounts
    was having some issues with gearlinkage so thought it was the bushes.
    replaced with nylon ones from lmf. was slightly better for a while anyway.
    got some polybushes for the front
    so fired them in
    my mate jimbo from here came round and we set about messing on with boost in gears
    Sep 2003
    cumbria
    Re: corsa booster
    well the problems i thought was the bushes in the linkage wasnt the linkage it was the engine mount.
    lovely. i was only using a 2 bolt set up and not the 3 bolt like everyone will say you are supposed to.
    decided to change the wheels from the speedlines ive owned since 2002 for some comp mo's
    shame as i liked the speedlines.
    but also like the mo's
    everything was going fine then had an oil pump failure
    sorted that out then got some 2nd hand carbon door cards
    looks great. left the back as wanted to sort it out a bit first
    Sep 2003
    cumbria
    Re: corsa booster
    chopped and fillered over the dents from removing rear seat mount bits
    ex bodywork man jimbo came round to watch and pass on helpful advice.
    primered it all up
    rattled canned like mad
    lovely stuff
    then the rear door cards were fitted
    managed to crack part of the casing from gearbox number 1 so had to borrow a spare
    went to crail for total vauxhall day.
    bust the radiator top core so twisted the ends over to stop it leaking then carried on and managed to win the shootouts which was quite nice.
    then rasied the back edge of the bonnet up, which older chavs called jimbo approved of. let the warm air out and all that.
    Sep 2003
    cumbria
    Re: corsa booster
    fitted a neverbeen sticker because i havent. and every car round here that has never left the county seems to have nurburg stickers.
    mad a temporary duct to filter using a rubber inlet donut thing from a v6 ford engine. i say temporary, its like that a year later still.
    removed down pipe and a boost pipe and heat wrapped them
    water pipe was touching boost pipe so thought it would keep it cooler seen as i had loads of heat wrap left.
    had a cardboard radio so fitted one of them ebay air temp things to it.
    tried some scene camber out buy crashing into a curb
    beam and balljoint sorted it a couple hours after crashing while at work instead of doing what i was supposed to be doing.
    some lovely astra wheels
    got mtec 6 speed linkage, 3 bolt rear mount set up and some tie bar spacers.
    this was due to gearbox number 2 having issues with the 2 bolt mount set up
    cracked the mount off the casing. luckily gearbox 1 had been repaired.
    so got fitted with new 3 bolt mount. so far had no problems since.
    Sep 2003
    cumbria
    Re: corsa booster
    was missing a bit of sideskirt since its crash so got some 2nd hand ones and got busy with the rattle cans
    got some 2nd hand gaz coilovers and a white line rear anti roll bar
    really did handle a bit better. could feel difference.
    had pic in total vauxhall from when wont the shootouts. great stuff and a handsome looking chap indeed.
    drove it about in the ice and snow for a bit over winter. it managed to get up hills that a lot of other cars couldnt. suprising really. then started getting some other bits to do things with in the coming months.
    Aug 2007
    brighton
    C20LET 5dr corsa
    Re: corsa booster
    great pics enjoyed that ha, i have the scratched to **** flexi joint must go with 3" pipe and corsa's.
    Roll on LET power....
    Sep 2003
    cumbria
    Re: corsa booster
    Sep 2003
    cumbria
    Re: corsa booster
    Sep 2003
    cumbria
    Re: corsa booster
    broke part the gear stick possibly due to being rough.
    decided to paint the rear drums, as i am quite happy to show off power drums.
    parked next to jimbo's vxr vectra
    broke the front bumper
    got some of them
    and an ebay alloy radiator
    make it very easy to take bumper off indeed.
    moved oil cooler to fit radiator in
    cut some speed holes
    hard as nails
    mate machined down the arb spacer blocks as i had ran car without it for a while but wanted ti back on again.
    attempted to clean the back box for the first time in 4 years
    my mate from work has the amazing rusty corsa. i dont get it.
    went to york for the day
    mates drank beer while i kept missing 2nd gear
    got a new oil breather filter as i lost mine.
    Sep 2003
    cumbria
    Re: corsa booster
    grand job indeed.
    Sep 2003
    cumbria
    Re: corsa booster
    and this is pretty much it for now
    its come on ok over the last couple of years. last couple of things ive done are below
    trimmed and re-fitted the door cards
    used the left overs to make a gearknob bit as i smashed the 6 speed insert a while back
    made a radio blanking bit
    moved wideband gauge to driver side heater vent
    seeing as the clock hasnt worked for ages put a blank in there aswell
    going to fit a taller and deeper intercooler to it at some point shortly.
    thanks very much for looking hope it hasnt been all that terrible. any comments feel free to say anything.
    Apr 2006
    SPAIN
    Corsa B GSI16v /Nova A TD
    Re: corsa booster
    withougth words...
    OPEL CORSA B WorldCUP GSI16v
    -----Sorry for my bad English------
    Jan 2009
    Wiltshire
    Corsa TD, DC2 ITR.
    Re: corsa booster
    Good stuff.
    Thanks for making a short version, because I can't be arsed to read all of the thread on corsasport.
    What make was that old flywheel?
    Sep 2003
    cumbria
    Re: corsa booster
    it was a fidanaza flywheel. maybe about 2-3 years old.
    Jan 2009
    Wiltshire
    Corsa TD, DC2 ITR.
    Re: corsa booster
    I throught they are meant to be good.
    Sep 2003
    cumbria
    Re: corsa booster
    i was led to believe they were as well. Ring gear was close to coming off. 2 different materials heating and cooling at different rates really. Over time just worked its way slack. Replacement is machined 1 piece so a lot better although a couple kg heavier.
    Aug 2007
    Kings Lynn
    Astra mk3/4 Turbo
    Re: corsa booster
    Nice one Chip
    Dec 2009
    Llynfi Valley
    Corsa B
    Re: corsa booster
    I am amazed by what you have done and if thats only a shortened progress thread i dread the full one ahaa. Pleasure reading that pal, you have given me some much needed motivation i no longer need to buy some off ebay ahaa. I was reading the little write up in total vauxhall magazine last night funny enough, this is throwing out over 400 bhp aint it iirc.
    By the way where did you get the grey exhaust heat wrap from, im after grey one but can only seem to find natural, white and black ??
    Oct 2008
    JHB, South Africa
    Corsa Z18XE
    Re: corsa booster
    Wow decent work there Damn!! very nice
    Z18XE CORSA B EURO PROJECT
    Re: corsa booster
    Dude as you know i've loved this car for ages, never seen a thread about it atoll, glad you've done one.
    What power do you think its running at?
    Awesome work.
  26. #25
    MIGWeb Technical Moderator Dale's Avatar
    Jul 2006
    Swindon
    Monty / Vinnie (AstraVXR)
    Re: corsa booster
    Alot easier to read over the corsa sport thread nic! Great car Hope to see it one day!
    and just for you benn, copied off corsa sport thread:
