Corsa B C14SE SRI rep
Page 8 of 8 FirstFirst 1 2 3 4 5 6 7 8
Results 176 to 190 of 190
Thread: Corsa B C14SE SRI rep
  1. #176
    Dec 2008
    Lincoln
    Disco 200TDI, CBR400RR
    Re: Corsa B C14SE SRI rep
    yeah i've looked for it many times, but never managed to find it lmao i'll text u one day if you can show us
    [SIGNATURE] [/SIGNATURE]
    Jun 2009
    Lincoln
    Corsa B 1.0 12V
    Yeah, i've finished school, so am free most days, well apart from sat as I will be too hungover to find the way
    When a man talks dirty to a woman it’s sexual harassment!
    When a woman talks dirty to a man its £3.96 a minute...
  4. #178
    Dec 2008
    Lincoln
    lmao
  5. #179
    Dec 2008
    Lincoln
    I fixed the bonnet prop yesterday,
    8 inches
    out comes the grinder
    gave them a root gap
    and set them up straight
    glued them together
    5 inches
    its now slightly too low lmao but its still a lot better
    just need to paint it when i can be bothered
  6. #180
    Nov 2009
    Ruskington, Lincolnshire
    Corsa B X20XEV
    damm that is short lmao
  7. #181
    Dec 2008
    Lincoln
    lmao it barely works as a prop, its nearly horizontal and if you lift the bonnet up it doesnt even hook on to it lmao hope its not windy
  8. #182
    Nov 2009
    Corsa B X20XEV
    lmao
    what day you going to billing?
  9. #183
    Dec 2008
    Lincoln
    friday efternoon, and leaving late sunday
  10. #184
    Dec 2008
    Lincoln
    well the bonnet prop was a total waste of time lmao i didnt even open my bonnet at billing
    but nevermind, as i bought a set of coilovers from billing, so set about fitting them today
    they are replacing lowering springs and standard dampers, which bounce and bottom out so hoping for some improvement
    rears in
    fronts in (i love not having to use spring compressors )
    but then
    the lock nut just rubs on the sidewall i reckon a 3mm wheel spacer will sort it out, but i have no money at all, so that can wait,
    so for now had to raise it 40mm from the bottom
    sits like this
    about the same height as before at the front, and a little bit lower at the back.
    but it has transformed the handling, its now noticeably firmer (how i like it) but also copes with rough roads much better as it doesnt bottom out any more, it also corners totally flat with fcuk all body roll, and it doesnt skip sideways when you push it anymore. WIN!
    that is all
  11. #185
    Jul 2006
    Sutton Coldfield
    Fiesta ZS, Clio 172
    just take off the helper spring, you'll have bags of room then.
    I saw your car but didn't see you for these camber bolts.
  12. #186
    Dec 2008
    Lincoln
    yeah sorry about that, i didn't see your FS thread sayin you would bring them till late friday, so assumed i'd left it too late
    is the helper spring not needed then? i'll whip it out when i can be bothered
  13. #187
    Jul 2006
    Sutton Coldfield
    Fiesta ZS, Clio 172
    it's just a helper spring, loads of people ditch them, it helps stop the spring unseating so don't get jumping the car and you should be fine.
  14. #188
    As said bin the helper spring. I'd get the threads on the coilover body greased or copper slipped up. Inc under the adjusters.
  15. #189
    Nov 2009
    Corsa B X20XEV
    was that one of those coilover sets that were on a stall not that far from where mig was, if so i was looking at them, saw them at pvs aswell but wasnt sure on the quality of them
  16. #190
    Dec 2008
    Lincoln
    Quote Originally Posted by Gaz86 View Post
    right, i'll get that off then, the spring should stay seated, as i'm not gonna have it loose when the cars jacked up,it will still have some preload on it
    they are covered in glear spray grease atm, might put some copper grease on though so it lasts better
    Quote Originally Posted by bluecorsab View Post
    yeah i think they were from the LMF stand. quality isnt too bad, about what you would expect for that price i suppose, few things that i dont like, such as with the bracket that fits round the hub, the corners are square, so they get in the way and stop it fitting round the hub properly but 2 seconds with the angle grinder will sort that out. also the top hole is slotted to allow for ghetto camber adjustment lmao
