Page 1 of 9 1 2 3 4 5 6 7 8 9 LastLast
Results 1 to 25 of 222
Thread: Kadett C 16v Turbo
    Dec 2008
    Grimstad Norway
    76 Kadett C - 402whp
    Kadett C 16v Turbo - New project Page 6. Supra Omega
    Hello, I am from norway, and have a 1976 Kadett c project.
    I think that you guys in england maby were interested to watch what happen in norway =)
    I wil try to write in english as good as I can, but I am not so very good I`il try my best.
    This was the first time the car was finished in 2008.
    The engine was orginal, uncept Electromotive ecu, and a MHI 16T turbo
    It was 265Whp at that time
    Some specs about the new engine:
    Engine
    Xev block , 87mm bor
    H-rods, weight-adjusted in the large end, and the total - with ARP 2000 bolts
    Wiesco pistons 8,5:1, weight-adjusted
    C20let crankshaft, polished and balanced
    Blybronse advise and carry stock
    GM Head, with new valves ++
    Turbonetics T3_T4 Turbo
    CPS Manifold
    ARP main studs, head studs, flywheel bolts and inletstuds
    Cometic 0.045 " Head gasket
    Precision Turbo1008cc
    Electromotive Tec-GT fuel injection
    Petersson Oil Catch Tank
    Tial 50mm Dump Valve
    TurboXS Boost Controler
    600x350x100mm Intercooler
    Griffin alu radiator
    SBD strap wheels in aluminum
    SPAL 16 "Cooling fan
    Earl's oil cooler
    Earl `s fuel hoses and oil hoses in AN-8 and AN-6
    Earl `s Red-anodized aluminum fuel line
    Earl's fittings on all oil and gas lines
    Aeromotive A1000 fuel pump, fuel rail and pressure regulator
    Aeromotive 11203 Low pressure pump
    Swirl-pot tank and battery in the trunk
    Dbilas adjustable vernerpullyes
    Stainless exhaust with Magna Flow exhaust pots
    Drive system:
    Getrag 265 transmission with Manta 1800 clutch-house and adapter plate
    CNC machined flywheel made to the S4 plate
    Sinter and Audi S4 pressureplate
    3.5 " shaft from "Kardangservice" in norway
    Adjustable short Spax shock absorber, and 60mm Apex lowering kit
    SellHolm power rack and pinion with 2.2 laps at the steeringwheel
    1600 front trevers with powerflex nylon bushings
    Dana 30 rear axle with locker , Suspended in 3link.
    Goodrich brake lines front and rear
    D2 6 pistons calipere with 304mm AP racing in front
    Volvo 240 Turbo brakes in the back
    Interior:
    Sparco Corsa seats
    LMS 4 point harnesses
    Instruments from GTE
    MLK tuning instrument washers 260km / h and
    Auto Meter Ultra-Lite (oil pressure, oil temp, water temp, turbo boost, AFR and 5 "Tachometer with shift light)
    Sabelt steering wheel with leather
    doorpanel, side plates behind in carbon
    Rollcage painted the same color as the car
    Rims:
    Compomotive MO 8x15 "with 195/45/R15 tires
    Some earlier pictures of parts and the car the first time it was finished.
    1008cc nozzles and som ARP bolts
    Manifold form sweeden
    Powerseteering
    304mm breake discs
    Allmost finishd, and ready to maping
    402hp and 553Nm on wheels
    And now the car will be picked in pieces again, to be painted in a different color, and be built together with attention to "finnish" and exhibition. But the car's supposed to be used =)
    I have made new 3" downpipe
    AN-4 on the turbo oil line
    Break sylinder and hydraulic break servo from BMW 745
    I also goint to use oil pump from Z20LET
    As you can see there's much difference between the oil pickup in c20let and Z20let oil pump.
    The flange on the pump, and the pipe are much more powerful on the Z20let pump.
    You can also see the inside of the pump is different
    Old C20Let
    New Z20let
    I am very curious to see how the new oil pump works, there are few that I know of that have tried this before
    Mar 2005
    newport s.wales
    nova
    Re: Kadett C 16v Turbo
    the pump will flow more a very good mod for any c20let or c20xe etc
    Built by Pete Burgess, Mapped by Dave Young
    Dec 2008
    Grimstad Norway
    Quote Originally Posted by corsakid View Post
    I hope so, but no one I have spoked with before can confirm that in other way then "I have read it on internet"
    Wales Regional Co-ordinator Tathan's Avatar
    Jun 2002
    Wrectum
    very nice.
    z20let is quite a common mod over here, the internals are machined from solid steel rather than sintered I think. Flow wise, it can supposedly flow more BUT:
    Pressure is a caused by flow
    Pressure is controlled by pressure relief valve
    You can't have more flow without more pressure, so the pressure relief valve opening point is more important than what the pump can flow. A C20LET pump can flow more than enough to maintain pressure at all engine speeds so there is no point trying to flow more.
    Benefits though:
    I'd guess that it is a bit more efficient so less drag
    it's safe for higher revs
    Mar 2005
    newport s.wales
    nova
    nice turbo though engine makes good power what bost level did it make 402bhp
    Dec 2008
    Grimstad Norway
    Quote Originally Posted by tathan View Post
    very nice.
    Ahaa
    Have previously had problems with the original C20let pumps.
    Begun to create bad press the hot engine, and takes a long time before the oil lamp goes out when the engine is cold. Scary to start to wait for almost 5 seconds before the lamp goes off. So here in Norway we have a lot problems with the original pumps. But most people here buying intensified parts from SBD, but that eather not hold forever
    Jun 2002
    Wrectum
    Yeah the SBD part is a copy of the sintered gears that is machined. Sintering is cheap and light but not particularly good. Not only does it wear more quickly, but it is very brittle and doesn't take that much to smash to pieces.
    Dec 2008
    Grimstad Norway
    At 1.83bar
    If you click here, the dyno document are in full size
    http://www.imenes.net/skann0005.jpg
    Dec 2008
    Grimstad Norway
    This is the SBD gears. The engine was running about 10 hours before this happened!
    Jun 2002
    Wrectum
    Aug 2009
    cavan, ireland
    nova,calibra,kadett
    isnt the getrag 265 from a bmw? what model? and did you swap the bellhousings over from a manta 1800 getrag 240?
    Aug 2009
    cavan, ireland
    nova,calibra,kadett
    oh yeah and by the way that car is gorgus!!!!
    Sep 2004
    GREECE
    tigra/westy
    ACE.............
    MIG.....Made In Greece LOL
    Dec 2008
    Grimstad Norway
    Quote Originally Posted by kadett kinin View Post
    It is true that you can find Getrag 265 cases in some bmw`s. For example, bmw 765, 635ci, etc.
    But these are not identical to those used by GM, (Opel monza/Senator 3.0i)
    The flange from the gearbox is not equal. On the bmw is a tightened rubber "hardy" link to the shaft, and on the opel case are the only regular splines that are slipped into cash like the getrag 240.
    To get manta 1.8 house to fit, I have made an adapter plate that sits between the house and the gearbox in 20mm aluminum
    Quote Originally Posted by TigraTurbo View Post
    ACE.............
    Thanks
    Kadett C Turbo - 402whp And 553Nm
    Dec 2008
    Grimstad Norway
    Btw. Here is a picture of the Volvo 240 rear axel I use.
    3.71:1 in gearing and diffrential breake from sellholm in sweeden.
    I have build it to 4x100mm and welded on some mounting bracketst that fit in the orginale boltholes in the flor.
    Dec 2008
    Grimstad Norway
    And here is som pictures of the hole car and the brakes mounted.
    The car will be painted in LY3D (Vw tornadorot)
    The car will be painted below, inside and outside.
    Wheels and the rollcage and everything else like suspension becomes black matt
    Aug 2009
    cavan, ireland
    nova,calibra,kadett
    was the imput shaft not to short? and did you need to uprate the gears to take that power?
    Sorry for all the questions.lmao
    Dec 2008
    Grimstad Norway
    Questions is just fun =) I am happy to answear
    No, the input shaft is not to short
    I use the orginal gears with no problems.
    It's probably have something to do with the weight of the car.
    I have no grip on the backwheels on the asphalt before the 5. gear (that`s with regular street tire, with slicks it helps alot )
    Aug 2009
    cavan, ireland
    nova,calibra,kadett
    thanks for the answeres!
    Dec 2008
    Grimstad Norway
    You are welcome, I am happy to help
    London, United Kingdom
    78 Kadett C
    Oh my, that is awesome
    That engine bay is porn aswell
    78 Kadett C 2.0 8v turbo
    Nov 2004
    Oslo, Norway
    Quote Originally Posted by Kadett C20let View Post
    no wonder when you see the how the axle is hung
    rc
    rc is offline
    MIGClub Member rc's Avatar
    Jan 2007
    Felixstowe, suffolk!
    359.9bhp astra
    Wow now thats impressive 553Nm through the rear wheels, scary
    Apr 2007
    Hull
    Mk2 cav
    Thats one wicked project.How does the back axle handle the power with it being mounted like that? Ive got a chevette estate im planning on putting a saab turbo lump in and my piazza axle is alot like yours.Might have a go mounting it the same as you if it works well.
  26. #25
    Dec 2008
    Grimstad Norway
    Quote Originally Posted by djivesp View Post
    Thanks =)
    Quote Originally Posted by Classic View Post
    Høhø
    Quote Originally Posted by rc View Post
    No, It`s not scary, its fun
    Quote Originally Posted by kwkmanta View Post
    Well, it's far from optimally mounted, but it works fine, and I use the original mounting points on the floor, and saves a lot of work that way.
    So I use it as long as it lasts
    When it breaks, it will be 4-link
  1. 27-01-2012, 22:23
  2. 17-01-2012, 21:50
  3. 24-12-2011, 18:27
  4. 10-12-2011, 22:13
  5. 26-10-2011, 16:16
  6. 23-10-2011, 21:43
  7. 21-10-2011, 21:15
  8. 14-10-2011, 06:39
  9. 21-09-2011, 02:22
  10. 15-09-2011, 06:44
  11. 18-08-2011, 11:26
  12. 15-08-2011, 10:19
  13. 24-07-2011, 23:48
  14. 24-07-2011, 20:56
  15. 20-07-2011, 19:46
  16. 03-07-2011, 21:05
  17. 10-04-2011, 21:58
  18. 28-02-2011, 15:57
  19. 21-01-2011, 13:26
  20. 18-12-2010, 22:17
  21. 18-12-2010, 20:14
  22. 26-09-2010, 11:32
  23. 05-09-2010, 19:06
  24. 18-07-2010, 15:53
  25. 13-07-2010, 20:38
  26. 29-06-2010, 18:46
  27. 28-05-2010, 15:06
  28. 13-05-2010, 12:59
  29. 10-04-2010, 19:04
  30. 03-04-2010, 07:58
  31. 12-03-2010, 21:24
  32. 04-03-2010, 23:27
