Corsa B Z18XE
Results 1 to 11 of 11
Thread: Corsa B Z18XE
    Oct 2009
    Hungary/Germany
    Corsa c18se, Zafira B OPC
    Corsa B Z18XE
    Hi!
    This is my little car. It was 1.4 si before the conversion.
    The original engine.
    Parts:
    Electric throttle sensor from vectra B, Brakes 256x24, wiring loom, exhaust tube from the cat to middlebox, 50,5->42 tube for the original exhaust, fuel pressure regulator, and my F15CR418 gearbox with wide 5 gear.
    Electric throttle body sensor
    The engine, with new piston rings.
    It's me
    A few days later
    The electric throttle sensor, and the original throttle cable.
    Slim fan.
    Dec 2009
    Llynfi Valley
    Corsa B
    Re: Corsa B Z18XE
    Very nice clean car that. What was the conversion like, easy or a pain. Is the engine running yet ??
    Whats next for it ??
    Oct 2009
    Hungary/Germany
    Thread Starter
    Re: Corsa B Z18XE
    The mechanic was easy, just from the pipe of the heater I had to cut 1cm. The inlet manifold is too big, and the original radiator fan was too big.
    With the electric i had some problems. By the first start of the engine was the camshaft sensor bad, we have changed, then the immo was wrong. I have bought a new immochip, my man has programed, and that was the all problem.
    The wiring is fast the same as the x18xe1, just 6 wires + to the electronic throttle.
    Plans are for the next 2 months 50,5mm exhaust system without middlebox, and a new inlet manifold. I bought x16xe inlet manifold and z18xe manifold, cut both. I will weld them, and will make mantzel style inlet box.
    Future plan is new ARB, and bushes.
  5. Remove Advertisements
    Oct 2009
    Hungary/Germany
    Thread Starter
    Re: Corsa B Z18XE
    Hi!
    Some new stuff:
    I fitted yesterday eibach ARB-s.
    The sump from x16xe.
  7. #5
    Oct 2004
    Oban - West Scotland
    Astra G/Nova TB
    Re: Corsa B Z18XE
    Very cool project
  8. #6
    Oct 2008
    JHB, South Africa
    Corsa Z18XE
    Re: Corsa B Z18XE
    Cool another flame red Z18XE corsa
    Mk4 Astra Z20LET
  9. #7
    Oct 2009
    Hungary/Germany
    Thread Starter
    Re: Corsa B Z18XE
    I have some problems with the electronic.
    The piston 3 will not run. I have changed the injector, then the coil pack, checkd the wiring, and last the ecu.
    The Z18XE ecu is a big ****.
    The whole electronic is in some gel, and the wires are very thin.
    And here is the problem, the wire is cracked by the soldering.
  10. #8
    Sep 2010
    Re: Corsa B Z18XE
    Please help i have a zafira with z18xe engine. i have problem with ecu too. how to open ecu and how to remove gel and insert gel again. and how to close case when soder the conntacts. thank you
  11. #9
    Dec 2003
    staffordshire
    Astra G & Nova Mk1
    Re: Corsa B Z18XE
    cripes :-o will need a needle n thread there eh?!
  12. #10
    Sep 2010
    Re: Corsa B Z18XE
    Plese help me. r u know how to open ecu
  13. #11
    Oct 2009
    Hungary/Germany
    Thread Starter
    Re: Corsa B Z18XE
    I have new exhaust manifold. Modified c20xe manifold. The shape of the pipes at the flange are the same as the exhaust ports. Between the pipe 1 and 4 i cut the welding, then was easyer to pull together. The height was 2cm bigger, i cut the pipes and weld togeather. My weldings are not perfect, that was my first MIG welding.
  1. 12-05-2017, 06:31
  2. 12-05-2017, 06:24
  3. 11-01-2016, 06:38
  4. 01-06-2015, 18:10
  5. 20-09-2014, 05:51
  6. 31-08-2014, 07:26
  7. 21-02-2014, 04:59
  8. 25-01-2014, 18:00
  9. 20-10-2013, 16:09
  10. 26-03-2013, 19:56
  11. 25-02-2013, 19:42
  12. 08-01-2013, 15:15
  13. 16-06-2012, 20:00
  14. 16-06-2012, 17:38
  15. 10-05-2012, 08:26
  16. 19-02-2012, 16:38
  17. 19-10-2011, 22:22
  18. 29-03-2011, 16:52
  19. 17-02-2011, 05:30
  20. 23-01-2011, 17:53
  21. 17-07-2010, 09:26
  22. 12-07-2010, 05:41
  23. 10-07-2010, 00:49
  24. 11-05-2010, 22:49
  25. 22-02-2010, 12:36
