Corsa B X20XEV - My First Project
Page 2 of 26 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 ... LastLast
Results 26 to 50 of 645
Thread: Corsa B X20XEV - My First Project
  1. #26
    Nov 2009
    Ruskington, Lincolnshire
    Corsa B X20XEV
    Re: Corsa B X20XEV - My First Project
    yh this one does its got the bloody pot type on it which is quite heavy but will get changed at some point for a flat type if i can find one for a decent price
    Sep 2005
    Sydney, NSW
    Excellent project mate.
    I am going to do an X20XEV conversion when i return to the UK.
    keep up the good work. Subscribed!
  4. #28
    Dec 2009
    Llynfi Valley
    Corsa B
    What is the difference in weight then between the pot and flat flywheel. What engines do the flats come in, will be much better getting a lighter flywheel it will pick up a lot lot quicker mate.
  5. #29
    Nov 2008
    South Africa
    Corsa
    Did a x18xe on my car a year ago these ecotec motors is a dream still running strong
  6. #30
    Nov 2009
    Corsa B X20XEV
    thanks for the nice comments,
    liam1805- the flat type flywheel come on the 2 litre 8 valve engines and its a few kilo's difference in weight between the two i think
    balsak- yh i saw your project log a while back and enjoyed the read, it made me want to do mine
    johnhara1- cheers mate
  7. #31
    Nov 2008
    South Africa
    Corsa
    Its a pleasure bud, as for cooling i would suggest getting a radiator from a corsa b pick up dont know if u have them there by you its the same
    size as the normal corsa fan just twice as thick and it sit alot more forward into your bumper making it ideal for clearing the branches and if
    u wana turbo later
  8. #32
    Nov 2009
    Corsa B X20XEV
    no mate we havent got corsa pickups over here but i would love to have one or even a corsa estate at the moment its going to be running with the standard radiator as i have heard they are sufficient for what i want, at some point i may upgrade it too a diesel radiator as they are a bit bigger
  9. #33
    Dec 2009
    Llynfi Valley
    Corsa B
    I would get a 8v flywheel for sure then, it will pick up much quicker, a few kilos dont seem much but it means a lot to the engine haa. Ive heared the normal radiators are capable of a lot more anyway. My mate for instance runs his 1.4 radiator with his c20xe and its never been a problem for him mate.
    I hate the way the radiators sit on the angle, is there a way to slot it under the slam panel then as id be doing that for sure.
    Liam.
  10. #34
    Nov 2009
    Corsa B X20XEV
    yh will get a flat type flywheel if i can find one at a decent price, not overly important at the minute but would be nice
  11. #35
    Nov 2009
    Corsa B X20XEV
    well the mounting is finally here!! thanks CEMEX!!
    so can get some more work done now, so expect some more updates soon
  12. #36
    Dec 2009
    Llynfi Valley
    Corsa B
    Finally haa. Get cracking with it now and update us mate. You know with the x20xev engine mate isit possible to use a ECU off a c20xe to eliminate immobiliser problems.
    I know its been done with a x18xe using a c18xe ECU to eliminate it.
  13. #37
    Nov 2009
    Corsa B X20XEV
    ive not known it too be done mate on a x20xev, not hard too do anyways, just use the imobiliser ring, ecu and chip from a vectra......
  14. #38
    Jan 2006
    liverpool
    a p.c with wheels
    good project mate, will be subscribing to this one as im planning on doing my own xev conversion this spring. What belt set up are you going to use? I want to try and keep the wide belt set up if i can as i want to keep the air conditioning on my conversion :S.
    If i was you i would definantly fit the 8v flywheel + clutch set up before you fit it in the car. Will be good peace of mind to know you got a new clutch in too as its gearbox out job to replace.
    Want good quality mirror finish smoked rear lights for you car? drop me a pm.
  15. #39
    Dec 2009
    Llynfi Valley
    Corsa B
    Yehha, just wondered if it was the same on these engines. So whats the crack now then, going to get the engine in yehh ??
  16. #40
    Nov 2009
    Corsa B X20XEV
    cheekyalex - cheers mate, im not sure what belt setup im going to be running yet but will propably be a wide belt setup as im trying to keep my hydralic powersteering what car you going to be doing yours on? im a bit low on money at the moment so dont know if i can afford a 8v flywheel/clutch setup just yet, but will put one on at some point, my main objective is to get it running at the minute then do that sort of thing later, not to bothered about taking it too bits again
    liam1805 - yh the plan is too get the engine in once i have sorted out a few little bits like fuel lines etc
  17. #41
    Dec 2009
    Llynfi Valley
    Corsa B
    You love the potch just like me haa. Just get it in and firing for now, then go from there. Money is a struggle as im in the same boat. Get loads of pics mate. Be click happy haa.
  18. #42
    Nov 2009
    Corsa B X20XEV
    yh ok mate will do
  19. #43
    Nov 2008
    Boolarra VIC Oz
    1995 Holden Commodore
    alright mate, i fitted a C18XE to a mates corsa sport last year. you'll need to use the single v pulley off a carlton 2.0 c20ne, and its alternator and brackets, just swap the top bracket (the slide one) upside down. as for the c20xe ecu, it wont fit or run the x20xev as the plugs are different. i used the corsa heater pipes, trimmed a bit, and an astra ecotec rad top hose and the corsa bottom one. if you get a sport with ac coolant radiator its the biggest and best for the job. wiring the engine is easy as its a case of snipping the black plug off the old 1.4 loom and soldering it to the xev loom. if you get stuck mate, im only in hull so close nuff to help.
    rob
    Sideways through the forest.
    www.allcorsa.co.uk
    touching cloth since 1995
  20. #44
    Jan 2006
    liverpool
    a p.c with wheels
    Im fitting mine to a 16v corsa sport. The plan is to make a bracket for the aircon pump and ditch the hydraulic power steering for an epas system. If you want to keep your 'wet' power steering then there is a readily availible bracket for using your power steering pump for xe conversions, im guessing it will fit the xev too but not 100% on that.
    As the cluch was already knackerd on mine it made sense to get an 8v flywheel as new clutches are about £20 cheaper for the 8v ,
  21. #45
    Nov 2009
    Corsa B X20XEV
    Quote Originally Posted by saabturbonova View Post
    rob
    cheers mate, its just the powersteering thats gonna stump me a bit lmao is there anyway i can keep the wide belt setup cus dont wanna loose the 110amp alternator lmao plus im a bit low on funds yh im using a x20xev ecu, transponder and chip from a vectra, it was a mate who wanted to know if it would run on a xe ecu but i didnt think it would your welcome to come and help me whenever you like
  22. #46
    Nov 2009
    Corsa B X20XEV
    Quote Originally Posted by cheekyalex View Post
    sounds like a good idea mate retaining your aircon, my original idea was to use epas but i though i might aswell retain the 'wet' system instead of ripping it all out, more hassle in my eyes changing it all
    yh ive seen them conversion brackets, i dont see any reason why it shouldnt fit, only thing is i dont know where it is suppose to me mounted lmao
  23. #47
    Dec 2009
    tiptree (essex)
    corsa b
    looks sweet m8
  24. #48
    Nov 2009
    Corsa B X20XEV
    Quote Originally Posted by jacko1992 View Post
    looks sweet m8
    cheers mate, its slowely getting there
  25. #49
    Nov 2008
    South Africa
    Corsa
    U can run the wide belt setup in a corsa u just have to hammer or cut away part of your frame skin or smack it with a hammer, xe and xev blocks are the same minor differences so you will be able to use the bracket
  26. #50
    Nov 2008
    Boolarra VIC Oz
    Quote Originally Posted by bluecorsab View Post
    its easier to use the single v setup, as tensioning the pas and alt setup is tricky due to the corsa conversion mount. if you can find one, a carlton cdx with ac and pas will have either a 90 amp or 110 amp alt. if you go for epas, and run just tha alt on multi v, you need to alter your chassis leg where the alt is, as it touches. hammer or notch ala nova conversions. the pas mount is the same as the xe one that you could get from chris astley. then just use the single v pump. it mounts below the cambelt end engine mount. clean the holes with a tap and die, and use threadlock on the bolts
    the corsa hoses will fit it with a little persuasion.
    www.allcorsa.co.uk
  1. 06-03-2012, 18:31
  2. 17-11-2011, 13:12
  3. 01-10-2011, 17:08
  4. 24-09-2011, 11:12
  5. 07-12-2010, 20:47
  6. 24-10-2010, 20:42
  7. 13-10-2010, 18:01
  8. 10-10-2010, 20:31
  9. 29-09-2010, 19:41
  10. 30-08-2010, 01:37
  11. >
    Refback This thread
    25-08-2010, 11:30
  12. 23-07-2010, 15:19
  13. -
    Refback This thread
    01-07-2010, 06:23
  14. 21-06-2010, 18:39
  15. 20-06-2010, 13:26
  16. 09-06-2010, 03:54
  17. 09-06-2010, 03:51
  18. 06-06-2010, 22:07
  19. 06-06-2010, 19:03
  20. 31-05-2010, 14:04
  21. 07-05-2010, 15:52
