red top conversion,goin for euro look
Page 5 of 5 FirstFirst 1 2 3 4 5
Results 101 to 108 of 108
Thread: red top conversion,goin for euro look
  1. #101
    Jan 2010
    Weston-super-Mare
    XE Corsa B,ratty 1.2 nova
    Re: red top conversion,goin for euro look
    *update*
    as you may of guessed from my other thread,i am having troubles gettin an engine management light,not sure what it is,so to be on
    the safe side i am buying a new loom and ecu,preferably one withlout traction control tps and abs.hopefully this will cure the problem and i can get her on the road asap
    Apr 2010
    northants
    astra 2.0 turbo
    Engine looks ace in the corsa mate cool work
  4. #103
    Jan 2010
    Weston-super-Mare
    fitted my new momo steering wheel last night,looks miles better then the 2 spoke standard one! also the white dash has got to go! looks so chavvy,regret doin it lol
    then after work today finished off my cold air feed and put the pressed plates on
  5. #104
    Jan 2010
    Weston-super-Mare
    changed the ecu and loom for a better one,had it all working fine,had a spark and a management light,then today,no management or spark :S any ideas?
  6. #105
    Jan 2010
    Weston-super-Mare
    made this whilst at work
    got to sand it back a bit more then will be getting it covered in vinyl
  7. #106
    Apr 2008
    dublin ireland
    xe/let corsas vectra gsi
    pretty cool project different from the normal gsi kit and speedlines anyway,what front strut brac you using with the 20xe as my old brace doesnt fit anymore and cant seem to find one that will fit
  8. #107
    Jan 2010
    Weston-super-Mare
    cheers pal.yeah my mate had the same problem,he had an 'S' shaped one,mines just a bog standard one off the bay mate,need an 'n' shaped one
  9. #108
    Jan 2010
    Weston-super-Mare
    im still alive! but unfortunatly the car isnt,i had it on the road for 2 days untill it started leaking oil from the rocker and eventually started knocking like a goodun,it is now back in the garage with the sump off to see what sort of damage ive done.i will keep u all posted
    whos giving me a nova saloon then?
