Been braving the cold again, weve got about 3" of snow up here its freezing!!
Got the passenger side inner wing repaired and got the wing on after doing a few repairs to it. Ive got all the stonechip done underneath, Im waiting on some rose joints to come so I can get the axle in...then its on to bodywork....
As good as new![]()
Got the car turned over again so I could paint underneath, also made a tower for the panhard rod. Im waiting in some rod ends to come so I can make the panhard rod and the top arms for the axle...
Its good to get a bit of paint on the car, seems like progress is being made!!!![]()
Scott
Is that a lighter shade? Is the rest of it gonna be like that?
Yup, its electric blue, the whole car will be done in it, inside and out. I didnt really like the original colour, this suits it a bit better I think.
Scott
Yeah looks good, my mum had a Manta B in a colour like that, with a massive blitz sticker on the bonnet![]()
Bit more progress, Ive managed to get the car turned again, fitted the rear axle and made sure my wheels fitted 8) Ive set the diff so the nose points up slightly as you can get strange vibrations if the prop runs straight. Ive also managed to get the engine bay in paint after loads of prep to smooth out the repairs. I did think about welding up all the holes and hiding all the wiring and brake lines but I cant be bothered with the hassle to be honest....
the paint has a fair bit of orange peel (not enough thinners I think) but its nothing some wet and dry and G3 wont sort.....![]()
Nice job......
You know you want to hide those wires though.![]()
MK III Astra 2.0l Turbo Cabriolet - Landrover Discovery
Skoda Otavia 2.0 Diesel Elegance
BMW 330 Ci Sport Convertible
Dude that looks good.
looking really good, Im looking forward to seeing how the colour looks on the outside of the shell.
Ive had another go at painting the bay today as I wasnt happy with the finish I got yesterday....Painting can be a right pain!!!
Theres a few bits of dust in it but the finish is much better this time.![]()
Lovely.
Smooth![]()
Ive got the shell painted now, cant get photobucket to work so Ill post pics when it stops being a spaz.....
heres some piccies, its turned out not to bad for a driveway job!!!
Lovely![]()
The cake is a lie :(
Superb!
They're there, in their room.
I saw your old green one for sale on Ebay the other week.
Looks good.
Looks like an amazing job for out on a drive way. You'll be tellling us you did it with rattle cans next lol.
Cheers guys, haha no rattle cans. Ive got a small 2.5HP compressor and a cheapo ebay gun, I sprayed it with 2 pack. Its come out good, the trick seems to be get as much paint on as you can then flat it off after and polish for a shine.
Its been loads of work but its turned out well. Still got the boot bonnet and doors to do though!!
Scott
Not much of an update this time, been busy with other distractions!! Got the tank painted. It was a nightmare getting the gunk off, it was really thick in places...Got the hubs and discs on too. They are Mk2 escort hubs machined on the back with 2.8 Capri discs. Not sure what to do for calipers yet but Ive got a few ideas...![]()
Ive started on the engine and box aswell. Made some engine mounts from 3mm plate (Ill weld these to the front cross member when the weather gets better, dont have enough room to do it in the garage.)The bottom end is built with new rings, shells oil pump and water pump. I didnt take anypics of this, Ill get some next time Im out. I put the bellhousing on my gearbox only to remember that its a 2.8 box, not a normal one which means the input shaft is longer.So out comes the grinder to make some mods!! I took about 15mm off the end and 13mm off the splines, then used a dti so make sure it wasnt too wobbly.....
Scott
