dewismotorsport's C20LET Corsa gsi
Page 23 of 26 FirstFirst ... 13 14 15 16 17 18 19 20 21 22 23 24 25 26 LastLast
Results 551 to 575 of 648
Thread: dewismotorsport's C20LET Corsa gsi
  1. #551
    Oct 2003
    Nr St Ives, Cambs
    Pug 309 Cosworth
    Re: dewismotorsport's C20LET Corsa gsi
    Looking good mate.
    The pic I sent you the other night didn't really show how the Corsa was done but this one may help
    If your running wide seats you will need to move the wheel over to centre everything, even with the seat bars mounted like that the steering wheel still sat on the left and even now its not perfect, that said their not perfect from the factory either !
    The column was shifted over nearly 2 inches and extended before the knuckle that joins onto the rack, it was also dropped a few inches which gives a much nicer feel if your running the seat low.
    Nice seats those, I have one in the Pug but sadly can't get a wide version in the passenger compartment or I'd have 2 !
    MIGWeb Lord
    Nov 2009
    Coventry & Plymouth
    Corsa C20LET/Astra coupe
    Yeah that's a better pic mate and yeah you have removed the part I was on about, but I'm also gonna remove the front part that you've cut down, I haven't extended my colloum like you though, and my seats aren't the wides so hopefully that will buy me an inch or so
  4. #553
    MIGWeb Lord
    Nov 2009
    Coventry & Plymouth
    Also forgot to mention I bagged all the tar up and weighed it and it is 7kg's which is quite a lot tbh
  5. #554
    Oct 2003
    Nr St Ives, Cambs
    Pug 309 Cosworth
    With normal width seats you shouldn't have such a problem. It was quite bad how far out the steering wheel was out with the seat tight up against the tunnel, not really sure how anyone could put up with that !
  6. #555
    rc
    rc is offline
    MIGClub Member rc's Avatar
    Jan 2007
    Felixstowe, suffolk!
    359.9bhp astra
    they look a bit too big for a corsa really? Selling them?
  7. #556
    MIGWeb Lord
    Nov 2009
    Coventry & Plymouth
    Quote Originally Posted by jonlem View Post
    Yeah from first looks it doesn't seem to be too far off but I have seen cars where the steering wheel is way out and could imagine it would feel horrible to drive
    Quote Originally Posted by rc View Post
    no chance mate
  8. #557
    Aug 2004
    glasgow
    astra 4x4 C20LET TURBO, v
    Great seats mate. Keep up the good work.
  9. #558
    MIGWeb Lord
    Nov 2009
    Coventry & Plymouth
    Tonight's efforts were to get the standard seat mounts out to allow me extra space to sit the seats perfect, after what felt like a lifetime drilling out spot welds it now looks like this
    Also drilled out the rear seat mounts as well
    Plus side I've shifted 10kg of weight but down side I slipped with the drill and punctured one of my 888's :cry: Will get that repaired next week
  10. #559
    Aug 2004
    glasgow
    I know how you feel bout drilling out spot welds they are a pain in the arse.
  11. #560
    MIGWeb Lord
    Nov 2009
    Coventry & Plymouth
    Quote Originally Posted by gazturbo View Post
    Yeah pain in the arse tbh needed to be done though, wanted to remove them to get the seats in better and the weight saving was a bonus, hoping to get the car down to around the 850-860kg mark if I can, and with the planned 450bhp it should be fairly nippy
  12. #561
    MIGWeb Lord
    Nov 2009
    Coventry & Plymouth
    Got the white spirts out and removed remaining tar and gave it a good clean out before having the rubbish job of having to weld up all the drilled out spot weld holes, seemed to take forever :cry:
    Then decided while I had the welder out to seam weld inside
    I then cut out a load of discs and removed the rubber bungs in the floor and welded them up as well and ground all welds back to floor level
    Almost done with the floor now just need to cut out a few small patches of rust around the rear seat floor mount, must be a water trap so while I'm at it I'll fully cut that out and patch it up
    Bought myself a epas colloum and another rack came as a package so will keep rack as a spare as my original one is better but I will swap the steering rods over as they are practically new
  13. #562
    Aug 2004
    glasgow
    Great work mate, That a corsa b column?
  14. #563
    Aug 2007
    brighton
    C20LET 5dr corsa
    best mod i done upgrading to epas!! no pipes or **** in the bay
    Roll on LET power....
  15. #564
    Sep 2011
    essex
    Astra sri
    i cant wait till you weigh this, looks such a great project. i have a similar corsa project and am also trying to remove as much weight as possible. do you think you could hit 850kg?
  16. #565
    MIGWeb Lord
    Nov 2009
    Coventry & Plymouth
    Cheers, and yeah corsa b column
    Quote Originally Posted by dearing5 View Post
    I don't have any power steering at the mo, love the feel of it on the move but it's a ballache trying to park etc as the steering is so heavy with sticky tyres
    Quote Originally Posted by redtopnutta View Post
    There is more weight to be removed if I took dash and blower box etc out but don't want to as I'd like to still have some luxurys tbh, my friend got his down to 860kg without gutting the doors so I'd like to think I could get 850kg's but won't be too upset if I don't, I have a few more bits to remove like the sunroof and spare wheel well, I'm hopefully getting GRP doors and maybe a roof skin as well
  17. #566
    Jan 2008
    Lincolnshire
    Thought I best have a post, can't believe the amount of skill in making your own inlets and fabrication, I know where I will be coming for tig welding. Do you have a project thread for the corsa that's getting the xe?
  18. #567
    MIGWeb Lord
    Nov 2009
    Coventry & Plymouth
    Quote Originally Posted by jay26 View Post
    Cheers mate, yeah they've developed over time, and what XE corsa project
  19. #568
    Dec 2008
    torquay
    vauxhall nova
    Any update's?
  20. #569
    MIGWeb Lord
    Nov 2009
    Coventry & Plymouth
    Quote Originally Posted by basil11 View Post
    Any update's?
    Afraid not mate, i'm currently working in Norway at the minute so won't be back until the end of March so will be full steam ahead when i'm back as i want to do spring action day in it, and want it all singing all dancing by PVS/TOTB
  21. #570
    Sep 2010
    East Lothian
    nova
    Ive just sat and read this whole thread and WOW, fair play mate thats mental. Can you pm me the NSN for the exhaust wrap if you still have it please
  22. #571
    MIGWeb Lord
    Nov 2009
    Coventry & Plymouth
    Thank you very much Must of took you a while, I don't have it to hand as i'm in Norway at the moment but if you search on SCOC disk for muffler wrap it comes up as it's used on the mastiffs
  23. #572
    MIGWeb Lord
    Nov 2009
    Coventry & Plymouth
    Well been away for the last two months with work so thought I'd best get my arse in gear and get something done so I whipped the dash out ready to be sent off for flocking, going to remove the rest of the sound deadening and tidy up the wires while I'm at it
    And removed my coilovers front and rear so that AVO can re furb them
    Lowered her back down to see what she looked like with no suspension msl:
    Wish I'd had more time before I left to get this lot all sent off as it would of been done by now but that's life I suppose :cry:
    Got a list now off stuff to buy so going to be buying it all over the next few days
  24. #573
    Dec 2005
    Aldershot hampshire
    Agila c20let in making
    Happy days, good to see progress is being made mate!
    Save the trees, wipe your ass with a owl!
  25. #574
    MIGWeb Lord
    Nov 2009
    Coventry & Plymouth
    Track day season is coming round stupidly fast and with me being away from the car now for nearly 3 months I need to get a bloody move on so have made a list of parts I need to finish the car to where I will be happy with for now
    First on the list was a EPAS controller so once I get the colloum and rack in I can set it up to how I want
    A reducer pipe for when I fit the V6 throttle bodie
    Three new silencers with the back box now a lot larger so I can quieten it down as without the super trap on its 105db :cry: And I want it bellow 100db so I can safely pass the track day noise regulations
    Bought myself some Reyland bells and discs so I can have spares and will no doubt start making 4 pot brake kits when I get more time
    I sent my AVO coilovers off for a re furb as they had started leaking and AVO did a rapid job of re furbing them (returned to me within a week) they have had all new pistons and seals, they even gave me spare collars and new bump stops and new top mounts for the rears, only thing that isn't new is the shock body which I will give a new coat of paint once back at work
    And finally new 300lb rear springs to help me get the rear to how I like it
    Plenty more bits on the way, it's like Xmas for me msl:
  26. #575
    Aug 2011
    blackburn
    mk2 astra sri 1988
    looking very good so far hopefully goes well for you then you can get out in it
