dewismotorsport's C20LET Corsa gsi
Page 21 of 40 FirstFirst ... 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 ... LastLast
Results 501 to 525 of 994
Thread: dewismotorsport's C20LET Corsa gsi
  1. #501
    MIGWeb Lord
    Nov 2009
    Coventry & Poole
    Corsa C20LET/Astra coupe
    Re: dewismotorsport's C20LET Corsa gsi
    Quote Originally Posted by Dale View Post
    looking good adam, is that the same fuel rail i'm using???
    No mate yours is different, need your address as Fenny hasn't got back to me with it yet so PM me it
    Apr 2002
    Southwest
    Like its stolen
    Quote Originally Posted by dewismotorsport View Post
    Yes mate you fancy it? I still have a lot to do and little time but am determined to make it
    I was there a couple of weeks ago in the corsa anyway, so probably a bit soon to go back with it again as will be a bit sameish and the nova isnt going to be in use till next year sometime, but if you are going i'll probably pop along and passenger ride with you and pitcrew for you if you like, and maybe we can use the lunch break to do a bit more mapping possibly too.
  4. #503
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    for the fuel rail o rings, spray them with carb cleaner before you fit the rail on them, it will shrink them momentarily and help them fit without being damaged
    SHoNkyOpELs.de
  5. #504
    MIGClub Member TigraTurbo's Avatar
    Sep 2004
    Crete
    tigra/LET westfield
    out of curiosity,wouldnt the carb cleaner destroy the o rings faster?
    MIG.....Made In Greece LOL
  6. #505
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    not if they are the correct fuel resistant ones no
    SHoNkyOpELs.de
  7. #506
    MIGWeb Lord
    Nov 2009
    Coventry & Poole
    Quote Originally Posted by chip View Post
    I'll let you know mate as still have brake bells to machine yet, so touch and go
    And good tip Lee I've just been using spit lmao
    Car is now up and running and not leaking so big relief
  8. #507
    Sep 2008
    Auckland, New Zealan
    Chevette XE, Calibra
    I just use a drop or two of engine oil - CRC if I can't find the damned oil can.
  9. #508
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    carb cleaner shrinks the o rings momentarily when it evaporates off though, hence why it makes it easier, plus its easier to apply than oil lmao
    SHoNkyOpELs.de
  10. #509
    MIGWeb Lord
    Nov 2009
    Coventry & Poole
    Made a start on making my new bells got them on the lathe and started turning down the edge lip to sit inside my disc, have done this as an interference fit so it's snug as when the alloy gets hot with braking it will expand and clamp itself to the disc adding etc strength
    Then machined the middle out to fit my hub
    I then used a spacer which acted as a template for the PCD for the wheel bolts/studs
    And drilled
    Once that was done I could fit it on and attach disc and work out what offset I need so that my calipers can fit over, so removed material from the inside to bring it in closer
    Have managed to get one almost done but it's just a slow process as you can only remove so much material at a time :cry:
    Also found out I need the slim head bolts to join the bells to the disc which I don't have so need to contact my nearest AP racing supplier to get some which I think is Roger Clark so will have a good nose around the gob stopper while I'm there
  11. #510
    Oct 2010
    Covas/Tabua - Portugal
    tigra A 1.6 16v
    awsome build this man!! liking the lathe work too, wish i had a lathe.....
    LET THE THRILL OF SPEEDOVERCOME YOUR FEAR OF DEATH
  12. #511
    Aug 2007
    brighton
    C20LET 5dr corsa
    That's well good, love it.
    Roll on LET power....
  13. #512
    MIGWeb Lord
    Nov 2009
    Coventry & Poole
    Quote Originally Posted by dearing5 View Post
    Quote Originally Posted by st3vo View Post
    Cheers guys! Yeah having a lathe is very handy can make all sorts on it and save a fortune not having to pay company's to do it for you
  14. #513
    Oct 2010
    tigra A 1.6 16v
    i used to have a small lathe in the UK but me dad sold it before we moved to Portugal :'(
  15. #514
    MIGWeb Lord
    Nov 2009
    Coventry & Poole
    Shame about that mate.
    Also forgot to mention have spoke to the new editor of Total Vauxhall magazine and have arranged to have a feature done after the winter when I have the cage and seats in etc so chuffed with that makes all the hard work and set backs worth while
  16. #515
    Jan 2008
    scotland
    Corsa Turbo
    can not wait to see that feature mate,well deserved,all your hard work is starting to pay off ,the thing i like most is the fact you make everything yourself,keep up the good work mate
  17. #516
    Feb 2006
    Berkshire
    Jenvey 1.6 Track Nova
    New parts all ordered gonna get them all fitted up this week at work and hopefully car will be back up and running correctly
    SBD nylon relief valve kit at a pull your pants down price of £70 delivered
    Got two stickers with it so gotta be worth it
    WTF! i spent 2k with them and dint get a bloody sticker :-( screwing lol
  18. #517
    MIGWeb Lord
    Nov 2009
    Coventry & Poole
    Quote Originally Posted by BLAIRC20LET View Post
    Cheers I just hate paying for stuff i know i can make myself saves me a fortune
    Quote Originally Posted by novaboyopr View Post
    Well i got two so ones yours for £1k lmao
  19. #518
    Oct 2010
    tigra A 1.6 16v
    its not too bad, got a machine shop 2 minutes away from us now an they have like 10 lathes in different sizes, head skimmer, crank grinder, CNC machine an a few other bits n bobs, so i know where i'll be gettin the tigra's new engine fettled do they sell TV in Portugal? would love to read your feature (shame they couldn't fit this whole thread in there!!)
  20. #519
    MIGWeb Lord
    Nov 2009
    Coventry & Poole
    Happy days I'd be in heaven there with all them machines! And not sure on a paper copy but you can now download it from the news stand on iTunes
  21. #520
    Oct 2010
    tigra A 1.6 16v
    SWEEEEEEET, i'll have to remember to get some pics to drool over when i'm next there, just got the engine on the bench now to start stripping so will be in an out of the machine shop a good few times in the near future
  22. #521
    MIGWeb Lord
    Nov 2009
    Coventry & Poole
    Well have been far to busy to get anything done lately so had chance tonight to have a mess with the car again, finished off bells and machined 4mm off the disc diameter as they were just slightly too big for the calipers so took them down to 305mm to match the old ones
    Due to the offset i still need to take about 2mm off but don't want to take anymore off the bells so will machine it off the caliper mounting face instead as it's got plenty of meat on there and they'll fit perfect then, this is just to give you an idea of looks
    Couldn't do anymore until the new slim headed cap headed bolts turn up so give them a quick buff msl:
  23. #522
    MIGWeb Lord
    Nov 2009
    Coventry & Poole
    Few recent purchases:
    Love the flocked look, so looking forward to getting my dash done to match
  24. #523
    Love that you make your own discs up. Buffing is pretty too... Like the flocking.
    Performance Vauxhall Show - HERE Please click for more information.
    VBOA at Billing - HERE Please click for more information.
  25. #524
    MIGWeb Lord
    Nov 2009
    Coventry & Poole
    Yeah every panel and part on the car has been modified in some way, can't help myself lmao
  26. #525
    MIGWeb Technical Moderator Dale's Avatar
    Jul 2006
    Swindon
    Corsa VXR-R & Astra VXR
    looking good adam, did you buy those flocked bits off Danny W?
