Two of my bolts came out of that mount, and the middle one was loose.
It was when I was fitting my solid mounts, only reason I saw it.
Dewis, as per what I said before, if its warped the steel manifold flange its almost certainly also warped the ally head too.
Not as critical as a head gasket, but really that should be getting skimmed now.
For no nonsense hardcore vauxhall modifying advice: www.VauxSport.com
My Total-Vauxhall Magazine Staff Nova in the www.VauxSport.com garage
My Total-Vauxhall Magazine Staff Calibra in the www.VauxSport.com garage
Nah checked the head and that's still flat, tbh the manifold wasn't 100% flat down that end when a put it on in the first place as with my previous manifold that was warped but pulled flat when done up so this time I'm getting it skimmed to be perfect as I'm not in such a massive rush
Always a nightmare when you have massive time constraints like we had for PV, now you have over a month to TVL though hopefully a chance to do things exactly how you want them this time![]()
TBH i'm gonna be stretched for TVL as well, suspension won't be done by then but hopefully all brake mods and obviously a bit more boost mapping, cooling will be best it can be as i'm positive i have an air lock and fan will be on blow instead of suck, as i was chatting to the guy with the blue corsa doing TOTB and he had exactly the same set up as me and no cooling issues
i still think a heat shield would not do you any harm either mate, something like what daz had should help a bit with heat soak into the rad.. bet you would have the materials ready to make one at work..lol
Keep up good work fella!
What about getting the inside of the manifold ceramic coated to try and keep some of the heat in the manifold
Your right ceramic coating will keep temps down a bit but tbh others have there's working fine so mine will be an air I'm sure as on motorway it's fine as soon as you come off and sit at traffic lights etc temps start climbing up fast
Well not had much chance to touch the car really been busy doing inlets, sumps etc but thought i'd at least do something on it just to keep it ticking over as TVL is looming and i have no chance of making Billing now tbh :cry:
I had found my oil catch tank was too small and once over half way would preasurise when booting it causing my bay to get drench in oil :cry:
Had Rob's old one that he gave me so set about modding it to suit my requirements, moved the in feed round the other side and started welding up the spare holes
All ground down and gave it a quick polish and re assembled, will mod the mounting points possibly to suit it's new location
Other bits that have turned up was these off Fenny, new tie bar mounts as mine are shagged and iirc the last set of new gsi jacking covers from vauxhallhe sent them to me in April and i got them about 2 weeks ago as my worked decided to send them out to Afghanistan thinking i was there
msl: So sandblasted the mounts and gave them a quick coat of anti rust and then hammerited them, will press the polybushes in when i whip the old set off
Decided to treat my car to a spare hour today just to try and chip away at some of the small jobs, removed discs so i can give them a quick skim as i have a slight warp in them due to the fact my rear brakes seem to just be doing the bare minimal braking so fronts have took the brunt![]()
While it was up in the air i decided to remove the old knakered tie bar mounts and remove the bushes and re fit them into the new freshly painted ones
re fitted them back up, gonna look at making myself some adjustable rose jointed ones at a later date as although they do the job there is more scope for fine tuning with adjustable ones![]()
Also replaced the missing bolt in my engine mount and thread locked them in this time as i don't need them going walkies again![]()
As it stands now looking sorry for itself, just waiting on the manifold to be skimmed and a heat sleave for the oil pipe and then i'll re assemble it ready for mapping session 2 :clap:
Also thanks to Chip for having my car in his staff car write up even if he did include that gay photo of memsl: :cry:
Got my manifold back today from being skimmed big thanks to Sam Brown engineering in plymouth as he did it for free for me cause i was in the Forces :clap: I also gave the front brakes a light skim as i'd slightly warped them
Re fitted the manifold and gave the block a lick of paint while i could get to it just to freshen it up a bit
Also gave the AP's a quick paint to tidy them up, have got new high temp stickers to go on as well once there dry, planning on getting them powder coated come the winter time so will do for now![]()
Just waiting on my heat sleeve to turn up for my oil feed and then i can get it fully assembled again ready for some more mapping![]()
looking good mate![]()
bloody work gone into this nice one![]()
#No1 In the TINTIN Fan ClubEin Projekt, das ist eine nie endende Entwicklung
Daily - Vectra C 1.9 CDTI (120bhp)
Track - W Reg Mk5 Zetec-S Fiesta
Cheers guys
Well finally got round to getting my hands on car again been on inlet duty for a while now, few recents:
Set about getting the manifold back on and making a few improvements as well to help with heat etc first was to add so heat sleeve to the oil feed pipe as it sits close to the turbo and manifold and I've had one melt on my old engine before so didn't want to risk it again, it's a bit baggy as it had to go over the 90 degree bend on the fitting and the smaller stuff didn't fit, also the wastegate pipe had started to melt the intake pipe so some heat reflective tape was added to prevent this
Bought a cool running thermostat at PVS had to mod the top locating pin slightly as it didn't allow the sealing face far enough down, also used a spare housing as mine had corroded inside so gave it a quick sandblast and a squirt of sealant for good measure
Managed to find the part number for this on the military system so re wrapped the pipe going to the thermostat
Put the new stickers on the AP's
And set about sorting oil catch tank as mine seemed to get pressurised and once over half full spray oil all over my bay :cry: Cut the wings off the spare and re welded a new bracket on so I could mount it to the underside of the wing, added riv nuts to aid quick fitting/release
All fitted, blanked off the small breather
Looks a bit more cluttered but works so tuff
Also took my fan apart and turns out my fan blade was on wrong for what I was using it for as when I had it blowing it wasn't the best so flipped the fan blades around and it's so much better so I'm sure this will cure my problems as I had the car running for about 20 minutes on the spot and no over heating so that's a result![]()
you would f**king find the NSN for heat rap just after id ordered some
good work otherwise :lol:
looks awesome
loooking mate![]()
That is looking awesome dude.
Performance Vauxhall Show - HERE Please click for more information.
VBOA at Billing - HERE Please click for more information.
looks tidier then it used towell done!
Roll on LET power....
