Awsome! looking good man,
Save the trees, wipe your ass with a owl!
Cheers guys! Also big thanks to the people who rated my build thread 5 star
Still no show on parts ordered so i'm padding out my time doing smaller jobs, my EGT gauge has turned up so fitted that, had to make a boss as it didn't come with one and it's a npt thread so didn't have any taps like that so just drilled out my blanking plug and welded it into there
I then re arranged some gauges, ditched the battery one and moved the oil pressure into it's place
Finally fitted the temperature sender wire for the dash gauge as I had no idea how hot it was running unless the laptop was plugged in, and then hid all the wires to keep with the clutter free look, also removed the bonnet pull cable and spring as there now not needed. Started pre MOT checks and so far just little things like bulbs, wiper blade and a slight blow from an exhaust joint![]()
That's some nice welding.
Performance Vauxhall Show - HERE Please click for more information.
VBOA at Billing - HERE Please click for more information.
Been cracking on with the pre mot work today, changed the wiper blade and re plumbed in the washer spray bar on the wiper, also changed the two bulbs that had blown, and changed the rocker cover gasket for a new GM one as the old one was seeping oil in a few places![]()
Then finally got round to fitting the pre filter for the pump
All fitted up, crap picture but you get the gist
Still left to do is sort out some scrubbing noises at the front and re fit the CAT as it's just makes it easyer as the mapping is on the rich side and I haven't been able to prove the engine age yet![]()
Well car is now insured again and it's booked in for an MOT Monday at 1pm so am looking forward to it but a bit nervous as well as it's the only thing stopping me using it on the road![]()
All this week I have been doing the small jobs to get it ready/usable like zip tying stuff out the way and double checking bolts/clips, have finally sorted the brake pedal box out as I changed the ratio of the pedal, only moved it about an 2cm but has doubled my braking power now so once MOT'd I'll need to fine tune the brakes by just playing with the bias bar, will buy a remote lead to go on it I think so I can adjust it in car![]()
I will let you know how it gets on, fingers crossed![]()
Looking good mate, Hope the MOT goes o.k for you.
If you always tell the truth, people will stop believing you!
http://www.iconperformance.co.uk/ - Vauxhall Specialist Tel 07962398027
Good news and good luck![]()
good luck on the MOT mate, my corsa turbo passed on wednesday, great feeling when you can (legally) drive it on the road again.
Build looking really good, interesting thread to keep an eye on!!
Good luck for the M.O.T, dreading the first M.O.T for my C20XE as it's the first time I have M.O.T'd is since owning it lol
Cheers guys! Yeah mot is always dreaded don't know why as everything is pretty much new etc just hope he doesn't hate modded cars or is too pedantic over stuff as I really want to drive it on the road now
Nice build,
Please loose the Ripspeed head unit and chav pedals
Good work
Well took it for it's MOT and it failed :cry:
Not on much though tbh:
Headlight alignment N/S
A spot weld had broke off the bulk head bellow the steering rack causing movement (not a hard to fix job for me tbh)
And emissions were out, have ordered a bung so I can weld in a narrow band lambda sensor so that Chip can connect it to my ECU so that he can fine tune the readings![]()
So over all very happy with the short list, was happy the brakes preformed really well and every thing else was spot on, the tester was really sound and let a few minor things slip like the number plates and a bit of wheel scrub on full lock![]()
Test station had a sweet ramp set up that was counter sunk so low cars can get on as it's a sunk down 4 poster with a small pit dug out
I love this build, looking forward to seeing it at pvs mate!
Not much wrong there to fiddle with mate, you will have it sorted asap no doubt, keep up the good work
Cheers guys, yeah looking forward to being able to drive it there and use it this time, and will have them bits sorted by the end of this week and get it booked in for a re test next week
Nice one Adam, car is looking great !
Made a start on the MOT work, sorted the headlight alignment out and welded the bottom of the bulk head that had split away
The corsa has a flimsy bulkhead like most older vauxhalls so I'm gonna look into making a brace from the steering rack like what saabs have![]()
Had a bit of rubbing on the disc so stripped it off to find the bottom dust guard had been touching so trimmed it down to stop it rubbing as it couldn't be bent far enough back
Lambda bung has turned up, and lambda from omex should of turned up today so will collect that from the mail room Monday and get it all fitted and wired in and just switch the settings on in the ecu
cool, awesome thread this is mate fair play, i just been reading through this to pass time while on my night shift, really neat and tidy engine swap this is mate fair playbet it goes like Feck aswell!!
Well mot re test was a non starter as the fuel leak just wouldn't go was down to damaged O rings must of got damaged squeezing them into the rail
Tried another set but still leaked, another dig around in my spares found another set and they seem to have worked, will order a brand new set to keep as spares![]()
Then disaster struck as my FPR snapped off![]()
So came up with a emergency repair which should fingers crossed be fine at least to get me through the re test which will have to be tomorrow or Friday, I drilled and tapped a push on fitting into it
Good bit of repair work there mate, good luck for mot!! if you get stuck ive got a weber reg you can borrow for a while.
