Dj_Faisca Calibra C20xe Turbo :D
Results 1 to 23 of 23
Thread: Dj_Faisca Calibra C20xe Turbo :D
    Sep 2009
    Portugal
    Hello people.
    I´m from Portugal and i have a Opel calibra c20xe 150ps which recently i applied a turbo.
    On this tread I present to you my Opel Calibra c20xe Turbo, it not finish yet but it rides on roads.
    Engine :
    - opel c20xe 150ps
    - Original pistons
    - Original transmissions
    Modifications:
    - Turbo MHI TD04 11G, from BMW 525tds
    - Motronic 2.8 injectors (243cc i think)
    - CPU Motronic 2.5 with chip by M-Tech
    - Air filter type BMC CDA
    - V-Max Actuator
    - Interculer 75x23x6
    - Inox pipes for interculer paited on blac
    - Dump Valve, piston
    - Borbet Type T rims 16x9, Tires 215/40
    Next Modifications:
    - Forged pistons
    Photos:
    Sep 2009
    Portugal
    Re: Dj_Faisca Calibra C20xe Turbo :D
    So i have one question...
    which of the two turbos is the best??
    - The kkk k16 (original turbo from opel calibra 4x4turbo)
    OR
    - The MHI TD04 11G (original turbo from BMW 525 TDS "Disel" )
    Jun 2009
    Near Lincoln
    Astra MK3 TDS
    Nice build mate I would love to know exactly how you managed to fit the turbo, that looks like an awesome conversion! Are you having problems with the standard pistons as most people would recommend forged pistons for a turbo conversion.
    Sep 2009
    Portugal
    I managed the turbo by original ECU, after some days i put the chip that seels on the M-Tech, they are now 4000km with this aplication and a don't have any problem, but the turbo onely do 0,5bar pressure, to put more pressure i need forged pistons.
    Jan 2005
    PORTUGAL
    Tigra 2.0
    nice build! a lot of room for improvement! you will need to work on internals there.
    are you running stock compression?!
    cheers/
    abraco, bom trabalho! =)
    Sep 2009
    Portugal
    Yes i´m running stock compression, then i have the turbo only 0.5bars
    MSG
    MSG is offline
    MIGClub Member MSG's Avatar
    Apr 2005
    Isle of Dogs
    Calibra Eco 16V 2L
    ya is very good your pictures, looks very nice, I like it too much. cool mods.
    Sep 2009
    Portugal
    Thanks man
    Jan 2005
    PORTUGAL
    Tigra 2.0
    you can buy some LET pistons and fit them, its a easy mod to do (sort of), they are not as expensive and should be fine for about 300hp!
    cheers!
    (vou fazer o mesmo ao meu XE...é barato!)
    Sep 2009
    Portugal
    Yes, in this moment i have the c20let pistons to put in... on the next month i will put the pistons and another this, like ECU motronic 2.7 chiped by V-Max. etc
    Jul 2009
    kosova
    the MHI TD04 is beter becouse is bigger than k16 and in high rpm can flow more
    install TD04 if you want to upgrade power in future
    Jul 2009
    kosova
    look and c20xe pistons are from forged aluminium but problem is compresion ration
    with xe-pistons you have about 10.5:1 cr can detonate easy and destroy your pistons with higher pressure than 0.6bar+
    with let pistons you have about 9.5:1 cr you can increase presure more than 1bar+
    is my think
    Jul 2009
    kosova
    question do you have change pressure regulator and injectors or you are runing with std c20xe bye
    Aug 2008
    Peterborough/ketton
    Corsa
    looks good
    i'm turbo'ing a xe, only difference will be thicker head gasket and i want over a bar going through it, but i'm running megasquirt.
    Gagged
    Aug 2009
    Dunstable
    White MK3, 1.4i LS
    Looks awesome mate, nice conversion!
    Jun 2009
    Nice project you have there And your english is good
    Dec 2002
    Essex
    Lada Riva
    Not keen on the ducting cold feed pipe being used in between air flow / mass meter .
    That aint gonna take anything before giving up .
    Sep 2009
    Portugal
    Someone get me the wiring diagram of the injection system Calibra Bosh Motronic 2.5??
    Sep 2009
    Portugal
    Hello people
    Some people told me that the crankshaft of the C20let it is the same of the C20xe... it is true?
    Sep 2009
    Portugal
    People the crankshaft of the c20xe support 500cv ???
    Dec 2008
    croatia/županja
    very brave project..Are you measured acceleration,top speed?.I am interested gain compared to a standard xe...
    Nov 2008
    Bosnia,Europe
    Calibra turbo 4X4
    Quote Originally Posted by Dj_Faisca View Post
    Hello people
    I had A C20Let with a crankshaft from XE on the exhaust side,it gives a better reaction on higher Rpm a little bit.
    Think You are looking for this?
    Who want's to live forewer?
    Sep 2009
    Portugal
    Hello again
    First sorry i´m not post more information on my project since last year
    Second i stop the project of c20xe Turbo, and start another project for my calibra.
    The idea is to put on my calibra a c25xe and put one or two turbos, for this i need help from all of you guys.
    First question is what better gearbox f20 or f25??
