Results 1 to 3 of 3
Thread: 2.0 16v ecotec into Corsa B type 2.... Mounting...
    Oct 2008
    Stockport
    Corsa Gsi
    As above, putting a 2 litre ecotec into my corsa B after dropping a valve in my C16XE.
    I have bought the engine & loom, the CV joint inners and have GSI driveshafts. The engine does have power steering so I am looking to take this off and use a shorter belt.
    I am told I can use two of the engine mounts I have already, i.e. rear and passenger side, but need a conversion bracket for the front drivers side mount, as it recesses into the wing.
    I am on a very tight budget so looking to avoid expensive parts where possible - where am I best getting hold of one of these? After looking on ebay I notice kits can be £150 - £300, and am looking to avoid spending this at all costs!!!
    Are there any mounts from other models which can be used? Or anyone pretty good with a welder who is happy making me one? Or anybody bought one that they do not use?
    Sep 2003
    South London
    Without Due Care
    Re: 2.0 16v ecotec into Corsa B type 2.... Mounting...
    you sorta posted in the wrong section but nevermind
    have you looked in the forsale section? theres always a few corsas about being broken.
    Another cheapish option is to PM 'rallyman' on here, he'll do you a good deal on the brackets you require and p/s bracket too.
    Oct 2008
    Stockport
    Corsa Gsi
    Cheers for advice, all required bits have been sourced!
