Im not mate but what issue do you have????
TOTAL VAUXHALL COVER CAR, SEPTEMBER 2008
PS3 Online Tag:- VAUXBOOST
Well Crombie kind of cleared it i think. Change the bottom pulley to a twin v pulley,relocate a v belt powersteering pump with a bracket and run it direct to the bottom pulley and then run a v belt alternator direct to the bottom pulley also.
Gagging For Boost =(
or be a real man n ditch power steering all together!![]()
ps3 online id - fromthearth add me
NEED ANY PLASTERING DOING? drop me a pm
^^^^ agree with the above... but if you do want to keep it then that is the way to do it... you can get a small bracket for a corsa conversion for the pas pump from lmf.. its an mtec one. they supply the shorter belt with this as well.![]()
Where do i get a v belt for the alternator? Off the car the twin v pulley came off of?
And Col i suppose you have an F20 speedo drive fitted to your F28?
I do have an f20 ring on the diff for the speedo.. also you cant get a pully for an alternator mate.. you have to source a v-belt alternator off an mk2 astra gte(c20xe)![]()
you can get pulleys for alternators cos i make them!!
www.wix.com/vxlgsi/zxr-750-r
there you go jamie.. top man above makes them.. cheers vxlgsi![]()
Cheers lads that clears alot up![]()
You can swop most alternator pulleys over - my current alternator WAS a wide belt, and is now a V-belt![]()
No updates Col?
no mate.. been busy on the house..![]()
not gonna swear but muck fe thats gorgeous !!!!
mate that thing looks beautiful! would love mine to look even half as good as thatnice to see time being spent over these little cars! good luck with the project!
Have Fun.
Daz.
My Frost Blue Corsa : http://www.migweb.co.uk/forums/proje...erm%2A%2A.html
Awesome, project.
Subscribed to give me some encouragement to get mine done.![]()
MK III Astra 2.0l Turbo Cabriolet - Landrover Discovery
Skoda Otavia 2.0 Diesel Elegance
BMW 330 Ci Sport Convertible
alrite mate got a qick question for you if ya dont mind fitted a 2.0 (GTE) in to my corsa but got a bit of a problem i have my 5 forward gear's but no reverse but the ratio of my forward one's have gone bigger for example 1st is were reverse is ment to be and gear stick go's further forward and back is it something to do with the linkage. could you e-mail me at john_boro_@hotmail.com if you can help thnks mate
you not chopped this in yet and got a nice family car
when are you going to grow up lmao
Right... A tiny bit of progresslmaolmao
I have purchased a Phase 4 ecu and some 550cc msd injectors of mr djbrowney (cheers mate).
Me being me (abit of a sad bastardlmao) thought id tidy up the way the std ecu looked seeing as though its going to be on show when the car is stripped out
lol very pretty.
lmaolmao cheers Benn
No work done but a couple of little buys over crimbo.
Sticker lmaolmao
And Santa put this under the tree from the mrs
This is going behind the spot light hole....
looking gud mate![]()
Nice looking car![]()
