Just went on there website although not english easy to understand and on dyno page guess what i found.............. fantastic woth a look hang on..
http://www.maxxtuning.se/index.php?id=70
there you go..... enjoy
I personally like the way it looks it looks rather evil lol
any one know what the nassan astra was making power wise i thought it was around the 900bhp mark?
ive said it once and i'll say it again... AMAZING!!!![]()
Awesome project mate, waiting for some more pics.
sure is brilliant fair play m8
is it a Precision or a Turbonetics turbo charger?
Regards akis
Observer:
Well, the body work is not finished yet.
There will be a new hood also.
The actual front and rear spoiler will be the same since they are custom made by us.
What was it that you thought was crappy made?
It hasn't been polished since last time it saw the sun, which was a long time ago.
We gave it 5minutes of pressured water before theese photos was taken.
It's a Garett 4094R with 1.15 exhaust house.
/Qrew
all i can say is..... AWSOMEyou have made monster there,cant wait to hear the qaurter mile times for this,great job
i love this carrrrrrrrr!!!!!!!!!!!! respect!!!!
Amazed again!
Nice car but where is the build pics would like to see more know of a few okes here in sa that also gets amazing power 325 whp out of a 1600cc 16 valve opel motor on 1.8 bar boost and 570 whp out of a z20let on 1.6 bar boost and a sliping clutch
what kind of ignition mallory or MSD ?
oel pump external trockensumpf ?? ventil mechanik or hydraulic??
cams??
how manz Rpm?
some specs about your new enginge....
Regards Akis
Now everything is set for tomorrow and our first competition with this setup of the car.
We tried on the normal road with our M/T Drag 10,5" wide....wheel spin at fourth gear (around 240km/h) so there is enought power
Balsak :
Amazing power 325whp from 1600cc injectors? amazing? I do not understand? And I can't see what a 570hp Z20LET engine with a slipping clutch has do in this thread about our car? Our clutch does not slip yet, better alternative than a slipping one I think
Dragcaligr:
VAG coils (Audi RR4).
Uprated XE oil pump.
Mechanic lifters.
288 degree cams with 10,4mm lift.
Stock valves.
Max rpm 7600
E85 Fuel
2,6bar boost, 17degrees ignition on full boost.
Lambda 0,82 at full boost.
Tommorrow is BIG DAY for us, I will post after the competition with some movies and times hopefully.
Regards Qrew
Good luck!
Good Luck!
good luck hopefully you will get some quick times with your new car.
Stuart
has scrapped the sig with all the cars to do list!!!!! 3 novas i own says it all really
good luck guys, get lots of video's![]()
i miss my vauxhalls breaking down
videos?
We had the opportunity to test the car three times.
First start a drive shaft went away.
Second start with a new drive axle we did a very easy start (go to the shop drive away) just to make sure we could travel all the way to the finish, and we did, but not that fast
The third start the second drive shaft died and traveled to mama also.
Times from our first quartermile run
60ft time: 3seconds
200m terminal speed: 175km/h
200m time: 9,3sec
402m terminal speed: 218km/h
402m time: 13.1sec
Next competition is in the end of this months, then we should be prepared with better drive axles and some small adjustments.
Hopefully we could release the clutch at 2bar boost (600hp) and smoke away really fast
The drive shaft problem was really expected, but there wasn't any time to make "real" ones.
Regards Qrew
you had a proplem with the clutch,lunching at 2 bar or at more?
MIG.....Made In Greece LOL
We did NOT launch whatsoever...just an ordinary simple start just to make things not brake!
No problem with clutch, I can't understand what you got that from?
/Qrew
You said that:Hopefully we could release the clutch at 2bar boost (600hp) and though that exept the shaft,you had also a clutch issue....it was just the shaft i quess.
Took my breath away!! absolutely amazing and looks just as bewautiful as it performs!! WELL DONE Qrew!!
Well the issue was that we couldn't release the clutch with loads of power because then the drive shaft went away...
I thinks it's really good to have a terminal speed of 218km/h with a 60feet time of 3seconds
Qrew
