Page 1 of 12 1 2 3 4 5 6 7 8 9 10 11 ... LastLast
Results 1 to 25 of 286
Thread: My Saab powered MK3 Astra
    Regional Co-ordinator nige-p's Avatar
    Jan 2005
    Moreton, Wirral, United
    saab astra mk3
    ok well havent posted on here in a while as been to busy researching my latest change to the car and thought it was about time i put a diary up on here, a few of the north west members might know me as i did attend a few meets but these were about 3 years ago
    ok so purchased the astra back in 2003 as a bog standard 1994 merit with 1 owner from new and 135'000 miles on the clock, within a week it had everything body coloured and some new wheels
    then in 2004 purchased a full reiger kit for it as was bored with the standard bumpers
    then decided needed some new wheels so changed up to 18's
    and then in late 2005 got offered a cavalier SRI with a 20SEH lump in for free so how could i not change it
    the donor lump
    this was a great lump and use to rev so well in the astra also took it on a migweb roilling road day on 21st april 2007 and it produced a healthy 130BHP and 130LLbFT of torque
    but then 1 month later on the way back from a meet at RAF cosford i managed to smash my pride and joy into the back of another car the outcome was this
    so decided to rebuild
    and within 2 weeks it was back in one piece and sitting their at PV 2007
    then about 3 months later the engine started to knock so it got parked up and sat for 8 months as i had no time to fix it i then got another 20SEH lump and fitted that in april 2008 i then drove the car round until FEB 2009
    now all the major work starts i had been scouring the internet and saab forums for information on putting a saab lump in the car as didnt want to go the C20LET route
    eventually came across a lovelly Saab 900 tubo sensonic car for £300 (BARGAIN)
    so the work began
    ok so the astra now in to be stripped
    also fitted a carpc setup at the same time
    ok so managed to get all the engine in and working but still got a few issues to resolve but i made it to PV and managed 4 runs at santa pod but with boost issues
    the engine is running standard spec at the moment but im running a saab 9-3 map which is meant to run better on the B204L engine, the car has a saab 900 manual gearbox on it now with a cable operated clutch im using the drivers side saab driveshaft and then a vaux passenger one as the saab one was abit to long the wiring was a bit of a night mare but worth the hassle i would say.
    im hoping to start tuning it up a bit more in the next year and a fair few other bits such as getting all the reiger kit back on and also got saab brakes sitting there waiting to go on and just to enjoy it
    if anyone has any question please feel free to ask
    May 2001
    South Wales
    Nippy Cav Turbo
    Re: My Saab powered MK3 Astra
    what 1/4's did u manage anyways matey? nice build
    Did the egine bolt stright in?
    Aug 2003
    plymouth
    wife around the
    fantastic conversion well done on being one of the first.
    are you willing to post details on engine mounts and wiring.
    ''THE REAL ROB''
    Apr 2002
    Southwest
    Like its stolen
    Love it
    Jan 2008
    Bramley Leeds
    mk4 astra sri c20let
    can we have some details on what is needed to get engine in and running. i can get a doner saab for £200 and i can swap my corsa for a astra gsi. so i would love to do this conversion
    Oct 2003
    glasgow/oban
    like its a hire car
    which of the saab engines / cars is that? did you use the complete subframe?
    looking really good!
    Nov 2005
    Chester - North West
    Vectra C CDTI
    about time you put it on here Nige lmao
    I've fixed this for you. Benn
    Jan 2005
    saab astra mk3
    ok thought i would get some questions so will copy bits from my mk3oc diary
    the engine bolts in on the saab mounts using the standard vaux subframe so no modifications needed in the slightest here, mechanically its a very similar engine its the electronics that are different i have used the standard inlet manifold and just slighty rebent one of the brake pipes and also used the saab radiator as this will fit in the front of the astra as long as you remove the front slam panel to get it in and out, the engine is a very similar outer casting to a vauxhall engine so i would think that it wouldnt be to hard to get it into other vauxhall cars i think one in a corsa would be interesting
    The other major problem i have is that the astra has a mechanical speedo from the gearbox where as the saab trionic(engine management) needs a speed signal so to run the engine this is taken from the ABS system and this is where the speedo gets its signal from, to combat this im going to fit the nearside abs sensor and the rings are allready on the driveshafts and the ABS ECU will be fitted and feed the signal back to the trionic ECU the car will not run correctly if it does not recieve a electronic speed signal
    Auxilary belt = the car had all the mod cons so air con and power steering where as the astra doesnt nor do i want them, removing the air con pump and rerouting the belt for that i can order from saab but i dont need the power steering pump this i solved by dismantaling the power steering pump and removing the blades from the pump it was then moun ted on the car filled with oil and then sealed at both ends and its been like this for 1000 miles at least and have checked inside and its running fine with no major noise it getting to hot
    im going to be mapping the car myself with the help of a program called T5 suite i have shown kev G how easy this is and it makes other cars look rubbish and the fact im going to be able to live map the car will be great, ive nearly finished my car pc which will run the mapping while im driving and also monitor all the engine sensors without having to have 20 dials on my dash
    the hardest part of this conversion is the electrics but if you have a donor veichle and some good wiring diagrams for the car its not to bad only took me about 8 hours to probably do the wiring but about 3 weeks of checking and writing bits down i will go over a few bits so to help people
    starting with dash wiring for your RPM that just comes from the ecu. speedo is a electrical signal from the ecu so im guessing if you have electrical clocks shouldnt be a problem if you have mechanical like is still have im not sure. engine temp is the next one as the saab has a 2 wire sensor where as my astra was a single connection and earthed through the engine to solve this i kept the saab one in the manifold and then fitted the vaux one as well into the thermostat housing by drilling and taping a hole its technically on the wrong side of the the thermsotat but only slighlty under reads,
    the electrics for the engine running you need to make up a wiring loom with 2 relays one to run the fuel pump and another is the main relay these pretty much control most of the engines controls and are the main voltage inputs for the engine, i used the standard astra circualr plug for the starter and alternator and then replaced the oil pressure switch with an aftermarket one
    hope some of this helps the people who are looking to do the conversion and good luck
    Aug 2007
    United Kingdom
    Shogun/MK1 Escort
    Great work, well done
    Jack said,
    Surely you are only pulling it one way though? ie. you are pulling it along its length.
    Apr 2007
    yorkshire
    astra gte mk2 16v,T.
    nice work
    Jul 2005
    Wirral
    Astra Coupe Turbo
    nice work mate, my mate john told me you had put it in. i passed you on the way back from PVS on the M53 in a green corsa b
    Nov 2005
    Vectra C CDTI
    its fapping quick aswell for standard ish lmao
    Oct 2003
    glasgow/oban
    like its a hire car
    Ive heard of T5 Suite from locost circles. When you get round to it, fancy posting some screenshots of the mapping process?
    Cheers
    Dec 2005
    UK
    Frontera LWB, Astra GSI
    Wow, that is awesome! Nice to see someone jumping in with both feet!
    Looks a really smart conversion. I can't believe you repaired all of that crash damage in two weeks!
    Mar 2009
    Preston, Lancashire
    Vectra SRi 150
    nice build mate and very nice engine. Nice to see something different
    Dec 2003
    staffordshire
    Astra G & Nova Mk1
    nice work, still kinda ground breaking, eh..?
    Jan 2005
    saab astra mk3
    thanks guys yes i remember you lawton did go back and forth past each other a few times but was still having boost issues on the way home only getting 5-8 PSI stupid faulty wastegate
    i ran 15.2 at santa pod at 94MPH only on 8 PSI of boost but have been running 18-20 without fuel cut since
    will try and post some pics up of the t5 stuff later if i have time
    here are some links to the car on youtube
    http://www.youtube.com/watch?v=XoWX-R9lf1I
    http://www.youtube.com/watch?v=s-sfpUHioG4
    001 is offline
    Aug 2002
    Scotland
    530d, VXT
    Nice build mate, good to see someone doing things a little different.
    If you take measurements of the size of the belt you need and how many 'ribs' it has then go to your local motor factors they'll be able to match it pretty close to another car and you can do away with the powersteering pump completely, i did this before when running a wide belt set up on a mk2 astra, with no powersteering or aircon.
    Cheers, Iain.
    VXT In the making....
    Jan 2005
    saab astra mk3
    Quote Originally Posted by 001 View Post
    Cheers, Iain.
    hi man did look inot this as their is a place by ours with some old geezer and all he does is belts you just go in and ask for the length you want and he will have something to fit but i cant it needs to have a pulley where the power steering pump is otherwise id have no water pump
    Aug 2008
    Cambridgeshire
    A fleet of Griffins...
    fandabidozie. good work.
    - humbucker's satin red cavalier turbo WIP: http://is.gd/74Bgsf
    - humbucker's cavalier v6 WIP (pic heavy): http://is.gd/Vq105d
    - humbucker's 2004 Irmscher Omega 3.2 MV6 project: http://is.gd/ghpBhW
    MIGClub Member MarkW's Avatar
    Nov 2003
    Essex
    Seat Leon Cupra R
    Awesome! Top work chap, are you going to Billing? Would love to have a nose.
    I love my LCR
    Jan 2005
    saab astra mk3
    will be going to billing im still going with mk3oc at the moment but due to where we have our site for billing i might come with mig???
    Feb 2006
    WREXHAM
    Vectra V6
    Thats one sweet conversion matey well done for taking the plunge.
    you deserve a lot of respect for taking on the wiring in that.
    Vectra Owner
  26. #25
    Nov 2003
    Essex
    Seat Leon Cupra R
    Quote Originally Posted by astra-nige View Post
    mk3oc isn't in a terrible place, if you want to go with Mig then you will need to pay for membership, the deadline for Billing booking is the 30th,
    If you do go with mk3oc, I'll definitely have to have a nose!
    I love my LCR
  1. 19-12-2011, 14:52
  2. 20-11-2011, 14:31
  3. 20-11-2011, 02:26
  4. 18-10-2011, 15:48
  5. 07-07-2011, 09:34
  6. 03-07-2011, 01:01
  7. 01-07-2011, 23:54
  8. 28-05-2011, 06:41
  9. 21-04-2011, 18:33
  10. 13-01-2011, 06:51
  11. 28-11-2010, 19:53
  12. 25-10-2010, 21:35
  13. 01-10-2010, 09:05
  14. 26-07-2010, 12:37
  15. 28-06-2010, 20:28
  16. 23-06-2010, 09:58
  17. 05-06-2010, 22:10
  18. 21-04-2010, 07:10
  19. 11-04-2010, 13:03
  20. 23-02-2010, 19:45
  21. 27-01-2010, 22:16
  22. 14-01-2010, 18:10
  23. 06-11-2009, 17:59
  24. 01-08-2009, 18:50
  25. 16-07-2009, 21:04
  26. 11-07-2009, 20:17
  27. 10-07-2009, 18:01
  28. 10-07-2009, 17:50
  29. 05-07-2009, 20:53
  30. 05-07-2009, 20:45
  31. 26-06-2009, 21:20
  32. 26-06-2009, 18:12
  33. 26-06-2009, 17:22
  34. 26-06-2009, 09:46
  35. 23-06-2009, 17:21
  36. 23-06-2009, 06:14
  37. 23-06-2009, 04:00
  38. 22-06-2009, 23:34
  39. 22-06-2009, 19:44
