cant wait to see this at PVS
Vectra Owner
Haha you got the turbo you was on about then mate? You sure it's big enough? On a serious note I've bought 3 spare turbos for mine off eBay an they have all been knackeredHow much do you want for your t25 posted to mine if you are selling it? Stevo
hi steve im going to keep the turbo as a spare as i never know my plans
well had a visit over the weekend to sort out the bay on the car and have spent today putting the engine back in and placing the turbo on the engine to get an idea of where it would sit and spacing ive got a different manifold to get which should bring it up a bit have also done a wiring tuck so very little wiring in the bay now
all painted
1994 MK3 ASTRA now with SAAB TURBO power 274.8BHP 315LBFT
INJECTOR CLEANING TESTING 24HRS TURNAROUND
WWW.SAABCONVERSIONS.COM
Previously known as Astra-nige
getting there mate![]()
Can't you turn the turbo round 180 degrees? Will be a bit of a drama getting the downpipe to run where it should unless you have a custom sump made. The 9000 downpipe runs off the turbo to the offside but I'm sure you already know that! Can't believe how big it is! Will it be ready for pvs? I'm booking mine in for a dyno at the scooby clinic soon so I'll let you know how it gets on![]()
well had a good day on ther astra as ive been to busy this week to do anything on the car so first job was rto replace loaoads of bits so big pile of old bits
and how the car currently stands
have done all the engine wiring now so the engine all works now but i cant start it as i need to do oil pipes to turbo and do my coolanty pipes but this all depends on me going to get my 9000 manifold tommorow, have done a few other things but im sure the eagler eyed will spot some of the work in progress bits
Alright chief I've got a 9000 manifold off and ready to post if you can't get your hands on 1. Let me know mate. Also if anybody suggests using an f20 with a Saab conversion tell them to not bother cos it will last about 3 hours!
Stevo
ok well got my 9k manifold and its helped quite a bit but still needs some tweaking in position by modifying the the t25 to t3 adapter
well today is wiring day so im siting in the drivers wheel well doing this
this is the current state of under the bonnet
the only things left to do under here are the header tank pipes and oil and intercooler pipes
and another little parcel came
that turbo looks like its gonna be rubbing on everything matey engines move around quite abit, might be worth giving it a bit more space while its an easy job.
www.wix.com/vxlgsi/zxr-750-r
what holset is that?? im currently getting a flange made for mine hehe big aint they!!
is that it for the bay wiring wise?? looks mint.
Roll on LET power....
im making a v shaped adapter for the turbo so will bring it about 1 inch maybe a bit more closer to the engine so clearance should be ok as its just the rad its close to, thats all the wiring in the bay just pipes to do really
nige that looks pukka mate fresh!! so have u but a bigger turbo on that? are u running a different map / ecu or just stock? and bolting a bigger one on.
Vectra B Estate 2.2
Vectra B Saloon 2.6
upgrades to the engine for the turbo are as follows
custom engine map
holset he341 turbo
3 bar map sensor
siemens deka 630cc injectors
3 inch exhaust
oher upgrades im doing as well are
volvo valve springs to allow upto a 9000 RPM limiter
bosch 044 fuel pump and swirl pot
what size wheels is on that he341?? i bought a h2a and could only find one guy that was running 500hp... everyone seems to use the hx35 or 40. i think the others are still un tested on modified petrol engineswere see..
very well built turbo's though!!
Going to follow this thread with interest............ i've just picked up a Saab 900 Turbo tonight............. It's the future...........![]()
Project Astra Aero is underway.............
the holset ive got is a he341 which was fitted to the auto dodge ram trucks so is a tad smaller than the hx35 its specs are
HE341: 54MM Compressor
HE341: 9 CM Exhaust Housing
HE341: 58MM Inducer
also has titanium comp wheel
the h2a is a big turbo and will be hard to get spooling low down the he341 im putting on no one has used over here yet there is one saab in the usa using it but havent been able to find any pics or info on it, the main ones people use are the hx35 twin scroll turbos and they are now moving on to the he351 VGT turbos with 2 x guys over here getting to grips with the varaible vane
nice info cheers.
so my h2a will do 400bhp?? lol
well bit of an update its been slow on the car as had a few issues with the new injectors but have sorted it now
so scaffolding in
and my first 3 inch tight mandrel bend came and my friend finished my 3inch to 4.375 vband adapter, (stainless porn alert)
have also now modded it so that i no longer have a power steering pump to give me some more space
very nice Mr P![]()
very nice keep up the good work
AJB69
very good, seen you towing this the other night in hoylake. you were waiting to pull out onto the main road when i went past
ok well no real updates on the car its back on the road and did 400 miles last weekend down to santa pod and back and the new engine run like a dream and revs so much better with the balance shaft chain removed, collected a manifold flange on the way back
so the 200sx manifold nearly stripped down and new flanges for both ends
hoping to have this finished in the next week so i can get the turbo on ready for billing
great work! i will do a upgrade like u in my astra mk2 gte![]()
so if you could help me with the electric stuff you would be my hero!
i need help with conecting the trionic wirering system with the in my car.
I spent a small fortune on custom powersteering hoses for mine so I can put the pump back on. Mine did exactly the same when I replaced the pump for a small pulley, flirted the belt off and then I was left pulling bits of string out of the bottom pulley!man-down!
See you have removed your balance shaft chain... Does it really make that much difference? Did you remove both balance shafts too?
Stevo
