My Saab powered MK3 Astra
Page 2 of 14 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 ... LastLast
Results 26 to 50 of 349
Thread: My Saab powered MK3 Astra
  1. #26
    Feb 2002
    Fareham, Hants.
    13S C20XE X20XEV
    Re: My Saab powered MK3 Astra
    Can you not use the speed signal from the back of the clocks? Mk3 Astras etc generate a speed signal from a disc driven by the speedo.
    They're there, in their room.
    Sep 2003
    South London
    Without Due Care
    IIRC saabs also use a differnt amount of pulses
  4. #28
    May 2009
    falkirk
    mk3 astra mk4 van
    awryt mate how did the car go with the seh in it im puttin one in mine cant wait lol
  5. #29
    Jun 2009
    QLD AUSTRALIA
    MK2 ASTRA GTE 16V
    nice job mate , i know the rear beam and lower front struts fit mk2 & converts car to 5 stud but gives you 288 mm discs same parts as vectra as you would prob know as far as i know it should all fit mk3 ,i also heard the 900s is based on the mk2 floor pan by gm who ownes saab "this is info from 3rd party not confermed "
  6. #30
    Feb 2002
    Fareham, Hants.
    13S C20XE X20XEV
    GM900 (94-03) = Mk3 Astra underneath.
    NOT Cavalier, Calibra or Vectra.
  7. #31
    Regional Co-ordinator nige-p's Avatar
    Jan 2005
    Moreton, Wirral, United
    saab astra mk3
    yes dan is spot on GM purchased saab in 89 and gave the designers a mk3 astra chassis or if you want to be technical a GM2900 and went make yourself a new car so saab used the front subframe and rear beam and their own engine and a vauxhall gearbox and their you have a saab GM NG 900 which came on the market in 1994 they then used this same floorplan on a few other cars such as but with some changes
    * 1993-1996 Chevrolet Vectra A
    * 1997-2005 Chevrolet Vectra B
    * 1990-1997 Holden Calibra
    * 1996-2002 Holden Vectra
    * 1990-1997 Opel Calibra
    * 1988-1995 Opel Vectra A
    * 1995-2002 Opel Vectra B
    * 1994-1998 Saab 900
    * 1999-2002 Saab 9-3
    * 1997-2009 Saab 9-5
    * 2000-2005 Saturn L-Series
    * 1990-1997 Vauxhall Calibra
    * 1988-1995 Vauxhall Cavalier Mk.3
    * 1995-2002 Vauxhall Vectra
  8. #32
    Jan 2005
    saab astra mk3
    ok here are a few more pics of odd bits on the car but first some pics of what is required to flash the maps on the ecu
    take one ecu and unscrew and pull the board out
    find the 8 pin debugging connections
    you then need to connecter a header to these
    i decided to drill the board out and then solder them in (this was the scariest bit as if i slip im broken my ecu
    some nice small holes
    now powered up of a 15 volt powersupply and them my nokia debugging lead connected to it and the PC
    read the old code of using the program in dos and them prep the ecu for flash and start copying the new maps to the ecu took about 15 mins
    ok some more pics of odd bits on the engine
    the wiring loom i made up for the relays and a more compact fuse box
    also fitted the gearshift from the saab as the throw was wrong on the vaux one and luckily enough its the same stud pattern to bolt to the floor just had to remove the key lock as on the saab you have to put the car in reverse to remove the keys
    saab gearbox
    some pics of the engine from different sides
    ok so hope some of these pics help anyone who is intersted in the conversion
  9. #33
    Ed
    Ed is offline
    South Croydon/Surrey
    Merc W201 190 & W124 300
    Well done that man. Always wondered when someone would do this. It had to happen given the similarities; always wondered why it never had been though.
  10. #34
    Feb 2008
    Ashford, Kent
    calibra
    Whow what an intresting project, I certainly enjoyed reading that.
    Very well done
    PM Sent
  11. #35
    Banned
    Oct 2005
    ThickFord Shropshire
    a BMW again lol
    and me
  12. #36
    Nov 2005
    Chester - North West
    Vectra C CDTI
    i mentioned it when my mate had a 900 and we tuned it then speaking to nige one day we both had the idea but he has the balls to do it. I love it
    #No1 In the TINTIN Fan Club
    Ein Projekt, das ist eine nie endende Entwicklung
    Daily - Vectra C 1.9 CDTI (120bhp)
    Track - W Reg Mk5 Zetec-S Fiesta
  13. #37
    Jan 2005
    saab astra mk3
    thanks guys for the comments ive got the brakes sorted as well now and will be making my way down to billing saturday mrning and it will be on the mk3oc stand with the bonnet wide open if anyone wants to come and nose and pick my brain feel free to
    ok some pics of my new brake setup which came from a 9-5 aero these are 308mm disks
    old setup(cavalier SRi)
    old disk versus new disk
    and all done
  14. #38
    Eastern Regional Coordinator MarkW's Avatar
    Nov 2003
    Essex
    Astra Convertible
    Nice.
    Roofless.........
    I love Tintin, you love Tintin, EVERYONE loves Tintin!!!!!!!!!
  15. #39
    Oct 2008
    north west
    5 door corsa
    i was thinking about doing this in a corsa b
    would it be the same as mounting a 2ltr vaux engine?
    what gearbox have you used as i have heard that you could use a f20 or f28 box?
  16. #40
    Nov 2005
    Vectra C CDTI
    few pictures from the weekend cracking drive home and it does bloody shift
  17. #41
    Oct 2002
    South London/ Surrey
    A4 sport avant Clio172
    Great talking to ya and Kev
    www.shonkyopels.de
  18. #42
    Nov 2006
    Port talbot, wales
    Astra GSi ph1
    awesome mate.. you taking this to trax tomorrow? would really like to have a look at this and have a chat with you about it
    Valver power...
  19. #43
    Feb 2009
    peterbough
    Astra GSI C20LET
    is it alrite to cut the front out like you have done to fit the fmic . ? great work as well mate
  20. #44
    stt
    stt is offline
    Mar 2003
    Taunton
    Quote Originally Posted by astra-nige View Post
    Auxilary belt = the car had all the mod cons so air con and power steering where as the astra doesnt nor do i want them, removing the air con pump and rerouting the belt for that i can order from saab but i dont need the power steering pump this i solved by dismantaling the power steering pump and removing the blades from the pump it was then moun ted on the car filled with oil and then sealed at both ends
    so have you binned the air con pulley completely?
    How have you gone about making sure the water pump has enough contact with the belt?
    do you have a pic of your belt setup?
  21. #45
    Nov 2007
    Glossop
    c20let corsa gsi
    nice to see a differant conversion good work
  22. #46
    Jan 2008
    scotland,fife
    corsa gsi 8vt, nova
    ive seen one in a corsa! using the f20, well done m8
  23. #47
    Feb 2008
    n w lancashire
    vectra 2.2
    nice one mate, your rocker covers cheese shaped too lmao
  24. #48
    Jan 2005
    saab astra mk3
    thanks for all the comments guys
    the belt run for the pumps is just the standard saab route just without the aircon pump as some cars had no aircon so just ordered the shorter belt
    the panel cut out at the front is not a major problem with the strength but i have modified and run a bolt in section of box alloy to keep some strength in it
    sorry couldnt make it to trax
  25. #49
    Aug 2009
    scotland, fife
    GTE, 205 GTi, 84 SAAB T16
    love the saab power
    Turbo Jim
  26. #50
    Sep 2004
    Colchester, Essex
    Calibra LE 4x4 Turbo
    does the saab engine not use a air flow meter?
  1. 31-01-2013, 17:40
  2. 10-01-2013, 17:30
  3. 21-10-2012, 16:55
  4. 20-07-2012, 10:06
  5. 03-04-2012, 07:18
  6. 19-12-2011, 13:52
  7. 20-11-2011, 13:31
  8. 20-11-2011, 01:26
  9. 18-10-2011, 14:48
  10. 07-07-2011, 08:34
  11. 03-07-2011, 00:01
  12. 01-07-2011, 22:54
  13. 28-05-2011, 05:41
  14. 21-04-2011, 17:33
  15. 13-01-2011, 05:51
  16. 28-11-2010, 18:53
  17. 25-10-2010, 20:35
  18. 01-10-2010, 08:05
  19. 26-07-2010, 11:37
  20. 28-06-2010, 19:28
  21. 23-06-2010, 08:58
  22. 05-06-2010, 21:10
  23. 21-04-2010, 06:10
  24. 11-04-2010, 12:03
  25. 23-02-2010, 18:45
  26. 27-01-2010, 21:16
  27. 14-01-2010, 17:10
  28. 06-11-2009, 16:59
  29. 01-08-2009, 17:50
  30. 16-07-2009, 20:04
  31. 11-07-2009, 19:17
  32. 10-07-2009, 17:01
  33. 10-07-2009, 16:50
  34. 05-07-2009, 19:53
  35. 05-07-2009, 19:45
  36. 26-06-2009, 20:20
  37. 26-06-2009, 17:12
  38. 26-06-2009, 16:22
  39. 26-06-2009, 08:46
  40. 23-06-2009, 16:21
  41. 23-06-2009, 05:14
  42. 23-06-2009, 03:00
  43. 22-06-2009, 22:34
  44. 22-06-2009, 18:44
