Project "Monty"
Page 5 of 34 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 ... LastLast
Results 101 to 125 of 848
Thread: Project "Monty"
  1. #101
    MIGWeb Technical Moderator Dale's Avatar
    Jul 2006
    Swindon
    Monty / Vinnie (AstraVXR)
    Re: Project "Monty"
    Quote Originally Posted by corsakid View Post
    good progress mate should be a nice engine bay once finished with all the hoses!
    yer thats the plan cheers
    Quote Originally Posted by spankyjames View Post
    im so jealous of you dale, wish i had that sort of money to buy all those parts, top work mate keep it up
    bet you are i work hard for it tho
    Quote Originally Posted by ianofbhills View Post
    Looking like this is gonna be great. It was already mint with the xe in.
    Any gen on the bushes.
    where from and how much for the full set?
    are you running a front anti roll bar on this (with poly bushes) ?
    thankyou i got them from CAM ages ago, i won't be running a front anti roll bar this time, was always meant to take it off, apparently they handle better without so i wanted to try it
    Just deleted loads on photobucket so hopefully pictures will be back up soon
    Jul 2006
    Swindon
    Re: Project "Monty"
    Update:
    Got LET in tonight :thumbs: here are a few pictures
    Clearance is a bit of an issue tho.... :boggle:
    I'm using full CAM fitting kit with both the rear spacers on the inner edge of the rear mount (between the gearbox and mount), i have tried to shift it over as far as possible on the engine mounts, could anyone shine some light on this? (space by alternator and chassis leg + Top hat and brake pipes)
    This is just a mock build atm, engine will be taken back out for rebuild and engine bay will be painted
    Cheers Dale
  4. #103
    Jan 2009
    Wiltshire
    Corsa TD, DC2 ITR.
    Re: Project "Monty"
    I think another guy had the same trouble with the CAM fitting kit, I've got a multi v on mine, with more clearance than that. Mine has the M-Tech kit.
    Does look a bit tight.
  5. #104
    Jul 2006
    Swindon
    Re: Project "Monty"
    Quote Originally Posted by corsadonk View Post
    Joy..... anyone else???
  6. #105
    Jul 2006
    Swindon
    Re: Project "Monty"
  7. #106
    Jul 2006
    Swindon
    Re: Project "Monty"
    Update:
    Not massive update but more bits have turned up so i can crack on with the mock build this weekend, so should be big update over the weekend
    F28 short shift inc nylon bushes
    Some new vacuum hose off a 535d from work
    Forge 100 series intercooler with 63mm inlet/outlets, only been a 3 week wait.....
    Also had my Tx 3" top hat arrive
    Watch this space
    Cheers Dale
  8. #107
    Dec 2007
    West Yorkshire
    MG ZR
    Re: Project "Monty"
    I love this B. Just a few questions.... What steels are they? G60's? Also how did you restore your black plastic bumpers? Mine are all faded and horrible and i want to freshen it up. Any suggestions?
    Thanks
  9. #108
    Jul 2006
    Swindon
    Re: Project "Monty"
    Quote Originally Posted by forestfighter View Post
    Thanks
    yer g60's, i just use turtle wax back to black bumper shine but you can use a heat gun to bring the plastics back, sure it was is TV
  10. #109
    Jul 2006
    Swindon
    Re: Project "Monty"
    Update:
    Small update not really had alot of time to work on him but i really need to find time as its booked in at end of the month for the engine bay to be sprayed
    heres a few pictures of today progress
    Monty sleeping away under his temp cover
    mock fitting intercooler
    Radiator clearance
    Fitting and cutting the crash bar
    Mock fitting oil cooler
    Who needs a conservatory for sitting it........ its for corsa bits
    Cheers Dale
  11. #110
    Jan 2009
    Wiltshire
    Corsa TD, DC2 ITR.
    Re: Project "Monty"
    Looking good. But you may want to move the oil cooler over to the right a bit more, I smashed up one of my fans yestraday, with the bonnet catch
    But it looks like you've still got a bit of room above it anyway.
  12. #111
    Jul 2006
    Swindon
    Re: Project "Monty"
    yer the cooler isnt mounted yet just an idea for now, ill give you a ring tomorrow to talk
  13. #112
    Jul 2006
    Swindon
    Re: Project "Monty"
    Got more work done this weekend, thanks to mike (Corsadonk) for coming over Saturday
    Still in "mock" stages and all hoses will be black to match the roose kit i have already
    Started by cutting more of the crash bar off for the oil cooler
    Make some brackets for the intercooler
    3 inch top hat with roose coupler
    Although clearance isn't great....
    Removed the air box bracket
    Cut slam panel for 3 inch intake to turbo
    Rough route for the intercooler piping from turbo to cooler
    Rough route for the intercooler piping from cooler to top hat
    Mounted the coil and cossie webber fuel pressure regulator
    Modified the TX down pipe
    And final photo of the day
    Cheers Dale
  14. #113
    Oct 2009
    Yateley
    Corsa B 2.0l 16v
    Re: Project "Monty"
    great progress mate! starting to come on loads now
  15. #114
    Aug 2008
    Perth ecosse
    Red let
    Re: Project "Monty"
    This thread is great! Theres lots of good pictures
    keep up the good work
  16. #115
    rc
    rc is offline
    MIGClub Member rc's Avatar
    Jan 2007
    Felixstowe, suffolk!
    359.9bhp astra
    Re: Project "Monty"
    good work, great to see the extra time going into making it all fit nice and proper and brackets for everything, not just all lashed together and cable tied in
  17. #116
    Jul 2006
    Swindon
    Re: Project "Monty"
    Quote Originally Posted by daz1492 View Post
    Cheers
    Quote Originally Posted by carnegstar View Post
    Yer i try and take as many as i can so it helps people like other threads have helped me! Cheers
    Quote Originally Posted by rc View Post
    Thanks fella, thats the last thing i wanted. once its on the road i want to enjoy it not be fixing it every weekend
  18. #117
    Jul 2006
    Swindon
    Re: Project "Monty"
    As stated above I don't want to use those ****ty blue rubber 90's of the intercooler which are 1D bends, i did order some from Paul at Roose Motor sport but these are 2D bends
    Picture of the "1D" on left and "2D" Roose on Right
    So First thing Monday I spoke to Paul again and sent him the picture above and he said he can't do 1D in 63mm, only a 2D in silicone or a 1.5D in aluminum but i don't have a lot of space either side of the cooler to run joiners and aluminum pipe so a 1D is my only option. He then advised me to speak to Viper Performance.
    After ringing around I first tried SFS. Waste of time bunch of cocks didn't even want to help. Then i tried Samco and they just sent me round in circles
    I then rang Viper Performance and spoke to Mike, who was a great help and said they make 63mm 1D 90 bends Result So i ordered then and next day they turned up :thumbs:
    Here is a picture of all 3 hoses together:
    1D in rubber, Viper performance 1D and 2D Roose hoses which has been cut but you can see the difference of the tightness or "D" of the hoses
    I always use Paul at Roose Motorspot and I highly recommend them to anyone top service and great bloke always willing to help
    I would now also highly advise Viper Performance for great customer service
    So thats one thing of the list of long jobs to sort..........
    Dale
  19. #118
    Jul 2006
    Swindon
    Re: Project "Monty"
    Got more done this weekend, BIG thanks to Mike for making my oil cooler lines
    First job of the day Saturday was to fit my new 1D bends
    I also changed my piping from the turbo to intercooler as i couldn't use the alloy pipe as it was only a 1.5D and i really need a 1D
    Then Mike came over to make the oil cooler lines and once he received his cup of tea as always we started work
    Use compact connection for the cooler, we used 1/2 bsp lines
    Mounted to the car
    Then I use M6 threaded bar to make the mounts for the bottom of the oil cooler
    With the intercooler fitted and not touching it
    Then i Boxed everything way and started to remove the engine, ready for stitch welding and painting.
    Final picture of the day with engine and box sat on the trolley ready to be pulled out this week
    Cheers Dale
  20. #119
    Jul 2006
    Swindon
    Re: Project "Monty"
    Well got more done tonight although its been along night
    First off got the engine out
    I brought the LET a few years ago from "Valver" off Astra mk2 owners club and only had 5k since rebuild, new turbo etc which was fully documented on the forum etc but since then it just sat in my garage
    So i decided it was best to rebuilt it again so tonight i set about stripping it down and boxing and generally checking the engine over
    First off rocker cover off, all nice and clean here
    Late Engine
    Cam pulleys off and cambelt
    Caps and nuts and lifters boxed up and labeled
    Cams removed
    Head looks ok, i will take this to work and check with straight edge
    Pistons look good
    as does the bore
    Checked the piston to check sure they are standard size (86mm) Marked pistons before removal and matched the caps
    Big end shells look good
    In the box with some fresh oil
    All thats left on the block is to remove the oil pump and crank
    Garage is abit of a mess again
    Engine bits all boxed up
    The Plans for the engine is to do the bottom end once and be done with it, then I can work my way up from there when i want more power
    Plans:
    Overbore 86.5mm
    Low Comp Pistons
    Oil Squirters - Got
    Uprated Rods - Got
    Maybe Some work on the crank (is it worth it?)
    Z20let oil pump
    Arp Conrod Bolts - Got
    Arp Head Bolts - Got
    Lightened and balance flywheel
    Some more bits have turned up this week
    Another 1D bend
    My VEI gauges from America one oil temp and pressure and the other is meant to be wideband and Boost but they sent me wrong gauge and i only have wideband the correct one is on the way tho
    How they look with ignition on
    Adapters, pressure sender and oil temp sensor
    Wideband innovate wideband lc-1
    Then been speaking to Paul from roose again I needed a 76mm to 57mm reducer to go from AFM to turbo but Paul only did 76mm to 60mm but he said he would put a another slice of silicone to bring it down to a 57mm, top works once again
    Then I also ordered a 76mm Coupler to got from AFM to inlet, now thats every possible hose i can think off in the engine bay done and in black silicone
    Ordered some more Mikalor clamps
    Well thats all for tonight, hopefully get loads more done over the weekend etc :lol:
    Dale
  21. #120
    Apr 2007
    Bradford
    Vectra B C20LET :)
    Re: Project "Monty"
    Looking good .
  22. #121
    Oct 2009
    Yateley
    Corsa B 2.0l 16v
    Re: Project "Monty"
    Should go when its done when are you plannign to get it on the road all fully built?
  23. #122
    Jul 2006
    Swindon
    Re: Project "Monty"
    Quote Originally Posted by Olsrey View Post
    Looking good .
    Cheers
    The plan is the end of April but the first show is at the end of May, so there will be loads progress over next couple of weeks
  24. #123
    Oct 2009
    Yateley
    Corsa B 2.0l 16v
    Re: Project "Monty"
    awesome, the car becoming the main priority at the moment then?
  25. #124
    Aug 2008
    Perth ecosse
    Red let
    Re: Project "Monty"
    Do all the let engines not have the same setup like the later xe? looks nice and clean in there.
    I like the oil cooler hoses, very neat!
    Now you just need some braided brake hoses to go with them
  26. #125
    Jul 2006
    Swindon
    Re: Project "Monty"
    Yer is at the moment got loads to do and not alot of time
    Well after talking to steveboyslim there are different versions on later engines The redtop i had in before was an early version.
    Cheers, they were made my Corsadonk of here Dont worry the rest of the car is getting full treatment aswell
