Nice work mate. attention to detail is great.
Very nice dale... Mr motec loves you at the moment... I m deciding wether or not to go for a motec m600 etc
Built by Pete Burgess, Mapped by Dave Young
Coming along very well.
Performance Vauxhall Show - HERE Please click for more information.
VBOA at Billing - HERE Please click for more information.
I'll pass steves details over if you want, he will tell you want you can and can't do and whats best for you!!!
Cheers Fella
On to making the engine loomAfter measuring the loom up Steve came up with this..
Then started...
And you end up with this at present 95% done....
The "main man"
Then it was time to test the M400 and CDL3, setup on the bench...
Plan is to get him up and running over the jubilee bank holiday weekend as he is booked for mot Wednesday.
I thought I would clean a spare rocker cover out and have it sprayed as mine always had a chip in it..
With breather plate removed
Plate refitted
SBD breather mod swapped over from last one
Had it painted in white with breather to sump done black (all cleaning was done after spraying ensuring all the crap was removed...
-8 tank of for catch tank
Last few bits turned up from Roose motorsport, vacuum hose with internal diameter of 6mm (external waste gate, DV) 4mm internal diameter vacuum hose, 13mm internal diameter hose for "Mod" to the inlet as seen in previous posts!
Busy weekend ahead as all my powdercoating is now done, picking that all up tomorrow![]()
Nice work mate, wiring loom is a work of art
Cam cover looks great, i can tell it will be a joyfull moment connecting all those plugs into the car
That's alot of boxes to ram under the dash...lol
finished yet?
#No1 In the TINTIN Fan ClubEin Projekt, das ist eine nie endende Entwicklung
Daily - Vectra C 1.9 CDTI (120bhp)
Track - W Reg Mk5 Zetec-S Fiesta
wow what a project corsa awesome car
corsa c20xe project
Yer i'm well happy with it
Cheers, oh yes I can't wait to drive it again
hahah Ben, thats a rig so it simulates RPM etc etc only the ecu going behind the dash
Loom is finishedPlan to get him going this weekend
Thankyou![]()
Excellent work dale.. Looks superb
Christ... Just looked at the going rate for an E39-M5 !
Oh i took it the 3 black boxes did too. Not to bad really then..
Cheers
Nah they do other things and were just on the side
Been working flat out recently probably doesn't look alot but its so close now
Picked my last parts up from powdercoating. Shafts with some new CV's. Built them up and fitted and fitted my new knuckles with VW/Audi wheel bearings (No pictures, shocking I know)
Steve finished off the dashboard loom
Made nylon spaces for the dash to be mounted
Added felt tape to the inside of the carbon not to vibrate
Fitted to see how it looks with trim surround
Plugged to and powered up to test, Screen needs to be setup to display all features still
Then got onto fitted the engine loom, mounted the fan fuses and relays out the way
A few snaps, we tried to hide as much as possible within reason!
Baffled catch tank with -8 fittings
Mounted
How the line will go, need to order 90 swept for the catch tank
How I left it, ready to turn over tomorrow to get oil around and do setup for starting....
Great progress, can your mate get an m600 ?? Can you ask and pm me a price dude??
Look very good and very tidly installed.
You gonna be finished for PVS Dale?
*****Owner and creator of the lowest Zafira GSi in Europe...also featured in Total Vauxall issue 134*****
getting there
I'm doing everything I can to make it there with him!
Been mental couple of days.... I rebuilt the front end, wings and bumper. My current bumper I ruined cutting to far but i fitted to get me for mot tomorrow.
Made a temp catch tankput wire wool in there to help
Time for some gearbox oil would been easier to do this before oil cooler was fitted but oh well
Tool for the job
Fitted gps wiring for dash, gps was hiden under boot carpet
Tapped into dimmer switch for dash to dim with interior illumination
Steve came over we sorting timing etc, cranked with plugs out to check good oil pressure with fuel disconnected. Then primed the fuel system to check for leaks, all was good! This was also done with feed disconnected at rail to check lines were clear! There was also lots more calibration but I will be here forever writing about it....
Before start up safety first...
little shot of the laptop checking the whats been logged after the car had been run for a bit, it took a long time tinkering etc...
Another shot of dash with car running
then once everything was double checked it was off for quick lap round the block just checking it was safe to drive to mot station tomorrow, few tweaks here and there and now he is ready for tomorrow...
Still along way off but its a positive step....
fantastic work and your attention to detail is truly outstanding
great news mate that its up and running
total vauxhall cover car october 2012, 10.6 sec quater mile@137, uks quickest corsa b
