Looking good Dale, glad your pleased with them.
Welding and fabrication, custom roll cages, cnc parts + lots more PM me
what left to do now mate
total vauxhall cover car october 2012, 10.6 sec quater mile@137, uks quickest corsa b
pv looking good then?
Haven't missed PV yet admittedly I have been working day and night and normally putting last bits on the day I leave for PV. First year i went with monty (09) I done a total of 2 miles before PV lol
Great work mate.
Coming on very very well.
Performance Vauxhall Show - HERE Please click for more information.
VBOA at Billing - HERE Please click for more information.
Looking very good mate. Great work as always.
Previously known as Ted_16v_Corsa and Ted_CDTi
Cheers fella,
Little update nothing great....
Got some new shorter lower arm to ball joint bolts as I had spacers before
Had alittle play with adjustment of caster....
Wheel and wing placed on
Then got my new Big block hub flanges (Not conversion hubs) and knuckles back...
Knuckles with part grinded off for clearance for Alcon brakes
These will be powder coated now
Then I carried on with Dash mock...
Feel Wet lay carbon 1mm thick (Not crapped "carbon wrap")
Cut out to go into housing
Cut out for dash
Front face on with the motec shift lights/warning lights at top can only just see
Looking good Dale. Dash is going to be sweet !
Do like the dash. Will you be going the Audi bearing route?
Not checked this for a while, but its gone mental spec!! love it!
Nice, i like the Audi bearing thinking.
Love it. Just read all of itKeep up the work, will we be seeing this at Billing?
Really not for me....
Got a few more bits done...
First off modified the rocker cover to take -8 for the catch tank and the small breather will be blocked
Then on to my lockable aero catcheswhat a pain in the ass to do....
Getting there slowely
Mike popped round to make the oil cooler lines tooTop job thankyou...
Picking up the intercooler pipes from welding Monday and Steve @ GWR Motorsport is coming around Wednesday to measure the loom up![]()
I fitted my aero catches were a pain in the ass 2. Nice work mate.
Been getting on with few more bits
Got parts back from welding
Pre cooler intake temp sensor boss and DV take off
Shortened Brackets on baileys coolant tank
Also got small breather blocked on rocker and -8 fitting welded on for catch tank
Checking fitment
Getting there
Made new adapter for EGT boss as I wasn't happy with first one....
Steve made new earth for the alternator
Mounted the Map sensor up out of the way
Mounted ignition amplifier, ground paint underneath and used heat sink bonding paste to create good connection.
Mounted boost controller solenoid valve
Mounted Batter + joining post
looking good, the bays getting fuller and fuller lol
Little update and its get expensive
Motec GPS for dash
Motec M400 ecu with many options ticked
Motec "high" spec shift light model
Motec communication adapter and lead
Motec CDL3 Dash
EGT Adapter and loom
Wiring loom for the car, includes wiring for external fuel pump, connector ready for a 3rd fuel pump(won't be used yet) and connector ready for rear wheel speed sensors for Traction control (use as a reference point.)
Battery + and Battery -
Engine earth and alternator earth
Fitted battery + and - and plumbed in
All hidden and where it comes out
Fitted EGT sensor and loom
Fitted fuel pump wiring loom
New vaccum take off from TB, which was the old air temp sensor
Found some bungs that are used on BMW's to block the unused vacuum take offs
Thats all for now, the engine loom is currently being made![]()
Can't see any pics but I suspect you have just spent more money on motec parts than most people have spent on their whole car LOL
