Great project this, been watching this for a while.
Looked great at PVS last year and looks like its gonna be even better this year if your going?
Keep up the good work!
I will be indeed with Monty too he has been entered to Power N Style awards too...
Update time again...
Since reading Nic Barnes issues with mocal oil cooler sandwich plate, I have since taken it back and will run standard plate for now, If I suffer with high oil temps I will change for billet plate with remote stat and go from there like most things its trial and error
Rude not to put it through the parts washer
New filter as always
All fitted
Few bits to finish fuel system off
Inside
and underneath
Now was to sort oil return from turbo, fenny used rubber hose which IMO wasn't for me! I had some spare fluro silicone hose so i adapted that....
Old vs new
Measuring up
Then heat wrapped and used aluminum heat wrap tape to finish it off. I will also do coolant pipe the last thing I want is a thermal event
Heat wrap matting
Also did the breather to be safe
Location for EGT and wide band (Not fitted correctly yet.) I have a spare boss now as I will no longer be using a separate wideband as its built in the motec
Rebuilding
Next onto air filter location.....
Either normal place
Or looped around down the inner wing
Picked up couple for sensors (Air temp, post rad temp and Map sensor) Also machined the rail adapters and oil pressure to block adapter
Where i'm currently upto
The artist previously known as X20XEV
Project: Gold Snowplough Turbo'd Nova
Project: Mexico Red Cavalier
Any 8v or Vauxhall^
Looking big Dale and awesome.
Performance Vauxhall Show - HERE Please click for more information.
VBOA at Billing - HERE Please click for more information.
Had a little more time this evening...
Sorted out my coolant feed and return and heat wrapped like the oil return
Also did my turbo outlet joiner to boost pipe as this is close to the downpipe
All fitted
looks fantastic so will this or vinnie be at Billing?
#No1 In the TINTIN Fan ClubEin Projekt, das ist eine nie endende Entwicklung
Daily - Vectra C 1.9 CDTI (120bhp)
Track - W Reg Mk5 Zetec-S Fiesta
Im available for taxi duty lol
That turbo and manifold mega great attention to detail.....very nice ...![]()
That's from that online epc, which has worked every time for me.
good work on the turbo systems
If that's deffo the part number I can call up the dealer and get a price... that or AutoVaux.
EDIT just checked the number![]()
Been busy again first off was to design a sump plug to take new oil pressure temp sensor, as the temp sensor uses M12x1.5 trying to find adapter to M14x1.5 (sump plug) was hard enough and one that had enough "meat" to drill and tap a thread was impossible! So popped to Steve's (GWR Motorsport) and we designed this....
Adapters next to standard sump plug
Together
Also bought post radiator temp sensor housing to help monitoring....
Next I got to work with the Motec CDL3 dash, I want it to look as standard as possible, so it was time to start cutting and grinding, this is only a mock...
Rough placement with all standard dials removed and lugs
Done some more work to mount the shift lights but no pictures will update with more progress on dash soon
Mounted battery box
Again, why dont you fit the oil temp sensor in to the oil pump? As that is the moving oil, not what's left in the sump doing nothing....
Because its pressurized and it won't be as warm as the sump and the sump will tell me the temp of a large amount of the oil rather than a small amount... 90% use the sump to monitor oil temp just not the plug.... I could have had a boss welded on the sump but I didn't want to remove it as its currently not leaking (runs and touches wood)
Oh right.
Looking good Dale, going to be a very well sorted car !
Welding and fabrication, custom roll cages, cnc parts + lots more PM me
Been doing a few more bits over the weekend
Carried on this the dash, heres whats left on inside
Trial fitting with shift lights/warning lights
Got my bracket back from powder coating
Started to rebuild and cut light panel to allow room for coolant hose
Also shortened by vac hose for master cylinder
On the rebuild
Got my intercooler pipes "bead rolled"
All on and mock fitting Tial BOF
Then got these from jonlem, rose jointed lower arms and track control arms (note the TCA are placed the wrong way around here)
Lower arm
All fitted, I have kept from spacer plates as it gives me clearance from intercooler piping. Lower ball joint spaces don't fit but this isn't an issue as the lower arms clear with F28 fitted due to different pick up points. The chassis was drilled for 1/2" bolts for lower arm which was fun with engine in. In the end I removed the engine mount and lifted either side to make sure the chassis was drill straight! Over all very happy with the kit and quality of welds!
Fitted post radiator coolant temp sensor
Fitted air temp sensor in the oil cooler housing
Getting there slowely
Coil fitted with leads
All for now![]()
Top work as always mate![]()
