Corsa GSi...(Long Term Project)
Page 9 of 10 FirstFirst 1 2 3 4 5 6 7 8 9 10 LastLast
Results 201 to 225 of 241
Thread: Corsa GSi...(Long Term Project)
  1. #201
    Jan 2008
    Lancishire/Manchester
    Piaggio/Corsa/Honda CBR
    Re: Corsa GSi...(Long Term Project)
    Decided to do some work on the bay today, decided to cut the rust bits out and the cut out the areas for the smoothing of the bay and removal of the battery tray
    As it started from where I left it
    battery tray removed
    Rusty patch around the brake servo mounting point
    chop chop.....
    chopped off lots of other bits that "arn't needed" quite enjoyed being in the sun today too which was a plus then decided to make some tea and gave it a quick coat of primer just in case I don't continue tomorrow to protect the bare metal from the elements
    Still lots more to do on this, may be measuring an making the plates that need to go in to get the look I'm after tomorrow if tomorrows plans change.
    Just bring me Tea & Biscuits an a ciggarette............ nothing more....
    Corsa GSi Long Term Project >> http://www.migweb.co.uk/forums/proje...project-9.html
    Jan 2008
    Took delivery of my pedal box this morning was an absolute steal at the price I got it for
    Some pics -->
    0.625
    0.7
    with the rez cups on
    Thats that for the mo
  4. #203
    MIGClub Member RodOGW's Avatar
    Jul 2009
    Norfolk
    Calibra 2.0i 94
    In case I've missed anything - is that for a dual braking system so you can alter the bias? Looks good - is it going up inside the dash?
  5. #204
    Jan 2008
    Quote Originally Posted by RodOGW View Post
    yea sort of mate it replaces the servo diaphram and standard single master cylinder which is removed and this bolted in its place, thought it would be a good idea to uprate due to the willwoods needing more juice and I can fine tune the balance with the aid of a bias tap will get some pics up of how it goes together in the next few days or at the weekend
  6. #205
    Jan 2008
    Today decided to build up the pedal box for the brakes and strip the old unit off and paint up so it looks nice.
    The original OEM brake master cylinder setup
    Striped down to its parts to clean up & paint the bits being reused
    Cleaned up the mounting plate and painted
    Built back up with the new pedal box in place
    And all wrapped up to keep it tidy till fitting time
  7. #206
    Jan 2008
    Well today I've been busy in prepperation for the next few months where the Weather is likely to turn a lot colder, organising/tidying best I can my work area in the shed, as I plan to do most of what I can in there to keep warm (buying a heater soon), also got some new marine ply roof panels coming to fix the leaking roof, and also to build the storage extension to the shed
    I also took the time to wrap up all the car pannels and trim (and other stuff) bits as best I can to protect them and make them a bit easier to store,
    heres what some of it looked like bloody loads more wrapped but was that bored of it couldnt be bothered to take any more pics -->
    Off to Topgear Live and the Nec Classic car show next week so going to have a root throught the stalls too, so may be returning with some new bits to add to the collection...... hopefully
  8. #207
    Oct 2009
    Yateley
    Corsa B 2.0l 16v
    Good stuff James
  9. #208
    Jan 2008
    Quote Originally Posted by Daz H View Post
    Good stuff James
    Ta mate ........nearly time to get the russian hat out again lol
  10. #209
    Jan 2008
    Right first off some new bits I got last week for the car while at the Topgear & NEC Classic Car show-->
    HID Kit
    HeatShot washer jet heater
    Today decided to empty the cars interiour, had a suprise when I Lifted the cover off the car to see this......
    ..........clever sod managed to get in thru the opening for the brake pedal, left loads of hair on the seat too lmao
    Then got the seats an other trim that was already removed n just stored in there out, then pulled the carpet out,
    Then got side tracked n started to take some of the sound deadening of with the scraper,
    few rust holes
    then realising it was getting dark and I had all the interiour piled up and not wrapped up ready for being stored, decided to break off and wrap it up and put away before all the light went
    Thats it for now gonna take the dash out and attack the sound deadening next weekend then cut the rust out of the floor
  11. #210
    Jan 2008
    Well never got round to doing what I planned last week, but got a good bit of last weekends work done today, and bonus again was it was inside the car so wasn't cold or wet as it's been raining all day
    Anyway I spent quite a few hours removing the sound deadening which annoyingly unlike all other cars I've stripped sound deadedng out of didn't come off in big chunks, rather it was like chiseling tar got near enough all of it off looks like this at the mo -->
    And can now cut this area of rust out wich is the worst of the floor rust
    gotta few small spots of the sound deadnig to scrape off but ran out of power in the torch, so will do that tomorrow and then take the dash out
  12. #211
    Jan 2008
    Not updated this in a while been upto a few bits on the car over December, basicly gutted the rest of the interiour and stripped off the rest of the sound deadening, then painted it up, leaving the areas that are bing cut out or that ar gonna get burned from the welding (they will get a coat of paint once the fresh metal is in)
    And now with paint on, finish of the paint isn't critical as its gonna be covered over anyway, got it in everywhere a good few liters gone into this so far
    Also been getting more bits, got a pair of equal length drive shafts, off a member on here and the center shaft is on its way from another member, also bought some rear discs with hubs etc will need a refurb but not bad for the price also got a set of std rear lights offa member of here too
    Also got an F28 gearbox on its way bought from a member on here
    Next up the grinder is coming out gonna start cutting out the rust......well that is once I've finished chopping down and cutting up the trees that fell over in the back garden .........will update in due course
  13. #212
    Oct 2009
    Yateley
    Corsa B 2.0l 16v
    Looks good James! You've done quite a lot since I last looked! Sound deadening sounds like a right cow to do!
  14. #213
    Jan 2008
    wasn't as bad as the underseal still not somthing I would rate as fun thou
  15. #214
    Jan 2008
    Well had a very bad day today got the kind of news we all dread at the moment
    But had something that raised a smile when I got home from work my F28 gearbox had arrived which I bought off a nice member on here very pleased with it,
    Going to clean it up tomorrow as I've got a day off work I'll update in due course
  16. #215
    South East Regional Co-ordinator
    Apr 2011
    Sheerness, Kent.
    2003 Arden Zafira GSi
    Hope the bads news ain't to bad mate.
    Welcome to the jungle we've got fun and games.
  17. #216
    Jan 2008
    Quote Originally Posted by Ardenblueroy View Post
    thanks mate I'll find out in 29 days already know the answer thou
  18. #217
    Jul 2003
    Skelmersdale, Lanc's
    A4 Avant sline,Corsa LET
    Some good work there mate.. Do you work for bae by any chance?
    TOTAL VAUXHALL COVER CAR, SEPTEMBER 2008
    PS3 Online Tag:- VAUXBOOST
  19. #218
    Jan 2008
    Quote Originally Posted by Col004 View Post
    cheers mate, gonna clean it up today, not for bae no
  20. #219
    Jan 2008
    Right yeasterday started to clean the gearbox up, only a few stubbourn areas that need finishing off then I can paint it up
    Started off like this
    Now at this stage, a lot less greasey/oily
    Also this arrived today in the post the driveshaft center shaft
    Thats it for now
  21. #220
    Mar 2010
    Stornoway
    mk4 Astra Van :)
    good project mate! fair play for doing it all outside!!
    Vauxhall Astra Van 1.7DTii- T22 JFF
  22. #221
    Jan 2008
    Quote Originally Posted by Th0m45 View Post
    cheers mate not too bad outside ......with the heaters on that is
  23. #222
    Jan 2008
    Few bits arrived today
    A nice TIM boost gauge
    And the XE/LET wireing blocks
  24. #223
    Jan 2008
    Today cleaned off the rest of the stubborn grease/gunk/oil with a strong cleaner and then started to paint up the box to make it look nice, not finished it yet few areas need a touch up and got to paint the Getrag emblem and the bolts, not many pics as got carried away like ya do and forgot anyway >>
    and how it looks at the moment >>
    Thats it for now cheers
  25. #224
    Jan 2008
    ventured out today to pic up my paint....
    nice rich red colour
    though not being painted yet hope to get something done tomorrow...... hope no more snow decides to add to this :/
    thats it for now
  26. #225
    Jan 2008
    Mounts arrived today, need a good refurb, clean up with the sandblaster should do the trick
  1. 25-09-2011, 21:20
