Page 3 of 3 FirstFirst 1 2 3
Results 51 to 73 of 73
Thread: MK2 Cavalier Project
  1. #51
    Mar 2004
    Nr Exeter, Devon
    Astra GSI 1993
    Re: MK2 Cavalier Project
    Come on mate we're all waiting for some progress , Like mine, I've done a bit but not posted anything up yet, if you fancy popping over Bow, or you need a hand, let me know mate
    Aug 2008
    Cambridgeshire
    A fleet of Griffins...
    hi mike! any progress on the mk2 lately?
    - humbucker's satin red cavalier turbo WIP: http://is.gd/74Bgsf
    - humbucker's cavalier v6 WIP (pic heavy): http://is.gd/Vq105d
    - humbucker's 2004 Irmscher Omega 3.2 MV6 project: http://is.gd/ghpBhW
  4. #53
    Sep 2004
    Devon
    Cav V6
    Hello all, sorry for the delay. Some progress and some pics
    I haven't done as much as i'd hoped but, i am getting there with the wiring. It has turned into a bit of a nightmare. I have removed so much excess wire and nearly 30 scotch locks!!! The coolant fan wiring had been bogged and the fuse had melted in the fuse box its selt. The fuel pump wiring had been bypassed with bits of the orignal system there. Theres a plug for the instument cluster that wasn't much good. Then in general the wiring isn't to bad just needs re heat-shrinking to make it look better.
    I have almost finished the wiring for the immboiliser. I have just got to connect the earth wires to the body. I have started to connect a plug in the engine bay to all of the warning lights on the dash, rev counter gauges etc. I have an omega loom im stripping down so i can keep the wires the same colour. I have removed some wire to wire up the the fuel pump to the correct relays. The connector block after alot of messing around has most if not all the wires labbled as to what there function is so im just making sure i have got the right wires on the mk2 loom then its just a case of connecting them. Its been a bit of a pain but im getting there, i have a friend giving me a hand too sort it out.
    Still no luck with the radiator and fan problem. Im putting in the driveshafts, suspension legs and subframe and connecting the steering ready for its first try. I have clipped all the fuel lines to the body except one cause im one shortlmao Then i will put a couple on the bulkhead when i can reach lmao What im also going to be doing soon is making a rear stabiliser mount for it on that offside.
    I have got some braided brake lines being made up for me so when they are done i just have to connect the handbrake up then the rear will be done, via the fuel filler neck.
    i dont think i have forrgotten anything i probably have though So I have some progress and now its very nearly ready to turn that key to start! The igniton side works and all the loom gets powered up
    Thanks for looking and being patient
    I havent got a pic of the PAS system i forgot and its raining again so i'll get some sunday.
  5. #54
    Mar 2008
    Fareham
    c20let corsa
    Great thread mate! Keep up the good work!
  6. #55
    Sep 2004
    Devon
    Cav V6
    Quote Originally Posted by Richiedick View Post
    Cheers mate.
    Here's a couple of pics nothing of great coolness, just the mk3 8v pump inplace of the vectra one. It fits the same just the pulley is slightly smaller but the belt still fits fine and the tensioner is not right back so its nicely tensioned. I might as well try it Just a pic of the PAS bottle to. I made a bracket for it so it can be removed if need be, if i need to do any work and its in the way. So about the poor pics and stuff being in the way.
  7. #56
    Aug 2009
    Devon/Somerset
    Vauxhall Corsa Sport
    Your doing well babe
    Hurry up and get it completed though so I can drive it hehe
    Love you xxxx
  8. #57
    Sep 2004
    Devon
    Cav V6
    Quote Originally Posted by corsagirl2009 View Post
    Love you xxxx
    Thanks hun, lmao we'll have to talk about that lmao
    Love you xxx
  9. #58
    Aug 2006
    Derby
    Lots of Cavs.
    Looking good! This is going to be a beast when it's finished!
    "I'm always in the s**t.... Only the depth varies."
  10. #59
    Sep 2004
    Devon
    Cav V6
    Quote Originally Posted by himselfunknown View Post
    Cheers mate.
  11. #60
    Nov 2007
    monster lol and i hope i get a drive too lol ill get those brakelines made up for you i just need you to give me the chassis number again lol as i had it on my bench at work but at some point when i was off last some chump must have thrown it away lol
  12. #61
    Sep 2004
    Devon
    Cav V6
    Hi all i have some news and progess for you. Sorry for the delay but I did get some work done the other day!
    I have mainly been doing the wiring to get the engine running. Which im pleased to say is nearly done as its driving me crazy! It doesn't look as messy as it does in the pic but obviously its got to be tidyed out the way etc. I have had an extra pair of hands so big thanks to Phil
    Theres just a couple of wires to connect then the engine will be wired up, and theres a Diagnostic connector intergrated in too along with, all being well the dash and gauges should be working too.
    Aswell as that i have been removing old wiring that isn't needed and repairing old and damaged wiring. It looks like its had alot of things bodged up i have taken off over 30 scotch lockslmao
    I have started to put the front suspension back up so i can test drive it down the drive
    I have my nice Goodridge braided brake lines (thanks mike) to go on too with a new pair off metal brake lines.
    The next things on the to do list are:
    Finish the wiring, Weld up the engine mount, repostion a rear engine stay bar, put the fluids in the engine, connect the handbrake, brake pipes on the back. Then start to paint the rest of the suspension.
    I dont think i have forgotten anything i have taken some picture which are below. I still have to take somemore.
    Watch this space
  13. #62
    MIGClub Member peebs's Avatar
    Jan 2010
    Chepstow
    Corsa GSI XE/ C16XE Corsa
    Devil Re: MK2 Cavalier Project
    Looking good mate will be an animal uleashed
    "It's not about what you can BUY, It's about what you can BUILD!"
  14. #63
    Aug 2008
    Cambridgeshire
    progress is progress, good work mike, glad to hear things are back on track
  15. #64
    Sep 2004
    Devon
    Cav V6
    Quote Originally Posted by peebs View Post
    Quote Originally Posted by humbucker View Post
    Thanks chap, yeah i know its been slow but hopefully now i can keep at it then get it sent for bodywork when its all running and working
  16. #65
    Aug 2008
    Cambridgeshire
    hey man i know all about 'slow', ive done almost zero work on my cav other than buying and stockpiling parts this year due to other non-motor related projects. hopefully get back on track myself the towards/in the new year
  17. #66
    MIGClub Member jav786's Avatar
    May 2002
    Yorkshire
    Vec GSI/Evo IV/Cav T
    nice work mate
    If you always tell the truth, people will stop believing you!
    http://www.iconperformance.co.uk/ - Vauxhall Specialist Tel 07962398027
  18. #67
    Nov 2009
    Biggleswade
    Nova GSI, Corsa Sport XE,
    Just had a quick look through your project, nice work there. Engine looks snug in the bay!
  19. #68
    Jun 2010
    sunderland
    vectra b estate dti
    going to be sum car
  20. #69
    Oct 2004
    Oban - West Scotland
    Astra G/Nova TB
    cool project!
  21. #70
    Sep 2004
    Devon
    Cav V6
    Thanks chaps hoping to get some more done this weekend
  22. #71
    Aug 2008
    Cambridgeshire
    looking forward to the next update, mk2s rule. there's a nice one in total vauxhall this month.
  23. #72
    Oct 2006
    Glasgow, United Kingdom,
    All sorts
    looks awesome mate good luck
    If it has wheels im happy!!!
  24. #73
    Sep 2009
    Falkirk
    This will be awesome when its finished. I have 2 mk2 cavs, a gl saloon with a redtop and an estate with a calibra v6 engine. Your car will definatley be worth the effort, the look on peoples face when they get over taken, and the noise of the v6 is wonderfull. Are you a member on MK2CAV.COM - Home of the MK2 Cavalier
