I think the bonnet alarm pin is too high up to be plugged into that Ste
rick with the sunroof, what is it that stop the cage being fitted? is it where all the mech goes for the roof to drop down? if so would it be posible to fit one of the old type aftermarket sunroofs maybe from a scrappy?
I had forgot how much i hated removing this ****!
Back in the scene
Take two!![]()
IIRC if it has a knock sensor then it doesn't have a RON plug.
Just cap and stowe the wires in the loom... that plug is the shorting point to test the fan on the rad. so if your fan is'nt kicking in, you can short 2 of the pins out (i think 5 and 6) and the fan fires up, then you know the temp switch is goosed in the rad or if it does'nt fire up your fans goosed..
TOTAL VAUXHALL COVER CAR, SEPTEMBER 2008
PS3 Online Tag:- VAUXBOOST
nice purchase rick
http://www.youtube.com/user/1muppetsport
http://www.facebook.com/pages/1Muppetsport/125016194265586?sk=wall
what do you use to get rid of the tar that is left after removing the sound deadening?
If you dont have anything percific then give it a go with some petrol. I used this on my nova and it worked very well.
c20xe looms converted to plug and play for corsa conversions - £35 pm for details
Tech2 Diagnostics, service light reset, Key coding, £20 Southampton
Got some thinners and some panel wipe twag but if that fails then i will try petrol. Thanks for the advice.
Engine coming out today, Lee is comeing round to give me a hand, should be a bare shell soon with no PETROL tank in it! hahaha.
Back in the scene
Getting there now mate
are you sure you need to take the petrol tank and fuel lines off?
Nice step forward.
Couldn't think of anything good to put in here.
Started today rubbing the tar leftover pap off but soon got bored:
Then Lee turned up and we went from this:
To this:
And also removed this!!:
The inside at the moment:
Back in the scene
Looking good dude. Be out in it soon. Jack, mines got both...
looking good rick. Be nice to see it all caged and painted.
Ive found the best way to get rid of tar mat ****e is with a hammer and a thin screwdriver. Gently tap all over the tar mat with a hammer, then it just chips straight off in big chunks and leaves no reside behind![]()
Ive found a heat gun, 2" flat scraper and celly thinners works the best done about ten race car builds now, and i keep going back to this system... they all work though
Gonna have a go at the front footwells tomorrow and see how i go on. Thanks for the tips though, been using a heatgun and 1" chisel and boy does the middle of my hand hurt at the minute!
Started stripping out the sunroof stuff tonight:
Got a bit bored after doing this bit though so going to go tomorrow for some new cutting disks to get the rest out. Have thought about the hole it will leave though. To get me up and running i am either going to use a window seal to stick a bit of perspex in the hole, or have a bit of alloy cut and bond it in from underneath. Dont really fancy a £400 bill for a roof at the min and i just want to get the car up and running first.
Back in the scene
I just cut a bit of ali and riveted it over the hole that the sunroof left in the manta.
Brian Sidebotham.
It was a right pain stripping all the inside out of my one.....O wait lmao
Rick nice work!![]()
www.shonkyopels.de
