Closed Thread
Page 6 of 61 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 56 ... LastLast
Results 126 to 150 of 1518
Thread: Track day corsa turbo build
  1. #126
    MIGClub Member Fow16v's Avatar
    Feb 2006
    Pontypool, S.Wales
    Mk4 GSi Van
    Re: Track day corsa turbo build
    good to see you got one, when you picking it up and progressing with the striping of it?
    Macclesfield
    www.Retrobike.c
    Going for it at half 3 and i might start stripping the interior out tonight. Going for a slightly different plan with this one. Going to try and strip the interior out but keep it as a driver so i can drive it to jays to have the cage welded in and then drive it home. Should be able to do that all been well but we will see how things work out. Cannot really be bothered having to trailer it here there and everywhere.
    Back in the scene
  4. #128
    May 2004
    Manchester
    BMW E36 320 Coupe
    just fit a single seat and dash in. ask jay to take dash out when he puts cage in?
  5. #129
    Nov 2000
    West Yorkshire
    Astra Mk4 BwarpTish
    don't need dash in to drive it anywhere. the wires are fine dangling about; been there, done that. Plus Rick, if you want to remove all that crap on the floor again, the dash'll need to come out anyway.
  6. #130
    Macclesfield
    www.Retrobike.c
    Quote Originally Posted by DaveB View Post
    That was the plan, zip tie the clocks to the column bracket. Will leave the heater matrix in for now as i cannot be arsed dicking about with repiping the engine + its to cold to drive anywhere without heaters.
    Car will be a shell like before, but just a drivable shell! Will make sure fuel tank is removed this time lmaolmaolmao
    Back in the scene
  7. #131
    Macclesfield
    www.Retrobike.c
    Just collected it, its gonna make a spot on track car. Dropped a slight bollock with it but its easily sorted:
    Back in the scene
  8. #132
    Mar 2003
    bedfordshire
    astra coupe t8
    its got a sunroof!
    can you get away with that, or has it got to be plated up or..........?
  9. #133
    Macclesfield
    www.Retrobike.c
    Quote Originally Posted by thumbs View Post
    its got a sunroof!
    Its gonna have a bloody great sheet of alloy over it, or something a little fancy
    Spent ages looking at the pics on ebay and decided it had not got a sunroof, there was no mention of it in the description either so i gambled and lost!
    Back in the scene
  10. #134
    MIGClub Member donvaux's Avatar
    Jul 2005
    pontypool, s.wales
    Corsa VXRArctic, Combo
    nice one rick, the sunroofs no biggy i'm sure you can handle it now come on get out there and strip the bugger lmao
  11. #135
    Aug 2003
    Durham
    Ive seen quite a few sunroof panels replaced with a exact carbon fibre replica panel bonded in that looks good, better than a sheet of metal pop rivetted on, IMHO..
  12. #136
    Macclesfield
    www.Retrobike.c
    Quote Originally Posted by donvaux View Post
    I did think about starting it tonight but think i will start stripping first thing in the morning. Interior out first, then engine out, shud be a huge pile of parts by tomorrow evening.
    Back in the scene
  13. #137
    Jul 2005
    pontypool, s.wales
    good good early start in the morning then
  14. #138
    Quote Originally Posted by neo1 View Post
    Dont buy a performance trim one. Saw one of his and its not good.
  15. #139
    Macclesfield
    www.Retrobike.c
    Seen some of there stuff and it always looks good
    Back in the scene
  16. #140
    Dec 2005
    UK
    Frontera LWB, Astra GSI
    Can't you just weld a piece in the hole?
  17. #141
    Quote Originally Posted by Rick Draper View Post
    Same, but a guy i know had a sunroof blank(and f&r door cards) done for his 306 and you can see thru the weave, the gel coat has been badly put on and the edges are very badly cut/trimmed. Very piss poor.
    Quote Originally Posted by Jack View Post
    Its getting it weeled in well with out a lot of filler, the roof skin is very very very thin. Be alot better to bond a bit of something in.
  18. #142
    Macclesfield
    www.Retrobike.c
    I was looking at the performance trim door cards and roof skin. Will now have to think it over.
    Back in the scene
  19. #143
    Jul 2006
    Sutton Coldfield
    Fiesta ZS, Clio 172
    usually only A/C models that have no sunroof, one or the other you see, how did you drop a bollock BTW?
  20. #144
    Macclesfield
    www.Retrobike.c
    Quote Originally Posted by Gaz86 View Post
    Wanted one without a sunroof. Had thought this one had not got one as the auction never mentioned it and there was no sign of one in the pictures.
    O well could have been far worse.
    Back in the scene
  21. #145
    Mar 2002
    suffolk
    Corsa Tbo KTM SMoto
    does the engine run ok? how much you want for some of the sensors and AFM of it?
    www.wix.com/vxlgsi/zxr-750-r
  22. #146
    Wouldnt fit a whole roof, big waise of cash, just get a pannel to bond in.
  23. #147
    Macclesfield
    www.Retrobike.c
    I aint doing a full roof replace!
    Was just looking at the performance trim bond on panels. You cut all round the edge of the roof leaving a 2" lip and then bond it to that.
    Back in the scene
  24. #148
    Macclesfield
    www.Retrobike.c
    Quote Originally Posted by vxlgsi View Post
    Engine runs spot on, its only done 57k. TBH i was thinking about ebaying it whole.
    Back in the scene
  25. #149
    Thats what i mean, no point, just bond bit in to cover the hole, but make sure its a good bit of weave.
  26. #150
    Feb 2008
    eastbourne
    e30 sport,
    why didnt you email the person that was listing the corsa and ask if it had a sunroof before you bought it?
    still a nice little car though.
    Dirrrrty dog!
Closed Thread
