Closed Thread
Page 11 of 61 FirstFirst ... 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 ... LastLast
Results 251 to 275 of 1518
Thread: Track day corsa turbo build
  1. #251
    Macclesfield
    www.Retrobike.c
    Re: Track day corsa turbo build
    Did this today to save Jay having to do it:
    Still undecided on seat rail, will make my mind up tomorrow and if i get bored of drilling spot welds!
    Back in the scene
    Aug 2003
    Durham
    The owner of that black shell must be 8ft 10" LOL
  4. #253
    Oct 2003
    Nr St Ives, Cambs
    Pug 309 Cosworth
    What have you actually done there Rick ? lol
    Put the grinder down before you do something bad
  5. #254
    Macclesfield
    www.Retrobike.c
    Quote Originally Posted by jonlem View Post
    Used my dremel and a cutting disk to remove some of the standard bulkhead so the front triangulation can go straight to the strut top.
    Back in the scene
  6. #255
    Oct 2003
    Nr St Ives, Cambs
    Pug 309 Cosworth
    Any chance it won't have a 65mm hole to put a 40mm cage through this time ?
    There is a trick to it and it doesn't involve a hole saw lmao
  7. #256
    Jun 2004
    Twisk, Holland
    '97ComboD '93NovaTD
    Quote Originally Posted by Rick Draper View Post
    Still need to wipe it over with thinners or panel wipe
    Or with diesel Let it sit for a while, then wipe off
  8. #257
    Oct 2003
    Nr St Ives, Cambs
    Pug 309 Cosworth
    Quote Originally Posted by DutchNovaDiesel View Post
    Can't say I've tried that before but I will next time I have to do one !
  9. #258
    Aug 2006
    huntingdon
    E46M3/GSXR750/RWD SCOOB
    You dont come out no more lmao JOKE
  10. #259
    Oct 2003
    Nr St Ives, Cambs
    Pug 309 Cosworth
    Atleast your getting the hint lmao
    JOKE < insert crying face here >
  11. #260
    Macclesfield
    www.Retrobike.c
    LMFAO.
    Anyhow here is today update.
    Cut the other side of the firewall out today:
    Then got busy with the spot weld drill bit and the funking grinder:
    I am now officially sick of drilling spot welds and removing tar ****.
    Back in the scene
  12. #261
    Does the tar mat really weigh that much?
  13. #262
    Oct 2003
    Nr St Ives, Cambs
    Pug 309 Cosworth
    Over 4 kilos in a nova iirc, I was sad enough to weigh the bag of crap I removed from my nova lmao
  14. #263
    Mar 2006
    Wrexham
    jesus remind me never to remove that black sticky crap
  15. #264
    Oct 2008
    clackmannanshire
    track day nova
    good going rick nice clean shell u got there keep it coming.
  16. #265
    Oct 2003
    Nr St Ives, Cambs
    Pug 309 Cosworth
    Rick has actually done it the hard way by the looks of it, if you gently heat an area and use a paint scaper to get under it then gently heat an inch or so forward of the scraper you can remove it in massive sections without it leaving as much behind as his did.
  17. #266
    Macclesfield
    www.Retrobike.c
    Tried both ways, for some reason the stuff just does not want to come off!
  18. #267
    Jun 2005
    west yorkshire
    nova 1.6, + van
    It gets easier on older cars, mut be the time it has to harden and the road flex on chasis.
    I used to build grasstrack mini's and you could tap it with an old chisel and it all used to pop off!!!
  19. #268
    Macclesfield
    www.Retrobike.c
    Just had this delivered:
  20. #269
    Oct 2002
    South London/ Surrey
    A4 sport avant Clio172
    Nice seatage.
    www.shonkyopels.de
  21. #270
    Jan 2005
    Newport
    Focus LX
    Shexy seats.
  22. #271
    Macclesfield
    www.Retrobike.c
    Started with this pile of wires earlier and began thinning it out:
    Left it like this earlier on, about 60% thinned out:
    And this is what i had removed:
  23. #272
    Jan 2002
    Oswestry, United Kingdom
    Cbr 600 F
    how much was the seat rick?
  24. #273
    Macclesfield
    www.Retrobike.c
    Quote Originally Posted by Kev_cav View Post
    £300, not bad at all really.
  25. #274
    Macclesfield
    www.Retrobike.c
    Polycarbonate windows now ordered, gone for bronze this time.
    Floor clean up has been started, gonna take a while as its a fecking terrible job.
  26. #275
    Christ thats a lot of wire thats been cut out.
Closed Thread
