Nova build by Chris Astley Motorsport
Closed Thread
Page 1 of 9 1 2 3 4 5 6 7 8 9 LastLast
Results 1 to 25 of 201
Thread: Nova build by Chris Astley Motorsport
    Gagged
    Apr 2004
    Chorley, United Kingdom
    Mondeo ST TDCi
    Smile Nova build by Chris Astley Motorsport
    Im finally getting on with building my next nova, this is the shell which i started to use for the VXR engine transplant a while back, i decided against that project due to lack of time and as a competition car it would be unpractical and inelligible for some forms of motorsport.
    Any way, i have just had the shell professionally cleaned prior to commencing welding later this week.
    The shell has got some small areas of rust but nothing major. I have a weld-in cage to fit, seat rails, gearbox mount which was kindly donated by Simps from his saloon as i removed the one on this during the previous VXR attempt.
    Im planning to build something special for under the bonnet which i dont think has been done before, all im saying for now is its small block aspirated which is the best way for any Nova
    Will get some more pics up as i go through the welding.
    No thanks Chris
    Dec 2005
    Aldershot hampshire
    Agila c20let in making
    Re: Nova build by Chris Astley Motorsport
    make sure you keep us posted chris.
    Save the trees, wipe your ass with a owl!
    Gagged
    Apr 2004
    Mondeo ST TDCi
    Will do mate, gonna try and get on here a bit more now, hard with work,baby and everything else though.
    No thanks Chris
    Dec 2005
    Aldershot hampshire
    what happend to the vxr engine? can you not give us a clue as to what the spec of the nova will be?.
    Gagged
    Apr 2004
    Mondeo ST TDCi
    Quote Originally Posted by steve jordan View Post
    Well it will be a semi-stripped shell, welin cage, carbon seats, 6 point belts, gsi bumpers, Compomotive TH 15" wheels, Bilstein B16 kit, F20 box with big shafts and hubs e.t.c, 4 pots up front.
    possibly a corsa bias pedal box??
    Also i need to work out the motor i want to build as its a mix of bits to make an engine that vauxhall never made....
    I sold the VXR engine to ChrisR, not sure what he is doing with it though...
    No thanks Chris
    Apr 2002
    Southwest
    Like its stolen
    Interesting project
    London, United Kingdom
    78 Kadett C
    subd
    78 Kadett C 2.0 8v turbo
    MIGWeb Moderator
    Midlands
    Nowt
    Take it the shell has been for an acid bath?
    Apr 2001
    Norwich
    M3, 200sx, RWD Nova
    Shell looks to be in cracking condition mate.
    Look forward to seeing this move on.
    Jul 2002
    Northern Ireland
    6SPD 16V Turbo Nova
    Did you have the shell sent to SPL? or was it soda blasted?
    Oct 2003
    Glasgow/Oban
    Like it's a hire car
    shell looks awesome bare! will look forward to this one
    Sep 2006
    c20let astra coupe
    mk1 cav coupe
    This is gonna be good! good luck with it mate
    www shonkyopels de
    MIGWeb Moderator
    Midlands
    Nowt
    Quote Originally Posted by KeithRobinson View Post
    SPL are ace
    EY
    EY is offline
    Feb 2006
    Wymondham, Norfolk.
    to get more petrol.
    That's what i call a bare shell strip down! Looks solid
    MIG Performance camping
    1993 phase 3.5 Calibra turbo.
    Aug 2008
    Cambridgeshire
    A fleet of Griffins...
    hi what do you mean you had the shell professionally cleaned? acid dipped? shot blasted? interested as im weighing up the options when it comes to my cav project
    Macclesfield
    www.Retrobike.c
    Looking good chris.
    I am also interested as to what you had done to the shell and where did it?
    Back in the scene
    Dec 2005
    UK
    Frontera LWB, Astra GSI
    Ooooh!
    Gagged
    Apr 2004
    Mondeo ST TDCi
    The shell was done by a local company called ribble technology ltd in preston, they have also recently setup a website www.paint-strip.co.uk, on the site there is a video that guides you through there process. It is basically put in a large oven to heat the shell so all the paint/sealer e.t.c falls off, then is removed and jet washed, then put in a tank of chemicals to remove the rust, then jet washed again with an additive which prevents the metal from flash rusting. Prices start from £545+VAT depsnding on size of shell and amount of rust to remove e.t.c.
    No thanks Chris
    Gagged
    Apr 2004
    Mondeo ST TDCi
    Who is SPL?
    No thanks Chris
    Jan 2005
    hertford
    ph3.5 zafira gsi
    cool!!!
    www.revardagraphics.co.uk
    MIGClub Member jav786's Avatar
    May 2002
    Yorkshire
    Vec GSI/Evo IV/Cav T
    Looks good mate
    If you always tell the truth, people will stop believing you!
    http://www.iconperformance.co.uk/ - Vauxhall Specialist Tel 07962398027
    Aug 2005
    Manchester
    A Slow Corsa
    *subcribed*
    should be a good project, im intrigued as to what the engines gonna be
    Apr 2001
    Norwich
    M3, 200sx, RWD Nova
    is that bare metal chris or coated in anything?
    Gagged
    Apr 2004
    Mondeo ST TDCi
    Quote Originally Posted by The Simps View Post
    it is bare metal, there is slight discolouring from the heat of the oven. Gonna get some done on it on saturday hopefully as missis is workin so gonna go into work for a couple of hours.
    No thanks Chris
  26. #25
    Gagged
    Apr 2004
    Mondeo ST TDCi
    Quote Originally Posted by Ste L View Post
    *subcribed*
    Well im hoping to mate a C16SE head with a X18XE bottom end, but i want to offset grind the crank and overbore, not sure what size it will end up yet and depends what steel rods i can find, im aiming for 200bhp for a 8v small block
    No thanks Chris
Closed Thread
Tags for this Thread
