looks like a good shell, getting all that sound deadening off is loads of fun![]()
i found a hair dryer awesome to get the deadening out of my corsa gsi, warmed it up just enough to peel off, and didnt leave much mess
fair do's if you get ya shell as well prepper as that astra your onto a winner.
id have a look at using mk2 escort struts/steering column for the front or have a look atleast
Cool project, have read it but I have missed something, are you using the silver shell as a "1st draft" before hacking up the red or you taking bits off the red one and selling it on or de-spec-ing it?
Nova GSi Tb'd XE wip - migweb.co.uk/forums/projects-restorations/295478-nova-xe-full-restore-8.html
yea unfortunatly the red one's not too healthy underneith, so got this mint silver shell to 're-shell' it into! so still gonna look exactly the same from the outside, still be j61 rbm, and still be a performance red gsi, but yea like u say underneith everything will be despeced inside, a stripped out race car![]()
Just wish I had the garage to do it in.
Can't wait to see how this progresses`
Hi mate, Good to see the project started
We were fitting a "custom cage" last weekend just like a BIG mcarno set.
Wasnt impressed at all with there delivery times BUT...... a QUALITY piece of kit!
Make sure youve a spare pair of hands (probably not something even YOU lmao can do on your own) and a decent ratchet strap!
Best of luck Ron.
Lee.
wanted small minority to spoil it for the rest of us! Is it you?
had another few hours for some more stripping tonight!
carried on getting the whole loom out, very heavy
then engine bay
another pile of bits
and a bare engine bay
and for the people thinking about steering suggestions, heres the space i have to play with, see what i mean now!! i recon the flywheel is going to be about there the bottom of the bulkhead is
got tomorrow off so will prob loose all its suspension, then all that really will be left is a bare shell.
More space than an E30 BMW mate...
Have a look see here!!
Have you had a word with Jamie about the steering options? He brought my Senator steering setup for his V6 Mk2 Astra but I think he is using another solution.
MK III Astra 2.0l Turbo Cabriolet - Landrover Discovery
Skoda Otavia 2.0 Diesel Elegance
BMW 330 Ci Sport Convertible
hmmmm there maybe a steering development
need to source a cossie box and adapter belhousing!
Hi Ronnie, it's looking to be a good project. For the steering could you just swap the front legs left to right so the trak rod end mounts are facing forwards? as your using vectra legs the mount will be low enough to clear the chassis leg, then use the vaux steering rack mounted to the subframe just far enough forward to clear the engine, shouldnt be a problem to make some slightly offset track rods, then just need to extend the steering column with an extra UJ. It all sounds easier writing it than it will be in practice but thats the lines i'd be thinking along.
Anyway you dont want to add to many ford parts, you might get more rust/reliability issues, lol.
What motors have a front mounted rack and pinion setup? The steering rod will be quite long granted, but at least you'll be able to mess about with your exhaust setup a bit easier.
Got the time to space frame it?![]()
after a heads up from TomF to a project on astra-mk2.com in the making i went off for a very intresting read last night. a guy has put a sierra cossie engine and running gear in a mk2 astra. and cept his standard steering rack
now the reason i was so convinced the steering is going to be such a problem is on MONTY-D's RWD cav the back of the engine is right up against (and in) the bulkhead. not allowing room for a track rod, let alone a rack!
the position of the engine is determined by one point, the gearstick, that has to be in the exact same place as the standard astra one, this is the datum for where the engine will sit. now, what im assuming is that cavs have alot bigger foot wells than an astra, i.e the bulkhead is further forward in relationship with the gearstick, meaning bringing it alot closer to the engine. so if the mk3 astra is the same as the mk2 astra, then that would mean the bulkhead is further back, in relationship to the gearstick, meaning there 'should' be room for the standard steering rack to stay![]()
anyways, today was time to strip the rest of the underneith
and totally stripped from the bulkhead backwith only the subframe, legs and pedals left on the front
so the shells ready for the conversion
next major to do is get a T5 gearbox and a-frame custom bellhousing, to see where my engine is actually going to fit!
so time to get the turbo off to go to andiman for exchange for some nice moneys
and heres my piece of engineering thats stopped my so called 'thats such a cheap **** 200sx bodgejob thats gonna crack the first time you start the engine you should just go to nortec' manifold thats done me wellno cracks no problems!
and all the work i did moving the actuator around
Keep the good work up Ron![]()
If you always tell the truth, people will stop believing you!
http://www.iconperformance.co.uk/ - Vauxhall Specialist Tel 07962398027
It's moving faster than expected
might get bored tomorrow and cut the floor out!
good good
never doubted the manifold with brasing![]()
Excelent thread and project will be keeping an eyeon this one![]()
nice work ron glad to see ya still at it
