Old 26-11-2008, 17:28   #1
Painting!
I'm in the middle of building a wide arch rally car, cage is in, shells seam welded, generally ar**d about with. Now its time to paint it, which I'm going to do myself, space, heat, air and mask is covered, and im going to get some reasonalble guns, thinking both a gravity feed and a suction.
I'm only using base coat white 2 pack paint, nothing fancy!
What i want to know is what size nozzles do i need? I plan to paint hte whole car with hi-build, so do i need a bigger nozzle for this?
My plan was to primer whole car inside and out with the suction gun, then paint the inside with the suction gun, then do the top coat on the outside with the gravity gun as im told you get a better finish.
Has anyone got any tips? or suggestions? Moast the guns i've been looking at seem to be a 1.4mm tip!
Cheers
jamesmyers99 is offline   Reply With Quote
Old 26-11-2008, 18:23   #2
zx7r's Avatar
Drives: corsa xe, corsa let
Re: Painting!
iwata w400 or devibbis gti. both gravity fed guns, 1.4 or 1.3 fluid tip is about right
zx7r is offline   Reply With Quote
Members: 43,212
Threads: 310,613
Top Poster: LEE69 (43,150)
