he means grind the socket down, not the bolt head
SHoNkyOpELs.de
post some pix up man let us see the deamons![]()
dream project lotus carlton lump in a viva on ms and 2.1 bar!
Yep - I realise that and I tried it and the sockets won't stand the torque setting needed for the bolts - they just split and it was a good quality socket not a cheap one
Solution was to grind the bolt head down but I'd rather not have done that if there is a special tool I can make that solves the problem I'd like to see that
Bottom line is a std LC flywheel and clutch assembly is close to 30Kgs in weight - I've replaced it with a flywheel and clutch ass that weighs less than 10 kgs - maybe I don't need to use as high a torque setting but I've seen flywheels come thro transmission tunnels when they have come adrift or broken up.......
any room to double dowell the fywheel? always a good plan with a decent engine imo, i wouldnt fancy ginding heads down though
SHoNkyOpELs.de
Don't have pictures of the "special tool". It not just a ground socket.
Today I got my 3 3/4" carbon fiber driveshaft with 1350 U-joint. That looked MASSIVEBut again, my engine will need a massive drivetrain
Amazing rebuild mate! Can you please tell me did you order the head gasket directly from SCE, or there is a European dealer. I'm starting a rebuild on my LC, so any help regarding spare parts is greatly appreciated![]()
love it, me grandad had one and went very well
You need to join The Autobahnstormers Club.
Info HERE
Sourcing parts is made SO much easier, as there are a few people who have had to search for bits and pass the information on to help other owners.
Hello, just enjoyed reading your thread. Any updates?
Really like to see your adapted bellhousing.
I have also an additional question regarding your turbo c30se suggestion. Is it possible to use 144mm rods and C30xei pistons (machined down with one mm?) Or is there an other suitable piston from another brand that will fit after slight modifications?
Forgotten about this .
