LinkBack (1) Thread Tools
Old 24-11-2008, 21:54   1 links from elsewhere to this Post. Click to view. #1
Drives: GSI 16v TURBO
Astra GSI 2 GSIT 56k Heavy
Hey Guys and Girls Some of you may remember my car from billing 08 it was parked on the main stand right at the back next to steves cav..
The full story of my cars can be found here ...
http://www.mk3oc.org/forum/showthrea...257#post278257
Any way here she is started life as a standard ish Red Top.
Then i started to play about adding..
288 mm vectra v6 brakes
Then came the calibra guages
Then came performance Vauxhall in the summer great show
The car went up against one of my friends Toyota Celicas again 2.0 16v
Couple of months passed with no problems then there was a "bang" driving home one night..
Basically a spark plug had managed to strip its self from the cylinder head fly across the engine bay and arc out on the battery blowing a hole in the top... .fun !!!
So head came off and was re built. new head gasket, cylinder head was helicoiled and then fully re built...
So then after a little running in period the engine was back running again....
Did a bit more work on the inside of the car
Then along came the MK3OC rolling road day
the car managed to pull
146.5 BHP
148.1 lb ft Torque
109.3 Bhp @the wheels
Not the best of Figures for a Redtop but o well...More power was needed
THEN ALONG CAME A CALIBRA TURBO lol
Sole purpose of the calira was for the engine ........
just to make sure that all was well i decided to use the calibra for a while just to make sure that all was well with the engine before the conversion began.
On the first day of having the calibra coming home from work i decided to melt two of the pistons...
So that engine then came apart
Then the rest of the engine came out of the calibra and went off to be re-built
i decided not to cut any corners with it so had every thing replaced including the notorious oil pump......
Then all was built up and ready to go so we loaded it all up in to my passat and trotted off to see drizz..
The conversion Begins
The Leaky C20XE comes out ready for the C20LET to go in..
Then the car was finally done..
Drizz was warming the car up to tempreture up and down his lanes the when he got back to his workshop there was smoke everywhere from an oil leak straight out of the oil pump and down on to the manifold.
Long story short the oil pump that was brand new was cracked !!!!
Where the oil pressure sender screws in to the pump it had cracked.
The pump was purchased from auto vaux and was a "pattern pump "
So the car was towed home from drizz work shop. and sat on the drive for the next week and half.
Back to the engine builders It went and using the shell of the orignal calibra pump the new internals were built in to it.. all good again and no leaks.
There is a Knocking noise coming from the drivers side Drive shaft so got under it at the weekend and had look (apologies for the pics it was not that high off the ground)
Basically where the 2wd conversion plate was fitted the sleeve was fitted backwards so i just need to take the shaft out and re-fit them.
So far i have done 680 miles running the engine in..
In have brought some split shafts from ebay and am currently having the boost hoses made up by sfs performance. Then i can fit my FMIC and the build can carry on .....
Watch this Space ..................
GSiSpence is offline   Reply With Quote
Old 24-11-2008, 22:21   #2
Drives: Corsa C 2.0 SRi-T
Re: Astra GSI 2 GSIT 56k Heavy
Where is hert's is penning's ? i reckonise the name
sTaVwOrKz
stavs is offline   Reply With Quote
Old 24-11-2008, 22:22   #3
Drives: a van
looks nice, good to see a properly built up engine going in, not some 100k+ smoker that seems to be the norm for most people.
rudd86 is offline   Reply With Quote
Old 24-11-2008, 22:25   #4
Drives: astramk3gsi
very nice will definately follow this thread looks like it will be ace well done keep up work
mr.rail83 is offline   Reply With Quote
Old 24-11-2008, 22:26   #5
Its not lol thats taken at work in leighton Buzzard which is Bedfordshire
Old 24-11-2008, 22:30   #6
Regional Co-ordinator
Benn's Avatar
Drives: A shineeeey Nova
Thats a bit tasty.
Old 24-11-2008, 22:50   #7
Drives: Phase 2 GSi
Looking good mate, did you get that F28 rear mounting off someone on here ?
TomGTE is offline   Reply With Quote
Old 25-11-2008, 14:49   #8
have to ask drizz on that one.. when mine was removed from the car is was mullered so drizz fitted the current one. think somewhere along the line it did come from some one on here......
Old 25-11-2008, 17:13   #9
Drives: Astra GSi 1.8 16v
nice car mate. have I seen it outside halfrauds in letchworth at some point?
Not playing with a full deck....
Dan Boyes is offline   Reply With Quote
Old 25-11-2008, 18:27   #10
Drives: Cavalier SRi
I knew i recognized that place! Car looks really good
The cake is a lie :(
SteveM is offline   Reply With Quote
Old 26-11-2008, 13:33   #11
That would have been back in feb or before thats when i left
Yeah used to work at halfrauds in letch ran the bike hut up in the gods...
Old 26-11-2008, 13:43   #12
DaveB's Avatar
Drives: Corsa XE with TBs
Awesome. Looks like my old gsi lookalike in the first few pictures
Wedding Photographer and Portrait Photographer in West Yorkshire - www.2007bc.co.uk
DaveB is offline   Reply With Quote
Old 29-11-2008, 19:00   #13
ok busy day today ......
purchased some split drive shafts from the bay . arrived at work on thursday so today i got round to fitting the split side......
Aslo went shopping on wednesday night Purchased a set of boost hoses in red from SFS Performance just round the corner from work in luton.
Hopefully tommrrow going to get my intercooler fitted fingers crossed......
the shaft on the right is the orignal one that was sticking out of the box..
Left one is the new split shaft going on to the car..
Also brought some exhaust pipe going to use this to make up the pipes for the intercooler running between the silicon hoses. so set about painting it. i think the black will go well with the red. Had my very own team halfords BTCC mechanic do this for me
Then finally as it got dark i managed to get the car back on the ground and take it out for a drive before the fog came down its really bad at moment...
Should be able to get another update tommrrow with the intercooler fitted hopefully !!!!
Old 29-11-2008, 20:35   #14
i wondered why i havent i hadnt seen you about for a while. looks smart, gonna surprise a few people
kimbo is offline   Reply With Quote
LinkBack to this Thread: http://www.migweb.co.uk/forums/projects-restorations/379592-astra-gsi-2-gsit-56k-heavy.html
Posted By For Type Date
calibra pics - online discussion summary | BoardReader This thread Refback 02-12-2008 20:24
Members: 43,214
Threads: 310,613
Top Poster: LEE69 (43,150)
Welcome to our newest member, chrismessenger
