Old 05-11-2008, 13:11   #1
Drives: Omega & 1.8 Corsa B
1.8 Small block Corsa B
1.8 From a 2001 Vectra B, this was a STUPIDLY easy conversion. I can't believe it isnt a popular one?
Work so far:
2.25" Straight through system
Adjustable FPR
EGR Removed
Induction Kit (Or george valve as I like to call it )
280mm Discs + V6 calipers
Coil overs
Front + Rear braces
Polybushes
Braided brake lines
At present she goes very well, its on par with my mates Redtopped GSi.. I plan to get some lairy cams, build a plenum and I've got a better manifold.. These engines are good for 170bhp without too much of a headache.
The home of miserable bastids!
http://www.grumpyc*nt.com
Davey is offline   Reply With Quote
Old 05-11-2008, 18:44   #2
Drives: Calibra & Nova
Re: 1.8 Small block Corsa B
are any of these 1.8 ecotec's all small block then? z18xe and x18xe/r etc...?
peester is offline   Reply With Quote
Old 05-11-2008, 18:51   #3
all z18xe / x18xe1
NOT x18xe
Warren-G is offline   Reply With Quote
Old 05-11-2008, 18:54   #4
Drives: 16v Nova, Astra TD
Its not a very common conversion because unless your going for tb's etc etc, its not really worthwhile fitting over a 1600 16v, which are more common to buy and get parts for. (Std power difference is only like 10-12hp)
LongLiveTheNova is offline   Reply With Quote
Old 05-11-2008, 23:13   #5
Its on par with a local XE'd corsa and pushed a TypeR up the road... So what more can I say.
Old 05-11-2008, 23:55   #6
'sold' the idea , for me.. convincing performance wise. Its like the ultimate small block then.
Old 06-11-2008, 08:57   #7
ey?
Old 06-11-2008, 09:42   #8
edited my reply, lol..
to have around 120 bhp std, out-of-the-box from a small block engine,.. its up my street anyway.
Getting cheaper to buy all the while too i think, from vectras.
Old 06-11-2008, 09:50   #9
I think the characteristics of the engine better suite the Corsa too.. Revy, light weight and the variable inlet gives a nice ballanced power/torque delivery..
Old 06-11-2008, 09:53   #10
cool, wish i werent so far away, would like to have checked it out.
nice one tho dave.
Old 06-11-2008, 09:56   #11
Cheers
Old 06-11-2008, 11:10   #12
The one you have is a X18XE1 or the Z18XE?
vidas is offline   Reply With Quote
Old 06-11-2008, 11:11   #13
X18XE1.. They are identical other than the management and throttle.
Old 06-11-2008, 22:26   #14
where bouts on the blocks are the codes stamped..? near gearbox as usual..?
Old 06-11-2008, 23:59   #15
Its cast into the front of the block.
Old 07-11-2008, 00:32   #16
Drives: Fear into children
Nice one Davey, good sleeper
Ginge
A man goes into a library and asks for a book on suicide.
The librarian says, "**** off, you won't bring it back."
Ginge is offline   Reply With Quote
Old 07-11-2008, 09:26   #17
Drives: 3.0 V6, 2.5 V6, 1.8
The Z18XE has 130 BHP, X18XE1 115BHP.
The XE1 was used from about 99 to 2001, then the Z18 from 2001.
Z18 has electronic throttle so a little bit more work.
They a longer stroke X16XELs so will fit wherever a 1.4 or 1.6 XE does.
There are a range of engine covers you can get too, The one in the pic is a Z18XE one, the X18 one has the rear section in black textured finish.
The Corsa C one is all black textured and a lot smaller profile.
The Vectra C is a massive silver boxy one.
[url=http://77.96.230.10/sytemsandsoftwaredevelopment/systems.htm] How Tos
The two most life changing experiences you'll ever have. Finding Jesus, and having a baby.
Mark T is offline   Reply With Quote
Old 08-11-2008, 18:52   #18
I thought that the Z18XE one was plastic (and a bit lighter...), is this true?
How about electrics? Were there any problems or just the usual X16XE-out-of-the-box conversion?
I am thinking to follow the X18XE1 route too, but can't decide...
Old 30-11-2008, 19:21   #19
Which gearbox you have fitted ?
Mihó is offline   Reply With Quote
Old 30-11-2008, 19:50   #20
Drives: CorsaB-C14SE-C16XE
that results in 15 bhp diference between engines?
whats does the x18 needs to get 130bhps?
if price is slightly over a x16xe i would go for it.. if its more than 600 poundish i would go 20xe..
LeNnOxLeWiS is offline   Reply With Quote
Old 30-11-2008, 23:22   #21
F13 gearbox.
You need the Z18XE management + throttle body...
Old 30-11-2008, 23:54   #22
F13 gearbox.
then it makes some sense this swap.. i would go for it and turbo it. Should be ok for a low boost 180 bhpish..
but the down side is that those engines are overpriced.. they are in most cases recent.
Old 30-11-2008, 23:58   #23
a safe 200bhp+ is possible on standard internals.. I was at TOTD a month ago and a guy with a corsa C 1.8 turbo (Z18XE) run 204bhp..
Old 01-12-2008, 00:03   #24
running 204 bhp is fair enough, dont know exactly if those 204bhp correspond or can cope with the same 204 of a standart c20let..
Old 01-12-2008, 07:53   #25
The X18XE1.. have rare parts....since they are not from the most wanted-popular engines
Opel spare parts sales
OPEL PARTS GREE is offline   Reply With Quote
Members: 43,212
Threads: 310,611
Top Poster: LEE69 (43,149)
