| Re: Calibra Track/Show Project water leak into footwells can be caused by many factors, one that plagued my first Calibra was due to speaker cable entering from the door pillar (hinged side pilar) into the door, everytime it rained (continuous drizzle all night for example) would fall through the door gaps even when doors are closed there is approx 1/4 gaps and the rain enteres these gaps, intersects the speaker cable, clings around it and then runs along the cable due to garvity and clinging properties of water, and runs into the door, once inside the door it will leak just where the bottom of the door is inside the car around the bottom door seal.
yours could be due to another cause, but the thing to watch out is does yours collect water when it rains? or does yours collect water everytime you drive? rain water can eneter through scuttle panel and when its drainage is blocked so clear these drain holes and so on.
internal heater matrix can leak inside the car, but then you would know that wouldn't you as the coolant level would go down each time.
__________________ Calibra simply Calibra
I blessed Nemesis's Calibra and he got gagged, anybody else wants their Calibra blessed? |
