06-10-2008, 18:05
#1 | | MIGClub Member
Join Date: Nov 2006 Location: Bridgnorth. Drives: Corsa c20let
| My corsa c20let |
06-10-2008, 18:15
#2 | | MIGWeb User
Join Date: Mar 2005 Location: newport s.wales Drives: 350+bhp Nova Turbo
| Re: My corsa c20let good base |
06-10-2008, 21:22
#3 | | MIGWeb User
Join Date: Aug 2002 Location: Manchester Drives: Nova GSi 16v Turbo
| Re: My corsa c20let I helped Chris with that engine conversion, quite a good shell, can't believe he sold it so cheap. |
26-10-2008, 11:48
#4 | | MIGClub Member
| Re: My corsa c20let Its clean,just needs the front tidying up. The car wouldnt tick over so I did a compression check and found a had nothing in the first cylinder. Turned out I had burnt out a few valves. So the engines out to get some work done. Work so far . . .
Full f28 rebuild with quaife diff
Power steering kit fitted
Frontera front mounted intercooler and silicone pipework
Chris Astley uprated hubs/bearings and equal length shafts
New valves all lapped in.
Set of avo coilovers
Will get some pics up this weekend if I get chance |
26-10-2008, 12:21
#5 | | Regional Co-ordinator
| Re: My corsa c20let Needs a bit of love, biuts thats nice, should good well too...
__________________ Quote: |
26-10-2008, 12:29
#6 | | MIGWeb User
Join Date: Sep 2007 Location: glos Drives: corsa-c c20let
| Re: My corsa c20let any new pics m8? |
26-10-2008, 12:41
#7 | | MIGWeb User
Join Date: Apr 2008 Location: Northfleet Kent Drives: Astra GSi Mk3
| Re: My corsa c20let Very nice mate, me liking them wheels  lol
__________________ **Astra GSi Mk3 ** MVOC.co.uk |
26-10-2008, 13:28
#8 | | MIGClub Member
| Re: My corsa c20let Lol, heres a few pics I got before my battery went of some of the parts...
My f20 flywheel against the standard f28 pot
My shiney new bracket for my cossie actuator
My equal length shafts
One of my nice new hubs
My avos,just got to get some springs
and my messy engine bay with power steering rack put back in  |
26-10-2008, 16:57
#9 | | MIGWeb User
Join Date: Nov 2007 Location: Glossop Drives: c20let corsa gsi
| Re: My corsa c20let looking like a good base, where did you get your actuator bracket from? |
26-10-2008, 17:26
#10 | | MIGClub Member
| Re: My corsa c20let bracket was from scooby mate. P.m him if you need one, quailty is a1 |
26-10-2008, 17:31
#11 | | MIGWeb User
| Re: My corsa c20let looks very similar to my old corsa turbo, except mine was on an L plate.
good choice to fit the f28 with a diff, whats the linkeage like to setup? heard it can be a bit of a nightmare.. |
26-10-2008, 20:18
#12 | | MIGClub Member
| Re: My corsa c20let Piece of cake make. Dont think its any harder than doing a normal one |
31-10-2008, 19:32
#13 | | MIGWeb User
Join Date: Nov 2007 Location: Chesterfield Drives: Astra+CorsaLET, 306d
| Re: My corsa c20let bargain |
03-11-2008, 16:15
#14 | | MIGClub Member
Join Date: Jan 2002 Location: Worcester Drives: Astra GSI V6, Vectra
| Re: My corsa c20let looking good ash, you just need some speedlines on her now lol  |
03-11-2008, 16:41
#15 | | MIGWeb User
Join Date: Apr 2007 Location: Stafford Drives: Corsa Turbo
| Re: My corsa c20let looking good so far. When you get some springs for your coilovers can you let me know where you get them from please if buying new that is as my avo's dont lower that much and seen people with same ones go lower so kinda frustrating as its slammed on rear but quite high at the front  |
04-11-2008, 12:54
#16 | | MIGClub Member
| Re: My corsa c20let No probs mate,ive been quoted £106 delivered for a set of 300lb springs delivered from avo. |
04-11-2008, 12:58
#17 | | MIGWeb User
| Re: My corsa c20let is that for all 4 though bud??? i only need fronts some reason mine wont lower that much :S |
20-11-2008, 10:57
#18 | | MIGClub Member
| Re: My corsa c20let good choice to fit the f28 with a diff, whats the linkeage like to setup? heard it can be a bit of a nightmare..[/quote]
I take it back!!! Having mega problems with the gear linkage??! Its as though there is something blocking the rod that comes out of the gearbox to the linkage. The gearstick will only go up and down when connected and will not go left at all. Is this a common problem or could it be a problem with the rebuilt gearbox?? Thanks, Ash |
20-11-2008, 14:07
#19 | | MIGWeb User
Join Date: Dec 2005 Location: Telford Drives: mk3 astra TD
| Re: My corsa c20let looks good adgie, hope you get the linkage sorted for the meet |
20-11-2008, 16:17
#20 | | MIGWeb User
Join Date: Jul 2004 Location: bolton Drives: c20let corsa sport
| Re: My corsa c20let the rod needs shortening then welding back together! |
20-11-2008, 19:04
#21 | | MIGWeb User
| Re: My corsa c20let The linkage has already been modified as car was already running an F28. Sounds like the linkage isn't adjusted right or the selector wasn't located in the right place when the box was put back together. |
30-11-2008, 14:19
#22 | | MIGClub Member
| Re: My corsa c20let All sorted now the guy had put the selector rod back in wrong. Wish id have checked before I had put everything back together and just had the gear linkage to do but nevermind. So now i have got it all back together with the quaife diff and equal length shafts and it drives a lot better. I also fitted a set of chips I had yesterday and my alesios. Just got to tidy up the body work now and take a few pics |
Members: 42,547
Threads: 308,198
Top Poster: LEE69 (42,904) | | Welcome to our newest member, angelillo | | » Join MIGClub Today | Join online
now!
of being a MIGClub Member.
