My Wide-Arched F/G Panelled MSA Log booked Track Nova
Page 6 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 126 to 150 of 152
Thread: My Wide-Arched F/G Panelled MSA Log booked Track Nova
  1. #126
    Oct 2008
    Costa Del Bridlington
    calibra/nova
    Re: My Wide-Arched F/G Panelled MSA Log booked Track Nova
    Cage and seats in, need some plates for legs and il weld it in, then see if i can find front section of a cage at some point
    http://www.migweb.co.uk/forums/projects-restorations/374395-my-wide-arched-f-g-panelled-msa-log-booked-track-nova.html
    Feb 2008
    salisbury
    Transit / 2.0 Nova
    Hows this going?
    Just been speaking to chris at CMComponent's. Have arranged to have a pair of doors, a pair of wings and a bonnet done for 4 weeks time
    Might need some guidance on hanging them..... Its hard to tell from your pics but can window rubbers and lower weather strips still be used?
  4. #128
    Oct 2008
    calibra/nova
    Quote Originally Posted by 8valve-craig View Post
    Hows this going?
    nothing to update at moment, been out of work since christmas and been helping mates with there cars, i have the money to get it running right (ECU) and paint and few odd/sods but dont really want to spend till i know whats happening on job side of things just incase
    i had the rubbers on and was ok, never tried the metal surrounds but i think i will be getting rid of rubbers and bond/screw them in, fitting the doors is easy tbh done it twice now, plus you will have your standard doors to double check measurements before you cut
  5. #129
    Oct 2008
    calibra/nova
    decided to have a tinker with direct to box gear linkage set-up for the nova that came with the car (removed it because it was stuck solid)
    after stripping it down and clean up
    after opening it up the bar had slipped round inside i think something is missing attaching the bar, i forgot to take a picture but does anyone have a picture of inside theres to give me an idea ?
    also took engine out of corsa ready for c20xe conversion
    a little bit of surface rust to clean up but solid
  6. #130
    Feb 2008
    salisbury
    Transit / 2.0 Nova
    I wondered what had happened to this.
    Keep at it. Would be nice to see you get some use out of it.
  7. #131
    Oct 2008
    calibra/nova
    moneys been a little tight lately, close to been useable thats the annoying thing, doesn't mean i will be selling the nova tho lol
  8. #132
    Feb 2008
    salisbury
    Transit / 2.0 Nova
    first dibs on the doors....
  9. #133
    Oct 2008
    calibra/nova
    still after a set ? how did you get on with chris
  10. #134
    Feb 2008
    salisbury
    Transit / 2.0 Nova
    We agreed a deal on some doors, wings and a bonnet for £500. But the cars been tucked up until today so wasnt too bothered. Fitted an Xe on 45's today so might start buying more bits for it.
    Its a good deal. But soon doubles when factoring in colection fuel and bodyshop costs,
  11. #135
    Oct 2008
    calibra/nova
    true you are a fare distance from him, i may know someone selling a set of doors in Lincolnshire, a bit closer for you, Colin smith aka novarally,
  12. #136
    Feb 2008
    salisbury
    Transit / 2.0 Nova
    Are they the ones off his red nova? If so i think they are just outer skins and dont open.
  13. #137
    Oct 2008
    calibra/nova
    no, he also has a set same as mine made by chris that he may not be using now
  14. #138
    Oct 2008
    calibra/nova
    managed to get a few little bits done today, clutch cable, had to use another throttle cable to R1 carbs and cut it shorter so i now have 2 working pedals lol
    tacked the gear linkage in and abit of cutting
    before
    after
    i will clean everything up once every things sorted, also took picture of iinside the gear lever/linkage,
    i have been trying to find out some info is it just me or is there something missing ? ford type 9 ?
    backward and forward movements ok-ish but must be something missing for side to side to twist the bar ?
  15. #139
    Oct 2008
    calibra/nova
    not long got back with c20xe for corsa, with mounts, shafts, powercap ect ect
    might get started on it tomorrow or at weekend
  16. #140
    Oct 2008
    calibra/nova
    made a start on fitting the XE to corsa
    not far off just need to get few little bits then get it running
  17. #141
    Oct 2008
    calibra/nova
    terrible weather yesterday but wasn't going to let it stop getting it running, shortly after me and my mate started it started to rain, and i mean rain without stopping all day,
    so we made shelter lol
    all i can say is i wont be doing that again but it was funny and we did get the job done,
    video below, first time running, blowing on mani only had 2 nuts on, air temp and lambda sensor wasn't plugged in also need to get new radiator and pipe
  18. #142
    Sep 2009
    Livingston, West Lothian
    Vectra 1.8 LS saloon
    good progress buddy your also nuts for doing 2 cars at once, lol, personall6y i'd lose track of what i was doing, lol
  19. #143
    Oct 2008
    calibra/nova
    Quote Originally Posted by corsaXEV_chris View Post
    hopefully got a triumph herald to play with and another suzuki sj coming soon
  20. #144
    Oct 2008
    calibra/nova
  21. #145
    Oct 2008
    calibra/nova
  22. #146
    Eastern Regional Coordinator Spinbitch's Avatar
    Sep 2003
    Colchester, Essex
    MK3 Astra & Dis
    Brilliant project mate, just read through the entire thread. Be great to see the Nova finished.
    Soory I must of missed it, who did you get to do the fibreglass panels for you? Thinking of getting a bonnet and maybe a bootlid for my MK3 Astra.
    Chris
  23. #147
    Oct 2008
    calibra/nova
    Quote Originally Posted by Spinbitch View Post
    Chris
    cheers,
    chris off png, cmcomposites he did my doors
  24. #148
    Oct 2008
    calibra/nova
  25. #149
    Sep 2009
    Quote Originally Posted by calibra-keith View Post
    is this paint or a chrome plating? cant tell in the pics, also the wire with the croc clips in the pics before confused me, lol.
  26. #150
    Oct 2008
    calibra/nova
    powder coated bud, that was high chrome powder
