01-10-2008, 21:49
#26 | | MIGWeb User
| Re: my vectra 8v turbo build Lovely grinder work!  |
01-10-2008, 22:06
#27 | | MIGWeb User
Join Date: Feb 2007 Location: grimbsy Drives: vectra B 8v turbo
| Re: my vectra 8v turbo build Quote:
Originally Posted by A1an Lovely grinder work!  |
i was impresed with it also
__________________ i now own the only 1.8 8v turbo vectra B in the uk running 14 psi on megasquirt half the valves double the power |
03-10-2008, 17:00
#28 | | MIGWeb User
| Re: my vectra 8v turbo build |
03-10-2008, 17:58
#29 | | MIGWeb User
Join Date: May 2003 Location: durham Drives: R1 ,Astra V6, cav.t
| Re: my vectra 8v turbo build Looking good mate, definatley a good base to work on. I know everythings temp, but have you seen the pontiac sunbird turbo manifolds on ebay.com? from the G20LET engine, might be worth a look.
__________________ LET the fun begin....... |
03-10-2008, 18:31
#30 | | MIGWeb User
| Re: my vectra 8v turbo build they are hard as hell to get for the 8v engines ive seen a few the ones off the c20get are t2 flanges not t3 witch is what im running |
03-10-2008, 19:54
#31 | | MIGWeb User
Join Date: Sep 2003 Location: South London Drives: Without Due Care
| Re: my vectra 8v turbo build nice stuff there
i might of missed it so forgive me, what management is it on? and power output is that?
__________________ /// |
03-10-2008, 20:05
#32 | | MIGWeb User
Join Date: Jul 2006 Location: Northants Drives: 12.1 sec Corsa..@120
| Re: my vectra 8v turbo build sleeper.........  |
03-10-2008, 20:36
#33 | | MIGWeb User
Originally Posted by doge5644 nice stuff there
i might of missed it so forgive me, what management is it on? and power output is that? |
it is running megasquirt managment at the moment it is running 13 psi hoping to get it mapped to about 18 psi as for power im not sure as ive never put it on the rollers but going to be putting it on some when i get it all finshed |
03-10-2008, 20:37
#34 | | MIGWeb User
Originally Posted by bux sleeper.........  |
that is the look im going for with this one a car that looks standad every thing hidden just got to get some wheel trims now lol |
05-10-2008, 21:07
#35 | | MIGWeb User
Join Date: Mar 2008 Location: norton canes Drives: cav 2.0 16v(redtop)
| Re: my vectra 8v turbo build what manifold/s did ya use m8 ? whats the turbo off ? and what did ya do to lower the compression?
im intrested in doing the turbo conversion on a 8v im running
__________________ WWW.OVOC.NET |
05-10-2008, 21:36
#36 | | MIGWeb User
Join Date: Jul 2000 Location: Braintree, Essex Drives: Astra 888/Vec SRI V6
| Re: my vectra 8v turbo build That mount your using is no good what you need is one from a none aircon vectra that will give you better clearance for your turbo
__________________ 888 Astra/Vectra V6 Nurburgring attack 2009 |
05-10-2008, 22:39
#37 | | MIGWeb User
Originally Posted by beasty cav what manifold/s did ya use m8 ? whats the turbo off ? and what did ya do to lower the compression?
im intrested in doing the turbo conversion on a 8v im running |
manifold is a home made one mate but here is a link to the propper one im just waiting on funds to get one http://cgi.ebay.com/ebaymotors/SPA-T...mZ320203257634
the turbo is a t3 with internal waste gate the compresion is standad 9.2 compresion i can get a way with this as im running standalone managment so it been mapped around it but to lower the c/r you can get the standad pistons mechened for about £50 or stick a set of let rods and pistons in it that will drop it down to 8.5.1 i couldnt do that as mine is a 1.8 and the block is not as tall but even on this c/r im running 13 psi and it will go more yet if you want more info on 8v turbos have a look on my mates site http://www.vaux-extreme.com/ im vecky 8vt on there   |
05-10-2008, 22:43
#38 | | MIGWeb User
Originally Posted by Spankee That mount your using is no good what you need is one from a none aircon vectra that will give you better clearance for your turbo |
i heard this but couldnt find one the only one i did find was off of a 1.6 vecky and that was no good as there small block do you have any info on what models come with no a/c
thanks mike |
06-10-2008, 00:15
#39 | | MIGWeb User
Join Date: Jul 2006 Location: north pole Drives: Corsa 1.4 Corsa 2.0T
| Re: my vectra 8v turbo build you cane get conversion plates from t2 to t3 so you can get one of the pontiac manifolds on cheaply |
06-10-2008, 13:55
#40 | | MIGWeb User
Originally Posted by GBE86 you cane get conversion plates from t2 to t3 so you can get one of the pontiac manifolds on cheaply | Thats what i was getting at, about $59 last i looked! |
06-10-2008, 16:54
#41 | | MIGWeb User
| Re: my vectra 8v turbo build have you got a link to them please mate |
06-10-2008, 17:32
#42 | | MIGWeb User
Join Date: Aug 2008 Location: Peterborough Drives: Corsa Sport.
| Re: my vectra 8v turbo build yeah buh they add about 2-3 inch's? |
07-10-2008, 08:15
#44 | | MIGWeb User
Originally Posted by bowman |
thanks mate bin looking at that buy the time i stick a plate on it from t2 to t3 my turbo will sit to low down
it is now all running just a few other bits to sort out on it then should be on the road |
08-10-2008, 15:45
#45 | | MIGWeb User
| Re: my vectra 8v turbo build nice one dude, get some vids up if you can! |
12-10-2008, 20:05
#46 | | MIGWeb User
| Re: my vectra 8v turbo build cheers buddy will give it ago and see what happens |
Members: 43,216
Threads: 310,618
Top Poster: LEE69 (43,150) | | Welcome to our newest member, kaytee_lou | | » Join MIGClub Today | Join online
now!
of being a MIGClub Member.
