24-09-2008, 23:34
#1 | | MIGWeb User
Join Date: Nov 2003 Location: the big CiTy Drives: Cav T, Cali T, Vec V
| My Cav turbo rebuild... sound sys in
__________________ oh dear/dear me
cav turbo, boostin aaaaalll the day looooong - sleepers rule
24-09-2008, 23:34
#2 | | MIGWeb User
| Re: My Cav turbo rebuild, mot soon :) basically the head went porous and i wanted to uprate some parts as i went along, what started as a quick thing turned into a 3 year plan wi more and more bein done and replaced...
some of the main items
arp con rod bolts head studs etc,
steel head gasket,
uprated fuel pump,
uprated spark plugs
front mount intercooler,
silicon hoses
all new timing kit,
water pump
oil pump,
ceramic clutch,
uprated actuator,
new uprated alternator,
phase 2 software,
3.5bar fixed fuel pressure regulator,
irmscher 30mm lowering springs
xe cams.
All filters etc etc
Transfer box oil changed
Coscast head
Camshaft sensor
Coil & module
Fuel pump relay
Also ordered were all the small bits for interior/exterior,
· brand new velour mats,
· flaps,
· badges,
· weatherstrips,
· wiper arms,
· door mouldings,
· new front and rear bumpers and plastic reinforcements,
· new headlights and indicators,
· Clean set of 2nd hand fogs, (new ones are 100quid each, cant justify it at the mo lol L
· side repeaters,
· one new mirror,
· all the clips for the skirts and door mouldings etc,
· new central lockin module
· new battery
So wi engine out and sorted and back in, it was time to look at the outside, car has always been clean, genuine and straight with original arches etc, but I had a score on the pass side which needed painted, small bit of lacquer peel on the edge of the spoiler which no one would notice but annoyed me and few stone chips on the front. Was easier to respray the car than start tryin to patch the small bits. Friend in Banbridge sorted the prepping and stripping side of things and another friend sorted the painting. Have to say many thanks to these guys they’ve done an immense job couldn’t have hoped for a better finish anyone looking paintin done I highly recommend them pm and I’ll give ye details!!
Once she was stripped of the bumpers and skirts etc was afraid in case we’d find a few holes/rot, but happily she was very solid. Few pics of the paintin/strippin
Scrape on pass side
Car before goin for paint (cant really see scrape, but one of those things u know its there it bugs you)
Strippin, bumpers skirts windows, mouldings etc etc all off
Car primed  |
24-09-2008, 23:35
#3 | | MIGWeb User
| Re: My Cav turbo rebuild, mot soon :) |
24-09-2008, 23:35
#4 | | MIGWeb User
| Re: My Cav turbo rebuild, mot soon :) some bits and bobs arrived
and the refurbed alloys all wrapped in nice new toyo rubber
finally the new fogs are ere
the irmy bushes have been pressed in aswell so the camber shud be sorted for lowering. Hopefully be mot-able in the next few weeks!!!
well mot prep in full swing wi a mate working hard at it as i've bust me back!!! fuel leak cured, exhaust has new clamps, brake lines all cleaned, new frt suspension arms and drop links, the lowering springs are fitted on the frt as frt left had a broken coil, but the rears are a bit loose on full xtension so i'll leave them till after mot, new wipers and all bulbs tested ok
got the new frt headlamps in think they look great, new pass side fog in too but need to get bumper off to do drivers side.
ABS being a pain throwin light on occasionally but hopefully that be sorted, just wax oiling to do (thus the silly vectra rims, save gettin wax oil on the back of the tubby rims, change the frt windows to non tinted items and think its ready to go thru... fingers crossed it passes 1st time!!
whilst i was in the mood workin at it i decided to get it cleaned up a little as inside hadn't been touched in aaaaages, few pics for now
new fog and headlamp
interior cleaning
and of course wi dirty hands i touched roof cloth back pass side... grr
next up for the cleanin treatment... under the bonnet!!!  |
24-09-2008, 23:36
#5 | | MIGWeb User
25-09-2008, 00:56
#6 | | MIGWeb User
| Re: My Cav turbo rebuild, mot soon :) cavaliers stunning, would you happen to have the part number for the centre caps for the wheels?
david |
25-09-2008, 07:57
#7 | | MIGWeb User
| Re: My Cav turbo rebuild, mot soon :) i sourced them through autovaux part no. is
AS90372642
I know from lookin at a few diff centre caps that there were variation, whether they just superceded the part no. when a new supplier made them or they modified the design in some way i'm not sure
think vaux were about £24 each + vat for them
autovaux worked out 13.82+vat each |
25-09-2008, 08:35
#8 | | MIGClub Member
Join Date: Nov 2000 Location: Huddersfield Drives: Corsa XE with TBs
| Re: My Cav turbo rebuild, mot soon :) Damn that is a tidy cavalier. VERY impressed with the boot build
__________________ Wedding Photographer and Portrait Photographer in West Yorkshire - www.2007bc.co.uk |
25-09-2008, 09:39
#9 | | MIGClub Member
25-09-2008, 10:15
#10 | | MIGWeb User
| Re: My Cav turbo rebuild, mot soon :) Fresh pics this mornin wi the bits and bobs done...
ragin ordered a lot of the parts about 2.5years ago, amongst them were cav headlamp protectors, went to fit them this mornin, theyre feckinc alibra one, not a major thing seein as i have the cali tho i suppose
new batt cover fitted, not overly happy wi it, i'll replace it at some stage
all the new lights on the front...
refurbed tubby rims and the standard front windows fitted for mot, must remember to ask mot tester to actually chek the back windows with the tint metre see if they would fail
new interior mat set
thats all for now... hopefully be able to update with the tints back in, the rear lowered and boot build singin on full song again before long!!! |
25-09-2008, 10:45
#11 | | MIGWeb User
Join Date: Oct 2002 Location: Swindon Builds: Nova Drives: Fiesta XR2i 16v
| Re: My Cav turbo rebuild, mot soon :) That is a very clean example. One the cleanest i've seen in along time. Loving the boot build and the retrimmed door card insets. Car didnt look too bad on the Vectra rims. Could do with being abit lower an the back though, IMO.
__________________ Lewis Hamilton - Vodafone McLaren Mercedes - FIA F1 World Champion 2008 Still Building a valver nova... |
25-09-2008, 10:54
#12 | | Regional Co-ordinator
Join Date: Dec 2006 Location: KEITH (N.E. SCOTLAND Drives: mk3 astra sport 1.8
| Re: My Cav turbo rebuild, mot soon :) this and your Calibra. Your a jammy bastard. |
25-09-2008, 11:58
#13 | | Regional Co-ordinator
| Re: My Cav turbo rebuild, mot soon :) Damn that is one fine classic car. Really nice to see one still in one piece.
25-09-2008, 12:09
#14 | | Administrator
Join Date: Jun 2006 Location: Caerphilly S.Wales Drives: Cavalier 1.8
| Re: My Cav turbo rebuild, mot soon :) Top top job  |
25-09-2008, 12:12
#15 | | MIGClub Member
Join Date: Sep 2007 Location: Isle of lewis Drives: Dangerously!
| Re: My Cav turbo rebuild, mot soon :) Stunning, good job mate!! |
25-09-2008, 12:47
#16 | | MIGWeb User
| Re: My Cav turbo rebuild, mot soon :) yeah rear 30mm springs to go in still and the boot build so rear will come down level!!! |
25-09-2008, 14:02
#17 | | MIGWeb User
Join Date: Jan 2005 Location: Hampshire Drives: '58 BMW X6
| Re: My Cav turbo rebuild, mot soon :) I want that |
25-09-2008, 15:28
#18 | | MIGWeb User
Join Date: Jul 2002 Location: Northern Ireland Drives: Builds Nova Turbo
| Re: My Cav turbo rebuild, mot soon :) Awesome car Scotty, always been a huge fan. We'll have to convoy to the show's and ring next year  |
25-09-2008, 17:21
#19 | | MIGWeb User
| Re: My Cav turbo rebuild, mot soon :) thanks for the part number mate if autovaux is that much cheaper then ill just got them from them
thanks  |
25-09-2008, 17:50
#20 | | MIGClub Member
Join Date: Jun 2006 Location: Dunfermline, Fife. Drives: Nova GSI 1.6T
| Re: My Cav turbo rebuild, mot soon :) That is automotive porn. |
25-09-2008, 17:57
#21 | | MIGWeb User
| Re: My Cav turbo rebuild, mot soon :) not a bother for the part number, i've replaced lots of bits from bumpers, clips, weatherstrips to windscreen, wiper arms you name it and have the reciepts for everything so if ur stuck for anything try me... if i can help ya i will, i generally foned round everywhere to see who was cheapest for what bits and got friendly wi the local parts man who helped me a lot i must say!!!
thaks for the comments folks, cant wait for the first proper drive down to mot... its been so long |
25-09-2008, 18:26
#22 | | MIGWeb User
Join Date: Mar 2005 Location: newport s.wales Drives: 350+bhp Nova Turbo
| Re: My Cav turbo rebuild, mot soon :) absolutly stunning |
25-09-2008, 19:14
#23 | | MIGWeb User
| Re: My Cav turbo rebuild, mot soon :) Thats Wicked!!! |
25-09-2008, 19:17
#24 | | MIGWeb User
| Re: My Cav turbo rebuild, mot soon :) Very nice motor chap |
25-09-2008, 19:27
#25 | | MIGWeb User
Join Date: Apr 2008 Location: Northfleet Kent Drives: Astra GSi Mk3
| Re: My Cav turbo rebuild, mot soon :) looks lovly mate, if i ever sold my Astra GSi, id get one of them
__________________ **Astra GSi Mk3 ** MVOC.co.uk |
Members: 42,547
Threads: 308,185
Top Poster: LEE69 (42,904) | | Welcome to our newest member, angelillo | | » Join MIGClub Today | Join online
now!
of being a MIGClub Member.
