i jst typed a really long update and it closed... gutted..
ah well, was saying i attcked the car and stripped a#her to find very little rust (surprising.) and i#that im planing on fitting qed q420 cams with +1mm valves, solid lifters, double valve springs, colisbro guides, pocket pistons, con rods, possibly rebore to 2100cc, lightened balanced flywheel, paddle clutch, gripper diff, seam welded with chris astley motorsport plating kit,machine bottom ball joints to adjust camber, tarmac rally springs, quiaffe quick steering rack, compition engne mounts, weber or dellorto 45's and a sparco 6 piont roll cage.
that should be good for 200+ out a N/A fwd car, weighing less that a ton... fun fun fun..
will post up some pics of the progress when i get them hosted.
any comments or suggestions much appriciated.
Gregor.
