18-09-2008, 09:41
#1 | | MIGWeb User
Join Date: Feb 2007 Location: Cape Town - S.A. Drives: 96 Kadette 200TS
| South African Corsa Turbo 450hp target
__________________ Opel Corsa 20xe throttle bodies - 245bhp - 13.2 1/4 mile
Opel 200TS - eds phase 2 - water/methanol 306bhp @ 0.9 bar boost - stock turbo |
18-09-2008, 09:42
#2 | | MIGWeb User
| Re: South African Corsa Turbo 450hp target |
18-09-2008, 13:04
#3 | | MIGWeb User
Join Date: Aug 2006 Location: huntingdon Drives: 11secNova+GTR+CDTI
| Re: South African Corsa Turbo 450hp target Nice, which turbo? |
18-09-2008, 13:09
#4 | | MIGWeb User
Join Date: Oct 2002 Location: Swindon Builds: Nova Drives: Fiesta XR2i 16v
| Re: South African Corsa Turbo 450hp target Looking good. Love the gold wheels against the red paintwork. More pics please!
__________________ Lewis Hamilton - Vodafone McLaren Mercedes - FIA F1 World Champion 2008 Still Building a valver nova... |
18-09-2008, 13:41
#5 | | MIGWeb User
| Re: South African Corsa Turbo 450hp target The turbo is a custom spec T3/T4, T4 'O' trim turbine wheel in a 0.63AR T3 exhaust housing, with a Volvo Compressor wheel (56mm inducer/82mm exducer) 48 trim, in a T04E A/R 50 housing, and all the rest 360 thrust etc. Plan is to boost around 1.8 bar (26 Psi) when all tuned up. |
18-09-2008, 14:00
#6 | | MIGWeb User
Join Date: Feb 2002 Location: West Yorks Drives: Corsa Sport 2.0 XE
| Re: South African Corsa Turbo 450hp target the collector on the manifold looks a bit of a let down compared to the rest of the work.
Other than that i'm happy  |
18-09-2008, 14:03
#7 | | MIGWeb User
Join Date: Apr 2008 Location: Northfleet Kent Drives: Astra GSi Mk3
| Re: South African Corsa Turbo 450hp target wow, that looks really nice
__________________ **Astra GSi Mk3 ** MVOC.co.uk |
18-09-2008, 14:21
#8 | | MIGWeb User
| Re: South African Corsa Turbo 450hp target Quote:
Originally Posted by wazpaz the collector on the manifold looks a bit of a let down compared to the rest of the work.
Other than that i'm happy  | For my first ever manifold build i am quite happy, I also didn't have alot of space to play with as i moved the engine more to the front of the engine bay. |
18-09-2008, 15:19
#9 | | MIGWeb User
Join Date: Nov 2005 Location: chester/n.wales Drives: class 7 corsa;)
| Re: South African Corsa Turbo 450hp target looking good, but how come you moved the engine abit further forward? surely that would affect handling? |
18-09-2008, 15:22
#10 | | MIGWeb User
Join Date: Jul 2008 Location: nr Derby Drives: V8 Senator
| Re: South African Corsa Turbo 450hp target I think you need a bit more silicone (less alloy) in the boost pipework because the engine will rock under load! |
18-09-2008, 15:45
#11 | | MIGClub Member
Join Date: Feb 2006 Location: Norwich Drives: to get more petrol.
| Re: South African Corsa Turbo 450hp target Awesome build! |
18-09-2008, 16:25
#12 | | Regional Co-ordinator
| Re: South African Corsa Turbo 450hp target Great attention to detail, it looks well built & seeing as you made the exh manifold yourself..... Pat yourself on the back.
How long until mapping?
18-09-2008, 20:14
#13 | | MIGWeb User
Join Date: Apr 2001 Location: Norwich Drives: Nova Coupe
| Re: South African Corsa Turbo 450hp target looks great!
what brakes and suspension to tame the beast? |
18-09-2008, 20:30
#14 | | Regional Co-ordinator
| Re: South African Corsa Turbo 450hp target Very nice. |
18-09-2008, 23:26
#15 | | MIGWeb User
| Re: South African Corsa Turbo 450hp target Car has bilstein thick shaft racing shocks up front with 2L brakes, Koni adjustables at the rear, Engine was moved forward to increase traction, only been moved forward by 3cm so shouldn't affect handling that much, The chassis has been seem welded, aluminium roll cage going in, Quaife diff, equal length shafts, Will be running in and mapping at the same time, well a friend will be driving and i will be mapping, after a few hundred km i can put it on a dyno and fine tune. |
18-09-2008, 23:44
#16 | | MIGWeb User
Originally Posted by Agent Kellerman I think you need a bit more silicone (less alloy) in the boost pipework because the engine will rock under load! | The boost pipes are actually quite easy to move, so there should be enough flexability, but besides for that all the mounts are solid polyurithane mounts, so it should flex very little if anything.
Here's a vid of another corsa i Helped build for a friend. Its an XE engine with M3 itb's http://s11.photobucket.com/albums/a1...t=Corsa16v.flv |
19-09-2008, 00:13
#17 | | MIGClub Member
Join Date: May 2001 Location: South Wales Drives: Cav Tbo Evo5 on 18's
| Re: South African Corsa Turbo 450hp target very nice  what injectors u using?
__________________ I love MIG...MIG loves meeee...like one big gooOy F A M I L E E E |
19-09-2008, 06:55
#18 | | MIGWeb User
| Re: South African Corsa Turbo 450hp target RC 750cc Low impedance |
19-09-2008, 07:33
#19 | | MIGWeb User
| Re: South African Corsa Turbo 450hp target Nice one Pantera. Seems to be going well for the local okes - Chris and Debs have probably by now got their mint Superbosses and this project. Who built the turbo, I'm looking to upgrade the Focus ST225 I have and that spec would do the job @ 350 or so bhp with a custom mani. |
19-09-2008, 07:43
#20 | | MIGWeb User
| Re: South African Corsa Turbo 450hp target I ordered it from Mr turbo with that spec |
19-09-2008, 07:51
#21 | | MIGWeb User
| Re: South African Corsa Turbo 450hp target Are 2ltr brakes enough? I'd want better than that personally. |
19-09-2008, 09:51
#22 | | MIGWeb User
| Re: South African Corsa Turbo 450hp target I might fit Let brakes, but i can't go too big or the drag slicks will not fit as they 15" |
22-09-2008, 11:51
#23 | | MIGWeb User
22-09-2008, 19:25
#24 | | MIGClub Member
Join Date: Dec 2002 Location: Essex Drives: 1.0 12 V Corsa
| Re: South African Corsa Turbo 450hp target Wow , animal
Redline at 6k though ? thought all Vauxhalls were 6.5k . |
22-09-2008, 20:16
#25 | | MIGClub Member
Join Date: Sep 2007 Location: Co Durham Drives: Astra 2.0 16v Sport
| Re: South African Corsa Turbo 450hp target Looks Really good mate. Hope all goes well. |
Members: 42,547
Threads: 308,182
Top Poster: LEE69 (42,903) | | Welcome to our newest member, angelillo | | » Join MIGClub Today | Join online
now!
of being a MIGClub Member.
