LinkBack (1) Thread Tools
Old 10-10-2008, 21:33   #51
Drives: Corsa Tbo n Prelude
Re: First Corsa Track Car
yes.
vxlgsi is offline   Reply With Quote
Old 11-10-2008, 18:02   #52
SLICKCORSA's Avatar
Drives: Nissan Outlaw PickUp
Well got throttle bodies back yesterday after machine shop spaced them out, they look really good. Had the standard throttle sensor fitted looks like it a factroy fit. Just need a custom fuel rail making and a vacum block. What air filter would be best to use on these, or should i use no air filter and fit ram pipes?
Sorted out what goodridge hose fitting i had today, just need a few small bits for project.
Started on breather system, does anyone know if you take a outlet of the block anywhere as on my cosworth has a block breather also.
Click image for larger version
ID:	4796  Click image for larger version
ID:	4797  Click image for larger version
ID:	4798  Click image for larger version
ID:	4801  Click image for larger version
SLICKCORSA is offline   Reply With Quote
Old 11-10-2008, 19:09   #53
Drives: around looking Cool!
Light flywheel makes a hell of a difference!!
(")_(")Station once said: Nowden. u nd 2 gt a bgr njin, dat way u cn get rid ov dat shttee njin u av an den stop torkin like a cumpleet chav. To some complete idiot!
Old 12-10-2008, 00:14   #54
Drives: Corsa 1.4 Corsa 2.0T
especially to vxlgsis bank balance
Gaz86 is offline   Reply With Quote
Old 12-10-2008, 20:37   #55
Throttle bodys look spot on, did they have to mod the linkage too?
Bring back the power of LET
Old 12-10-2008, 21:08   #56
SLICKCORSA's Avatar
just made each one a bit longer, they only cost to build 300.00
Old 12-10-2008, 21:09   #57
SLICKCORSA's Avatar
Originally Posted by leigh 2.0 16v View Post
how mcuh money have u chucked at this looks amazin so far done properly
to date i have spent with buying the car 3k
Old 14-10-2008, 18:25   #58
SLICKCORSA's Avatar
Hi everyone, i have being buying a few bits from the states latley but to today i got my remote oil filter, i paid 49.00 USD for it. I am well happy with it.
ID:	4806  Click image for larger version
Old 14-10-2008, 18:53   #59
nice project! some interesting parts being used.
Novaload_Nick is offline   Reply With Quote
Old 19-10-2008, 17:10   #60
SLICKCORSA's Avatar
hi everyone done a few bits today
1. Sorted out breather system on rocker cover
2. Built up single wiper set-up
3. Started to build-up rear beam brake lines but -4 fitting are for fuel/vacuum line not brake so ordered new fitting, but using -4 fuel/vacuum line fitting on vacuum set-up
4.Made some carbon fiber wing vents, going to have rocker cover breathering to a header tank, then header tank braathing to wings where indicators go.
5.Finished off lightening doors.
Things may be a bit slow for the next few weeks as i am moving
comments needed
ID:	4825  Click image for larger version
ID:	4826  Click image for larger version
ID:	4827  Click image for larger version
ID:	4829  Click image for larger version
ID:	4830  Click image for larger version
Old 19-10-2008, 19:09   #61
Drives: Nova Coupe
Great project this mate. I live up near riverside in norwich and would love to come take a nosey round this sometime, especially seeing as I'm fitting bike carbs too mine too. PM me your contact details.
Simps.
The Simps is offline   Reply With Quote
Old 19-10-2008, 21:15   #62
Drives: Escort S2/Corsa D!!
Them parts look lush and its gonna sound mental with them carbs!
LeHICK is offline   Reply With Quote
Old 20-10-2008, 14:16   #63
Drives: Mk4 Astra Gsi
Not the usual track car build, Should be one of the cleanest about!! Well done!
allan_d_1 is offline   Reply With Quote
Old 01-11-2008, 14:53   #64
Drives: Red top 20 XE
Hi Lovely looking job and great attention to detail, all I will say is try and supply your Throttle Bodies with the coldest air you can, so definately not from under the bonnet as that will be very hot from rad and exhaust etc and loose you lots of BHP, I hope that helps, Regards DM
Dinoman is offline   Reply With Quote
Old 30-11-2008, 16:58   #65
SLICKCORSA's Avatar
Hi people, I got moved over the last last couple of weeks and got my new home workshop up and running, a few updates got shell back from welders not done a bad job just a few small bits to finnish, like remove bulkhead and seat runners etc.
Got a few more bits of hose from States
I have also finnished rear beam brake hoses & stud conversion, picking up throttle bodies next friday where i have had a custom fuel rail & vacuum mainfold made.
comments needed.
ID:	4953  Click image for larger version
ID:	4954  Click image for larger version
ID:	4955  Click image for larger version
ID:	4957  Click image for larger version
ID:	4958  Click image for larger version
ID:	4959  Click image for larger version
ID:	4961  Click image for larger version
ID:	4962  Click image for larger version
ID:	4963  Click image for larger version
ID:	4965  Click image for larger version
ID:	4966  Click image for larger version
ID:	4967  Click image for larger version
Old 30-11-2008, 17:45   #66
Drives: senator 24v/saxo
some top work there
callymat is offline   Reply With Quote
Old 30-11-2008, 18:52   #67
Must admit your attension to detail is great, the only thing that would worry me is the damage it might inccur whilst out there on such a painstakingly intensive rebuild could all be a lot of work for nothing, or do you intend on just keeping it mint and do the odd trackay...
Theony reason i mention this is my mate had a minty mint scooby RB5 when they were nearly new, and did the odd trackday in his concourse car and rolled it at cranner curves second time out uninsured and a loss of nearly 20k ouch...
neo1 is offline   Reply With Quote
Old 30-11-2008, 18:59   #68
Drives: Corsa 2.0 Gsi
This is quality! I love the old Cossie's great cars. Few questions
1. Where you get your manifold wrap? I got sum n it was crap. lol
2. Where you get the rocker cover powder-blasted? How much?
Keep it up
Andy Mc
mcewanslager2k2 is offline   Reply With Quote
Old 30-11-2008, 19:14   #69
SLICKCORSA's Avatar
Thats why i am building it i had nearly 30k in that cossy everytime i went out in it i was thinking what if. With this i will have approx 7k in it if what if happens its a new shell + 2k. The trouble with me is i like everything clean, so if i have a problem its so much easier to see and do.
Old 30-11-2008, 19:22   #70
SLICKCORSA's Avatar
Keep it up
Andy Mc
Hi i got mainfold wrap off ebay link below, the rocker cover got done at the people below they do all lotus stuff first class company it cost me approx £20.00 as i had loads off stuff done hope this helps.
http://shop.ebay.co.uk/merchant/flamebarrier
Colorcote (Norfolk) Ltd
6, Potash Lane,
Hethel,
Norwich,
Norfolk
NR14 8EY
Tel: 01953 607789
Old 30-11-2008, 21:09   #71
Cle
Drives: Vauxhall nova 1.2i
This is going to be one reallllly cool corsa
Flat oot like a dukes fit
Cle is offline   Reply With Quote
Old 30-11-2008, 21:53   #72
Drives: MG ZR
Awesome progress mate. I'm loving the attention to detail with the powder coating. Going to be one tidy little machine!
Keep up the good work!
forestfighter is offline   Reply With Quote
Old 30-11-2008, 21:53   #73
Rick Draper's Avatar
Drives: 2.2bar = 500bhp :-)
Can i ask if it took much hunting to find somewhere to blast your shell?
Losers and cheats do win, just ask Lewis Hamilton and mclaren
Rick Draper is online now   Reply With Quote
Old 30-11-2008, 23:22   #74
SLICKCORSA's Avatar
Got a company in Derham Norfolk to do it for 200.00 cash if you need the name and tel let mw know, if you just go on to yell.com and type in blasting and powder coating in your area or truck trailer blasting and painting.
Hope this helps! your corsa is taking good shape hope to see on the track next year
Old 01-12-2008, 17:58   #75
Drives: Nova Coupe
Thats very handy to know!
I'll give you a bell soon mate when I get some freetime.
LinkBack to this Thread: http://www.migweb.co.uk/forums/projects-restorations/371377-first-corsa-track-car.html
Posted By For Type Date
bike throttle bodies - Page 2 - Performance Nova Group - PNG This thread Refback 07-01-2009 16:32
Members: 43,214
Threads: 310,615
Top Poster: LEE69 (43,150)
Welcome to our newest member, chrismessenger
